Flexible 8x32 NeoPixel RGB LED Matrix
PRODUCT ID: 2294
DESCRIPTION
For advanced NeoPixel fans, we how have a bendable, flexible 8x32 NeoPixel LED
Matrix! Control all 256 ultra-bright LEDs using a single microcontroller pin, set
each LED as you wish to scroll messages or draw little images. This matrix has a
thick flexible PCB backing that can be gently bent and curved around surfaces
You can use this matrix just like any other NeoPixel-compatible product, and we
even have NeoMatrix code that will let you use the matrix as a 8x32 grid for
drawing on without having to do all the icky math Just initalize NeoMatrix with
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, PIN, NEO_MATRIX_TOP + NEO_MATRIX_
LEFT + NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG, NEO_GRB + NEO_KHZ800);
Don't forget, with 256 LEDs, you could use over 15A of current if you turn on all
the LEDs on to white (which we really do not recommend because we don't think
the flex PCB can handle that much current). Try to keep the current draw at undrer
5A, you can use our 5V 4A or 5V 10A power supply. For portable use, if you are
drawing less than 3A, try out this 5V@3A UBEC.
Please note: Flexible PCBs are not designed for repeated flexing! While we think
this product may work in wearables or other situations where the matrix is bent
around, we do not offer any guarantees or refunds if you end up cracking the LEDs
or traces! This is for advanced users only, who already know how to use NeoPixels
and are comfortable with the high current requirements and protecting the matrix
from damage. There are no returns, refunds or replacements for damaged product.
Don't forget to read our NeoPixel Uber guide for more information on how to care
and feed your NeoPixels!
http://www.adafruit.com/product/2294
12/2/2015
Technical Details
320mm x 80mm x 2mm / 12.6" x 3" x 0.08"
Weight (with IDC cables): 63g
很抱歉,暂时无法提供与“2294”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+883.489301+114.30293
