D256 16*16 pixel display panel
Product Overview
D25616*16 Pixel display panel is a LED dot matrix display product witch is specially designed for the field
of LED-Clothing, it has many advantages as follow: Small size, light weight, arbitrary curved, easy to carry,
Low-voltage drive, green energy, high brightness, low power, long life.
D256 use our Company’s advance Intelligent LED driver IC, WS2812 as the basic unit. 16 Pixels are placed
each line, and there are 16 lines on each panel. The space between each pixel is 1cm. This product is totally
able to meet the basic requirement of Chinese character displaying. When used it with a controller additionally,
it can also display numbers, English, video and so on.
The Main Application areas
● LED-Clothing products
● Stage
Lighting,decorating
● Require
frequently disassembly. Occasions which need to be implemented in a limited space
Unit
:cm
Mechanical Dimensions
Dimensions(Unit
Unit:cm
:cm)
http://
http://www.world-semi.com
Wire Connection
PIN Funtion
Funtion:
No.
Symbol
PIN
Funtion Description
1
+5V
POWER
2
DIN
Data Input
3
GND
Earth
4
DOUT
Data Output
5V power supply
Input the control signal
Earthing
Output the control signal, connect to the next panel’s DIN
Maximum Ratings
Ratings(If not specified, TA=25℃,VSS=0V)
Paramater
Symbol
Range
Unit
Power Voltage
VDD
+4.5~+5.3
V
Logic input voltage
VI
-0.5~VDD+0.5
V
Operating Temperature
Topt
-25~+80
Storage Temperature
Tstg
-40~+105
http://
(If not specified,TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V)
Electrical parameters
parameters(
Paramater
Symbol
Minimal
Typical
Maximum
Unit
Input Current
ID
0.3A
15A
A
Operating Voltage
VDD
4.5V
5.0v
5.3V
V
RGB
Chip
Characteristic
parameters
Color
Model
Wavelength(nm)
Luminous intensity(mcd)
Operating
Voltage(V)
Blue
13CBAUP
465-467
180-200
3.0-3.4
Green
13CGAUP
522-525
660-720
3.0-3.4
Red
10R1MUX
620-625
390-420
2.0-2.2
Data Transfer ( TH+TL=1.25µs±600ns)
T0H
Code 0,
hight level
0.4µs
±150ns
T1H
Code 1,
hight level
0.8 µs
±150ns
T0L
Code 0,
low level
0.85µs
±150ns
T1L
Code 1,
low level
0.45 µs
±150ns
RES
low level
>50µs
Timing Waveforms
Input code:
Connection Method
Method:
D1
D IN
DO
P IX 1
Data Transfer Method
Method:
http://
D2
D IN
DO
P IX 2
D3
D4
D IN
DO
P IX 3
Note:The D1 on the figure above is the data sent by MCU,D2、D3、D4 are the data being transfered and adjusted by
the next level circuit.
24bit data structure
structure:
G7
G6
G5
G4
G3
G2
G1
G0
R7
R6
R5
R4
R3
R2
R1
Note:High data bits are sent first.Sending data according the order: GRB
http://
R0
B7
B6
B5
B4
B3
B2
B1
B0
很抱歉,暂时无法提供与“104990127”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+786.313301+101.78006
