Page 1 of 2
Serial Enabled 16x2 LCD - White on Black 5V
L C D - 09 3 9 5 R O H S
4
images are CC BY-NC-SA 3.0
Description: This is the latest evolution of our serial LCD. Included on a single board
is a 16x2 LCD and an embedded circuit based around a PIC 16F88. The on-board
PIC takes a TTL serial input and prints the characters it receives onto the LCD. The
installed firmware also allows for a number of special commands so you can clear the
screen, adjust the backlight brightness, turn the display on/off, and more.
Communication with SerLCD requires 5V TTL serial at a default baud rate of 9600bps
(8-N-1). You can adjust the baud to any standard rate between 2400 and 38400bps.
The power (VDD), ground (GND) and RX pins are all broken out to both a 0.1" pitch
header as well as a 3-pin JST connector.
SerLCD has the ability to dim the backlight to conserve power if needed. There is also
a potentiometer on the back of the display to adjust the contrast.
Features:
• Embedded PIC 16F88 utilizes onboard UART for greater communication
accuracy
• Adjustable baud rates of 2400, 4800, 9600 (default), 14400, 19200 and 38400
• Operational Backspace
• Greater processing speed at 10MHz
• Incoming buffer stores up to 80 characters
• Backlight transistor can handle up to 1A
• Pulse width modulation of backlight allows direct control of backlight brightness
and current consumption
• All surface mount design allows a backpack that is half the size of the original
• Faster boot-up time
Page 2 of 2
• Boot-up display can be turned on/off via firmware
• User definable splash screen
Dimensions:
• PCB: 103x36mm
• LCD: 71.4x26.4mm
https://www.sparkfun.com/products/9395
11/11/2015
很抱歉,暂时无法提供与“LCD-09395”相匹配的价格&库存,您可以联系我们找货
