LCD-09067
LCD-09067
    SPARKFUNELECTRONICS
    SERIALENABLED16X2WHONBK
LCD-09067 数据手册
Page 1 of 2   SparkFun Serial Enabled 16x2 LCD - White on Black 3.3V L C D - 09 0 6 7 R O H S       3  images are CC BY-NC-SA 3.0 Description: The serial enabled LCD allows you to control a parallel based LCD over a single-wire serial interface. Included in this product is a white on black 16x2 LCD connected to our serial backpack. The backpack, based around a PIC16LF88, takes a TTL serial input and prints the characters it receives onto the LCD. The installed firmware allows for a number of special commands so you can clear the screen, adjust the backlight brightness, turn the display on/off, and more. Communication with SerLCD requires 3.3V TTL serial at a default baud rate of 9600bps (8-N-1). You can adjust the baud to any standard rate between 2400 and 38400bps. The power, ground and RX pins are all broken out to a 3.5mm pitch screw terminal. SerLCD has the ability to dim the backlight to conserve power if needed. There is also a potentiometer on the backpack to adjust the contrast. Note: Though the silkscreen may say ‘5V’, this is a 3.3v Serial LCD. Connect to a 3.3v power source. Features: • • • • PIC 16LF88 utilizes onboard UART for greater communication accuracy Greater processing speed at 10MHz Incoming buffer stores up to 80 characters Backlight transistor can handle up to 1A Page 2 of 2 • Pulse width modulation of backlight allows direct control of backlight brightness and current consumption • All surface mount design allows a backpack that is half the size of the original • Faster boot-up time • Boot-up display can be turned on/off via firmware Dimensions: 1.425x3.15" - 1" Thick https://www.sparkfun.com/products/9067 11/11/2015
LCD-09067 价格&库存
很抱歉,暂时无法提供与“LCD-09067”相匹配的价格&库存,您可以联系我们找货
