Luckylight
0.54" Dual Digit Alphanumeric Displays
Technical Data Sheet
Model No: KWA-541XUYB12
Spec No.: C5243A1/B1
Approved: JOJO
Rev No.: V.2
Checked: Sun
Lucky Light Electronics Co., Ltd.
Date:Apr/01/2006
Drawn: Liu
Page:1 OF 6
http://www.luckylightled.com
Luckylight
Features:
0.54″ (inch) digit height.
Excellent segment uniformity.
Sold state reliability.
Industrial standard size.
Low power consumption.
The product itself will remain with in RoHS compliant Version.
Descriptions:
The KWA-541XXX series is a lager 13.60mm (0.54") high seven segments display
designed for viewing distances up to 7 meters.
These displays provide excellent reliability in bright ambient light.
These devices are made with white segments and black surface.
Applications:
Audio equipment.
Instrument panels.
Digital read out display.
Device Selection Guide:
Model No.
KWA-541AUYB12
KWA-541CUYB12
Approved: JOJO
Chip Material
AlGaInP
Rev No.: V.2
Checked: Sun
Source Color
Description
Super Yellow
Common Anode
Super Yellow
Common Cathode
Date:Apr/01/2006
Drawn: Liu
Page:2 OF 6
Luckylight
Package Dimension:
8.0[0.315]
8°
15.24 [0.600]
13.60 [0.54'']
21.15 [0.833]
PIN 1
7.7 [0.303]
1.0 [0.040
PIN 10
PIN 18
PIN 9
12.7 [0.500]
6.5 [0.256]±0.5
25.1 [0.989]
DIG.1
A
J
K
H
F
DIG.2
B
1
G
Φ0.5 [0.020]
G2
N
E
L
DP
D
2.54*8=20.32 [0.801]
C
M
KWA-541AUYB12
16
(COM)
11
(COM)
DIG.1
A
B
C
12 10 9
D
7
E
F G1 G2
H
J
K
DIG.2
L
M
1 18 13 6 17 15 14 2
4
N DP
5
A
B
C
D
E
8
F G1 G2
H
J
K
L
M
N DP
L
M
N DP
3 NO CONNECT
KWA-541CUYB12
16
(COM)
11
(COM)
DIG.1
A
B
C
12 10 9
D
7
E
F G1 G2
H
J
K
DIG.2
L
M
4
N DP
5
8
A
B
C
D
E
F G1 G2
H
J
K
3 NO CONNECT
Notes:
1. All dimensions are in millimeters (inches).
2. Tolerance is ± 0.25 mm (.010”) unless otherwise noted.
3. Specifications are subject to change without notice.
Approved: JOJO
Rev No.: V.2
Checked: Sun
Date:Apr/01/2006
Drawn: Liu
Page:3 OF 6
Luckylight
Absolute Maximum Ratings at Ta=25℃
Parameters
Symbol
Max.
Unit
Power Dissipation (Per Segment)
PD
70
mW
Peak Forward Current (Per Segment)
(1/10 Duty Cycle, 0.1ms Pulse Width)
IFP
100
mA
IF
25
mA
0.4
mA/℃
5
V
Dating Linear From 25℃
Reverse Voltage
VR
Operating Temperature Range
Topr
-40℃ to +80℃
Storage Temperature Range
Tstg
-40℃ to +85℃
Soldering Temperature
Tsld
260℃ for 5 Seconds
Electrical Optical Characteristics at Ta=25℃
Parameters
Symbol Min. Typ. Max. Unit
Luminous Intensity
mcd
Test Condition
IV
8.5
17.0
IF=20mA (Note 1)
Luminous Intensity Matching
Ratio (Segment To Segment)
Iv-m
2:1
Peak Emission Wavelength
λp
590
nm
IF=20mA
Dominant Wavelength
λd
588
nm
IF=20mA (Note 2)
Spectral Line Half-Width
△λ
15
nm
IF=20mA
Forward Voltage
VF
2.1
2.8
V
IF=20mA
Reverse Current
IR
50
µA
VR=5V
IF=10mA
Notes:
1. Luminous intensity is measured with a light sensor and filter combination that approximates
the CIE eye-response curve.
2. The dominant wavelength (λd) is derived from the CIE chromaticity diagram and represents
the single wavelength which defines the color of the device.
Approved: JOJO
Rev No.: V.2
Checked: Sun
Date:Apr/01/2006
Drawn: Liu
Page:4 OF 6
Luckylight
Typical Electrical / Optical Characteristics Curves
(25℃ Ambient Temperature Unless Otherwise Noted)
Ta=25℃
Forward Current IF (mA)
100
Forward Current & Forward Voltage
75
50
25
1000
400 500 600 700
Wavelength λp (nm)
Luminous Intensity &
Ambient Temperature
100
10
1
-60 -40 -20 0 20 40 60 80 100
Ambient Temperature Ta (℃)
Ta=25℃
50
40
30
1.5 1.7 1.9 2.1 2.3 2.5 2.7
Forward Voltage VF (V)
800
Luminous Intensity & Forward Current
Relative Luminous Intensity (%)
Spectrum Distribution
Ta=25℃
1000
f=1KHz
Duty=1/10
100
10
1 0
10
1
2
3
10
10
10
Forward Current Derating Curve
50
40
30
25
Approved: JOJO
60
80 100
Rev No.: V.2
Checked: Sun
Date:Apr/01/2006
Drawn: Liu
Page:5 OF 6
Luckylight
Please read the following notes before using the datasheets:
1. Over-current-proof
Customer must apply resistors for protection, otherwise slight voltage shift will cause big current
change (Burn out will happen).
2. Storage
2.1 If the package contains a moisture proof bag inside, please don't open the package before
using.
2.2 Before opening the package, the LEDs should be kept at 30℃ or less and 80%RH or less.
2.3 The LEDs should be used within a year.
2.4 After opening the package, the LEDs should be kept at 30℃ or less and 60%RH or less.
3. Soldering Iron
Each terminal is to go to the tip of soldering iron temperature less than 260℃ for 5 seconds
within once in less than the soldering iron capacity 25W. Leave two seconds and more intervals,
and do soldering of each terminal. Be careful because the damage of the product is often started
at the time of the hand solder.
4. Soldering
When soldering, for Lamp without stopper type and must be leave a minimum of 3mm clearance
from the base of the lens to the soldering point.
To avoided the Epoxy climb up on lead frame and was impact to non-soldering problem, dipping
the lens into the solder must be avoided.
Do not apply any external stress to the lead frame during soldering while the LED is at high
temperature.
Recommended soldering conditions:
Soldering Iron
Temperature
Soldering Time
300℃ Max.
3 sec. Max.
(one time only)
Wave Soldering
Pre-heat
Pre-heat Time
Solder Wave
Soldering Time
100℃ Max.
60 sec. Max.
260℃ Max.
5 sec. Max.
Note: Excessive soldering temperature and / or time might result in deformation of the LED lens or catastrophic
failure of the LED.
5. Repairing
Repair should not be done after the LEDs have been soldered. When repairing is unavoidable, a
double-head soldering iron should be used. It should be confirmed beforehand whether the
characteristics of the LEDs will or will not be damaged by repairing.
Approved: JOJO
Rev No.: V.2
Checked: Sun
Date:Apr/01/2006
Drawn: Liu
Page:6 OF 6
很抱歉,暂时无法提供与“2158”相匹配的价格&库存,您可以联系我们找货
