Issue 7.2019
THE SERIALS
DOTMATRIX DISPLAYS WITH RS-232
s
l
a
i
r
e
TheS
EA SER162-92NLED
with snap in housing
Accessory:
cable EA KV24-9B
length: 1,50 m
FEATURES
32 DIFFERENT SIZES OF DISPLAYS AVAILABLE (1x8 UP TO 16x40)
SUPPLY VOLTAGE +5V OR OPTIONAL 9..35V1)
INCL. LED-ILLUMINATION SWITCHABLE BY MEANS OF SOFTWARE
25 DISPLAYS WITH YELLOW/GREEN LED-BACKLIGHT
7 DISPLAYS WITH LOW POWER WHITE LED-BACKLIGHT
3 DISPLAYS 1X8, 2X16 AND 4X20 WITH SNAP IN HOUSING
HIGH CONTRAST SUPERTWIST LCD
INCL. FRONTAL BEZEL WITH ANTIGLARE GLASS2)
AUTOMATIC LINE MANAGEMENT
CR / LF / SCROLL / CURSOR POSITIONING
BAUDRATE SETTING BY JUMPER: 300, 1200, 2400 OR 9600 BAUD
POTI FOR CONTRAST ADJUSTMENT ON BOARD
MULTIPLE DISPLAYS ON SINGLE RS-232C
OPTIONS
* SUPPLY +9..35V= INSTEAD OF +5V=
* RS-422 INTERFACE INSTEAD OF RS-232 (STANDARD)
* DIP-SWITCH FOR ADDRESS INSTEAD OF SOLDERBRIDGE
EA OPT-9/35V1)
EA OPT-RS4221)
EA OPT-DIP61)
ACCESSORIES
* CABLE WITH 9-PIN D-SUB FEMALE PLUG FOR PC
1)
2)
not available with SER308, SER408, SER3016 and SER4016
not available for all displays; please refer to the table at page 20
EA KV24-9B
THE SERIALS
GENERAL
The Serials
represents a complete LCD-Dotmatrix familiy with
input circuit and frontal bezel. These LCD-modules also includes
a RS-232 interface (or optional RS-422). The mounting is done
through holes of the LCD-module, the data connection is made
to a standard RS-232C/RS-422 interface. Transfer rate can be
set by jumper on 300, 1200, 2400 or 9600 Baud. All cursor
controls (line feed etc.) are performed automatically. All displays
feature LED-backlight illumination. Matching frontal bezel with
antiglare glass is included also.
scheme
POWER SUPPLY / CONTRAST ADJUSTMENT
Supply voltage is +5V, current consumption depends on type of display and its illumination (100-800
mA, see table on page 20). The Serials can be connected to power either by screw terminals or with
RS-232 connector. Display contrast is adjustable by potentiometer.
important: It is imperative that the polarity is correct. Even very brief polarity reversal can damage the
entire operating unit immediately and irreparably.
9..35V Versorgung bei Displays im Snap-In
MULTIPLE DISPLAYS ON A SINGLE RS-232C
A single RS-232C can operate a number of displays. For that an individual adress must be assigned
to each display. Commands "Select/Deselect" will target each individual display.
Adresseinstellung per Lötbrücken
1)
2)
Adresseinstellung über DIP-Schalter
Adresseinstellung bei Displays im Snap-In
not available with SER082-C, SER204-4, SER242-B, SER3016 and SER4016
Page 2
Printing and typographical errors reserved.
ELECTRONIC ASSEMBLY reserves the right to change specifications without prior notice.
THE SERIALS
COMMANDS, DATA TRANSFER
All incoming datas will be largely interpretated as ASCII datas. When display fills up, the characters
automatically scroll to the top. CR/LF will be recognized and executed. FF (12d/$0C) clears the
display. Cursor can be set manually by command i.e. "ESC O" (ESC=27d/$1B).
TABLE OF COMMANDS
Command
Formfeed FF (dec.:12)
Carriage Return CR (13)
Linefeed LF (dec.:10)
Cursor positioning
^L
^M
^J
ESC
Code
O
Cursor Form
ESC
C
Display Mode
ESC
M
Select / Deselect
ESC
S
D
n1
2
3
1
2
3
4
n2
adr
Remark
Clear screen and place cursor to home position (1,1)
Set cursor into first column left hand
Move cursor down to next line
n1=column; n2=line; home-position (1,1) top left hand
Hidden cursor
Cursor in form of a flashing block
Cursor as an underscore
Cursor in form of a flashing block with an underscore
Clear-mode; autoflow OFF
Clear-mode; autoflow ON
Scroll-mode; autoflow OFF
Scroll-mode; autoflow ON
Select interface adress adr=0..254; (adr 255=all)
Deselect interface adress adr=0..254; (adr 255=all)
after
Reset
1,1
3
4
selected
The 1-line, 2-line and 4-line displays offer beside standard-commands additional options:
additional commands for 1..4 line displays
Command
Display Mode
ESC
M
Convert Character Code
ESC
U
Define character
LED backlit on/off
ESC
ESC
Z
L
Code
5
6
n1
8 x data...
n1
Write output port
ESC
Y
n1
Version Number
ESC
V
Reset
ESC
R
n2
Remark
Overwrite-mode; autoflow OFF
Overwrite-mode; autoflow ON
no character code conversion
convert character code to IBM-Code (for englisch/japanisch character set)
n1=character no. (0..7); data = 8x bytes for new character
LED backlit n1=0: off, n1=1: on; n1=2: invert; n1=3..255 n1/10 sec. on
n1=0: Set all 6 output ports in accordance with n2 (=6-bit binary value)
n1=1..8: Reset output port n1 (n2=0); set (n2=1); invert (n2=2)
Shows the version number on the display
Resets and re-initializes the display and controller.
Before sending new data over the RS-232/RS-422 wait 500.
after
Reset
4
1
on
all
1
The 8-line and 16-line displays offer beside standard-commands additional options:
additional commands for 8- and 16-line displays
Command
Display Mode
ESC
Set letter type
ESC
Save actual settings
Select / Deselect
ESC
ESC
M
N
I
B
L
P
A
Code
5
6
7
8
adr
Remark
Set standard type; black letters; bright background
Set inverse letters; bright letters; black background
Flashing letters; black letters flash on bright background
Invers+flashing; bright letters flash on black background
Saves cursorform, display-mode and font-type in EEPROM
Assignes a new select/deselect adress (8 bit) to the interface
after
Reset
4
N
Page 3
THE SERIALS
RS-232C CONNECTION / BAUD RATES
Connection to RS-232C or RS-422 interface is made on a 2x5
pin type socket. With cable EA KV24-9B (accessories not for
RS-422) The Serials are ready to be connected directly to a PC.
Transfer rate can be set by jumper on 300, 1200, 2400 or 9600
Baud.
RS-232C socket (2x5 pins)
Pin
Symbol Function
Pin Symbol Function
DCD
connection to
DSR and DTR
4
NC
not connected
6
RXD
8
DTR
data input
connection to
DSR and DCD
10
GND
1
VDD
+5V
2
3
DSR
connection to
DCD and DTR
5
CTS
7
RTS
9
RXD5
CMOS
CTS and RTS
bridged
close
LB10+LB17
0V
RS-422 socket (2x5 pins)
Data format:
Pin
1
3
If no jumper is set during power on, the display switches into
self test mode and shows its character set.
5
7
9
Symbol Function
VDD
Pin Symbol Function
+5V
2
Data In+ Receive Data
4
NC
not connected
HS In+ and
HS Out+
HS Out+ bridged
HS In+
6
8
10
Data In- Receive Data
NC
not connected
HS In- and
HS OutHS Out- bridged
HS In-
GND
0V
If the operating unit is ordered together with the EA OPT-RS422 option, special RS-422 drivers are
fitted. The pin assignment in the table on the right then applies.
Incidentally, the same serial data with 5V level and CMOS logic
is available at Pin 9. These level are suitable for direct connection
to a µC. If these signal is used, the solder straps LB 10 + LB 17
must be closed!
Connection for SER308,SER408,SER3016,SER4016
Connection for displays with snap-in
Connection for 1- to 4-line diplays
Connection for 1- to 4-line diplays with EA OPT-RS422
Page 4
Connection for displays with snap-in with EA OPT-RS422
THE SERIALS
DIGITAL OUTPUT 1)
There are up to 6 digital outputs OUT1..OUT6. They share with the solder link for address setting
(cannot be used with EA OPT-DIP6). When one or more outputs are used, the possibility for address
set is limited automatically.
All versions except EA S ERxxx-92
Displays with Snap-In case (EA SERxx-92)
After Power-On all output are set to HIGH. Setting an output will be done by following command:
'ESC Y n1 n2'
n1: Output no. 1, 2, 3, 4, 5 or 6
n2=0: Output set to LOW (0V)
n2=1: Output set to HIGH (5V, EA SER204-92NLED: 3.3V)
n2=2: Invert output
APPLICATION EXAMPLE1)
Each output line provides a NPN transistor with about 50kOhm pull-up resistor; i.e. only LO level is
able to supply about 10mA. In summary current for
OUT1..OUT6 may not exceed 15mA. HIGH level is
able to source up to 100µA only. Driving a higher
load signal must be amplified by an external
transistor or MOSFET.
1)
not for SER308, SER408, SER3016 and SER4016
SELF DEFINED CHARACTER1)
8 character (ASCII codes $00..$07) are presetted with " ", "±", "²",
"³", "ß", "Ä", "Ö", "Ü" and can be redefined with the command
"ESC Z n1 data...". After re-definition the presetted codes are no
longer available. It makes sense to switch off the relocation of
ASCII codes via command 'ESC U 0'.
After power-on or reset the predefined codes are avaiable again.
Example:
ESC Z $00 $04 $04 $04 $04 $15 $0E $04 $00
After that, character code $00 is defined as an downside arrow.
Note: For definition 8 data bytes are necesary.
character data
bit value
hex (dez)
16 8
4
2
1
$04 (4)
$04 (4)
$04 (4)
$04 (4)
1
$15 (21)
1
1
$0E (14)
$04 (4)
$00 (0)
1)
not for SER308, SER408, SER3016 and SER4016:
only the complete character set can be exchanged
Page 5
THE SERIALS
CHARACTER SET:
1- TO 4-LINE DISPLAYS
All character listed beside are built-in
for the 1- to 4-line displays.
CHARACTER SET:
EA SER204-92HNLED/-92HNLEK
... does have a different character set.
CHARACTER SET:
8- AND 16-LINE DISPLAYS
All 8- and 16-line displays EA SER308, SER408,
SER3016 und SER4016 do provide the extended
IBM character set (codes 32..255) incl. frame
symbols. It is also possible to excange the character
set totally (e.g. for cyrillic or special codes).This can
be done together with the tools on EA DISK9708*).
+ Lower $0 $1 $2 $3 $4 $5 $6 $7 $8 $9 $A $B $C $D $E $F
(0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11)(12)(13)(14)(15)
Upper
$20 (dez: 32)
$30 (dez: 48)
$40 (dez: 64)
$50 (dez: 80)
$60 (dez: 96)
$70 (dez: 112)
$80 (dez: 128)
$90 (dez: 144)
$A0 (dez: 160)
$B0 (dez: 176)
$C0 (dez: 192)
$D0 (dez: 208)
$E0 (dez: 224)
$F0 (dez: 240)
also in internet at http://www.lcd-module.de/deu/disk/disk9708.zip
Page 6
THE SERIALS
EA SER081-92NLED
EA SER081-92NLEK (incl. RS-232 cable
incl. snap in housing EA 0092-KE
EA KV24-9B)
1x8,ZH 11.48mm
in
snap
Panel cut out: 70,5+0,5 x 48,5+0,5 mm
EA SER081-CNLED
incl. frontal bezel EA 017-2UKE
1x8,ZH 10.8mm
EA SER161-DNLED
incl. frontal bezel EA 017-1UKE
1x16,ZH 6.6mm
Page 7
THE SERIALS
EA SER161-ENLED
incl. frontal bezel EA 017-6UKE
1x16,ZH 9.66mm
EA SER082-CNLED
incl. frontal bezel EA 017-8UKE
1x8,ZH 11.44mm
Page 8
THE SERIALS
EA SER162-N3LW
hite
w
e
u
bl
2x16,ZH 5.55mm
EA SER162-CNLED
2x16,ZH 4.35mm
EA SER162-NLED
2x16,ZH 5.55mm
Page 9
THE SERIALS
EA SER162-NLW
hite
w
e
blu
2x16,ZH 5.55mm
EA SER162-BNLED
incl. frontal bezel EA 017-12UKE
2x16,ZH 9.66mm
EA SER162-BNLW
2x16,ZH 9.66mm
hite
w
e
blu
Page 10
THE SERIALS
EA SER162-92NLED
EA SER162-92NLEK (incl. RS-232 cable
EA KV24-9B)
2x16,ZH 6.68mm
in
snap
EA SER202-NLED
incl. frontal bezel EA 017-7UKE
2x20, ZH 5.55mm
Page 11
THE SERIALS
EA SER202-NLW
white
e
u
l
b
EA SER202-BHNLED
EA SER202-CNLW
Page 12
2x20, ZH 5.55mm
without frontal bezel
2x20,ZH 9.2mm
2x20,ZH 12.7mm
THE SERIALS
EA SER242-NLED
EA SER242-BNLED
EA SER402-NLED
incl. frontal bezel EA 017-14UKE
2x24,ZH 5.55mm
2x24,ZH 9.66mm
incl. frontal bezel EA 017-4UKE
2x40,ZH 5.55mm
Page 13
THE SERIALS
EA SER402-NLW
hite
w
e
blu
2x40,ZH 5.55mm
EA SER164-NLED
4x16,ZH 4.75mm
EA SER204-92HNLED
EA SER204-92HNLK (incl. RS-232 cable
EA KV24-9B)
4x20,ZH 3.73mm
in
snap
Page 14
THE SERIALS
EA SER204-4NLED
4x20,ZH 4.03mm
EA SER204-NLED
incl. frontal bezel EA 017-9UKE
4x20,ZH 4.75mm
EA SER204-NLW
4x20,ZH 4.75mm
white
e
u
l
b
Page 15
THE SERIALS
EA SER204-BNLED
4x20,ZH 9.2mm
EA SER404-HNLED
incl. frontal bezel EA 017-13UKE
4x40,ZH 4.89mm
EA SER404-NLW
4x40,ZH 4.89mm
Page 16
white
e
u
l
b
THE SERIALS
EA SER308-NLED / SER408-NLED
incl. frontal bezel EA 017-10UKE
8x30 bold / 8x40,ZH 4.2mm
Page 17
THE SERIALS
EA SER3016-NLED / SER4016-NLED
16x30 bold / 16x40,ZH 3.55mm
CAUTION!
Use ESD precautionary procedures
Electrostatic sensitive components
ATTENTION
handling precautions!
Page 18
THE SERIALS
FRONTAL BEZEL / DIMENSIONS
Drawing shows the nose piece for frontal bezels EA 017-xxUKE; EA
017-xxKE have a rim on full circumference.
Display type
Viewing area
Outside dim.
A
B
EA SER081-CNLED
EA SER161-DNLED
EA SER161-ENLED
60,0
63,5
98,5
14,8
12,8
12,8
EA SER162-N3LW
EA SER162-CNLED
60,0
63,5
14,8
12,8
C
D
1 line displays
76,0
27,0
79,5
25,0
114,5
25,0
2 line displays
76,0
27,0
79,5
25,0
EA SER162-NLED
EA SER162-NLW
60,0
14,8
76,0
97,4
22,4
81,5
EA SER162-BNLED
EA SER162-BNLW
EA SER202-NLED
EA SER202-NLW
EA SER242-NLED
EA SER402-NLED
EA SER402-NLW
EA SER164-NLED
EA SER204-NLED
EA SER204-NLW
EA SER404-NLED
EA SER404-NLW
Mounting size
Frontal Bezel
E
F
G
66,2
69,7
104,7
21,2
19,2
19,2
71,0
74,5
109,5
EA 017-2U
EA 017-1U
EA 017-6U
66,2
69,7
21,2
19,2
71,0
74,5
EA 017-2U
EA 017-1U
27,0
66,2
21,2
71,0
EA 017-2U
113,4
34,6
103,6
28,8
108,4
EA 017-12U
17,2
97,5
29,4
87,7
23,6
92,5
EA 017-7U
92,0
14,8
108,0
27,0
98,4
21,2
103,0
EA 017-14U
153,0
14,8
169,0
27,0
159,2
21,2
164,0
EA 017-4U
60,8
24,2
4 line displays
76,8
36,4
67,0
30,6
71,8
EA 017-8U
75,0
24,2
91,0
36,4
81,2
30,6
86,0
EA 017-9U
145,0
28,0
161,0
40,2
151,2
34,4
156,0
EA 017-13U
137,2
44,4
142,0
EA 017-10U
8 line displays
EA SER308-NLED
EA SER408-NLED
131,0
38,0
147,0
50,2
Dimensions in mm
Page 19
THE SERIALS
ALL SERIALS - AN OVERVIEW
Serial displays with RS-232 and LED backlight
Ordering
information
Lines x
Char.
Char.
height
Module dimension Viewing area
W
H
Bezel
D
W
H
1 line displays
Cutout
bezel
W
H
Keypad
EA OPTCurrent
NeW ! TAST5x5
typ.
EA SER081-92NLED
1 x8
11.48
77.0
54.0
26.0
56.5
22.0
0092-KE
70.5
48.5
100
EA SER081-CNLED
1 x8
10.8
84.0
44.0
26.0
61.0
15.8
017-2UKE
66.2
21.2
30
optional
EA SER161-DNLED
1 x 16
6.56
80.0
36.0
27.0
64.5
16.0
017-1UKE
69.7
19.2
100
optional
EA SER161-ENLED
1 x 16
9.66
122.0 33.0
27.0 99.0
13.0
2 line displays
017-6UKE
104.7
19.2
170
optional
EA SER082-CNLED
2 x8
11.44
84.0
44.0
27.5
63.0
25.0
017-8UKE
67.0
30.6
90
EA SER162-N3LW
2 x 16
5.55
80.0
36.0
27.0
64.5
16.0
017-2UKE
66.2
21.2
40
EA SER162-CNLED
2 x 16
4.35
80.0
36.0
27.0
64.5
13.8
017-1UKE
69.7
19.2
90
EA SER162-NLED
2 x 16
5.55
84.0
44.0
29.0
61.0
15.8
017-2UKE
66.2
21.2
120
EA SER162-NLW
2 x 16
5.55
84.0
44.0
27.0
64.5
16.0
017-2UKE
66.2
21.2
40
blue
EA SER162-92NLED
2 x 16
6.68
77.0
54.0
26.0
56.5
22.0
0092-KE
70.5
48.5
100
Snap-In
EA SER162-BNLED
2 x 16
9.66
122.0 44.0
29.0
99.0
24.0
017-12UKE 103.6
28.8
360
EA SER162-BNLW
2 x 16
9.66
122.0 44.0
29.0
99.0
24.0
017-12UKE 103.6
28.8
65
EA SER202-NLED
2 x 20
5.55
116.5 39.0
29.0
85.0
18.6
017-7UKE
87.7
23.6
210
EA SER202-NLW
2 x 20
5.55
116.5 39.0
26.0
85.0
18.6
017-7UKE
87.7
23.6
40
EA SER202-BHNLED
2 x 20
9.2
146.0 43.0
29.0
123.0
23.0
127.2
28.4
270
EA SER202-CNLW
2 x 20
12.7
190.0 54.0
29.0
149.0
31.0
100
EA SER242-NLED
2 x 24
5.55
118.0 36.0
29.0
93.5
15.8
017-14UKE
98.4
21.2
150
optional
EA SER242-BNLED
2 x 24
9.66
208.0 40.0
29.0
178.0
23.0
190
optional
EA SER402-NLED
2 x 40
5.55
182.0 33.5
29.0
154.1
15.3
017-4UKE
159.2
21.2
150
optional
EA SER402-NLW
2 x 40
5.55
182.0 33.5
27.0 154.1 15.3
4 line displays
017-4UKE
159.2
21.2
40
EA SER164-NLED
4 x 16
4.75
87.0
60.0
29.0
61.8
25.4
017-8UKE
67.0
30.6
220
EA SER204-92HNLED
4 x 20
3.73
77.0
54.0
26.0
56.5
22.0
0092-KE
70.5
48.5
100
EA SER204-4NLED
4 x 20
4.03
80.8
47.0
29.0
60.0
22.0
90
optional
EA SER204-NLED
4 x 20
4.75
98.0
60.0
29.0
76.0
25.2
017-9UKE
81.2
30.6
260
optional
EA SER204-NLW
4 x 20
4.75
98.0
60.0
29.0
76.0
25.2
017-9UKE
81.2
30.6
45
EA SER204-BNLED
4 x 20
9.2
146.0 62.5
29.0
123.0
42.5
810
optional
EA SER404-HNLED
4 x 40
4.89
190.0 54.0
29.0
147.0
29.5
017-13UKE 151.2
34.4
440
optional
EA SER404-NLW
4 x 40
4.89
190.0 54.0
29.0 147.0 29.5
8 line displays
017-13UKE 151.2
34.4
75
EA SER308-NLED
8 x 30
29.0
40.2
017-10UKE 137.2
44.4
300
EA SER408-NLED
8 x 40
29.0 134.0 40.2
16 line displays
017-10UKE 137.2
44.4
300
EA SER3016-NLED
16 x 30
EA SER4016-NLED
16 x 40
4.2 bold 180.0 65.0
4.2
180.0 65.0
3.6 bold 144.0 104.0 29.0
3.6
144.0 104.0 29.0
134.0
114.0
64.0
700
114.0
64.0
700
Snap-In
optional
blue
optional
optional
optional
optional
optional
blue
optional
optional
blue
optional
optional
blue
blue
optional
optional
optional
Snap-In
blue
blue
optional
optional
Dimensions in mm
Current in mA
ATTENTION
CAUTION!
ELECTRONIC ASSEMBLY GmbH
Zeppelinstraße 19
D-82205 Gilching
Germany
Fon:
Fax:
e-Mail:
Web:
+49 (0)8105-77 80 90
+49 (0)8105-77 80 99
info@lcd-module.de
www.lcd-module.de
