NeoPixel RGB 5050 LED with Integrated
Driver Chip - 100 Pack
PRODUCT ID: 3094
Description
Make your own smart LED arrangement with the same integrated LED that is used in our NeoPixel strip
and pixels. This tiny 5050 (5mm x 5mm) RGB LED is fairly easy to solder and is the most compact way
possible to integrate multiple bright LEDs to a design. The driver chip is inside the LED and has ~18mA
constant current drive so the color will be very consistent even if the voltage varies, and no external
choke resistors are required making your design minimal. Power the whole thing with 5VDC and you're
ready to rock.
This is the 4 pin LED chip version, not 6. It is code compatible and the same over‐all shape and
functionality but not the same pinout so you cannot use these to replace an 'S chip. If you are designing
a new PCB we suggest going with the B, since it has built in polarity protection. Other than that, B and S
are the same brightness, and use the exact same code interface.
The LEDs are 'chainable' by connecting the output of one chip into the input of another ‐ see the
datasheet for diagrams and pinouts. To allow the entire chip to be integrated into a 6‐pin package,
there is a single data line with a very timing‐specific protocol. Since the protocol is very sensitive to
timing, it requires a real‐time microconroller such as an AVR, Arduino, PIC, mbed, etc. It cannot be used
with a Linux‐based microcomputer or interpreted microcontroller such as the netduino or Basic
Stamp. The LEDs basically have a WS2811 inside, but fixed at the 800KHz 'high speed' setting. Our
wonderfully‐written Neopixel library for Arduino supports these pixels! As it requires hand‐tuned
assembly it is only for AVR cores but others may have ported this chip driver code so please google
around. An 8MHz or faster processor is required.
These raw LEDs are cut from a reel and/or might be loose. They may not suitable for pick & place +
reflow. We recommend these for careful hand soldering only! Comes in a package with 100 individual
LEDs. We have a ready‐to‐go component for this in the Adafruit EAGLE library
https://github.com/adafruit/Adafruit‐Eagle‐Library
Technical Details
o
o
o
WS2812 Datasheet
https://cdn‐shop.adafruit.com/datasheets/WS2812.pdf
SK6812 Datasheet
https://www.adafruit.com/images/productfiles/1138/SK6812%20LED%20datasheet%20.pdf
o
May ship with either WS2812B or SK6812‐based LEDs. They are the same brightness,
color, and protocol.
Product Dimensions: 5.0mm x 5.0mm x 1.5mm / 0.2" x 0.2" x 0.1"
Product Weight: 0.1g / 0.0oz
https://www.adafruit.com/product/3094 9‐8‐17
很抱歉,暂时无法提供与“3094”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+276.535551+35.88026
- 国内价格
- 1+244.27440
- 200+97.47000
- 500+94.21920
- 1000+92.61000
