LK204-25-USB-E
LK204-25-USB-E
    MATRIXORBITAL
    LCD CHARACTER DISPLAY 20X4 USB
LK204-25-USB-E 数据手册
LK204-25 Including LK204-25-422, LK204-25-USB. Technical Manual Revision 2.1 PCB Revision: 3.0 or Higher Firmware Revision: 7.3 or Higher Revision History Revision 2.1 2.0 1 Date January 4, 2018 January 8, 2016 Description Correction to Set Non-Standard Baud Rate command LKVK manual separated into individual manuals Author Divino Divino Contents Revision History ............................................................................................................................................ 1 Contents ........................................................................................................................................................ 2 Introduction .................................................................................................................................................. 4 Quick Connect Guide .................................................................................................................................... 5 Standard Module ...................................................................................................................................... 5 Recommended Parts ............................................................................................................................. 5 Serial Connections................................................................................................................................. 6 I2C Connections ..................................................................................................................................... 7 USB Module .............................................................................................................................................. 8 Recommended Parts ............................................................................................................................. 8 USB Connections ................................................................................................................................... 9 RS422 Module ......................................................................................................................................... 10 RS422 Connections ............................................................................................................................. 10 Software ...................................................................................................................................................... 11 Hyperterminal ......................................................................................................................................... 11 uProject ................................................................................................................................................... 12 Application Notes.................................................................................................................................... 12 Hardware .................................................................................................................................................... 13 Standard Model ...................................................................................................................................... 13 Communication/Power Header .......................................................................................................... 13 Serial DB9 Connector .......................................................................................................................... 13 Power Through DB9 Jumper ............................................................................................................... 14 Protocol Select Jumpers ...................................................................................................................... 14 USB Model .............................................................................................................................................. 15 Mini USB Connector ............................................................................................................................ 15 Alternate USB Header ......................................................................................................................... 15 Alternate Power Connector ................................................................................................................ 15 RS422 Model ........................................................................................................................................... 16 RS422 Header ...................................................................................................................................... 16 Alternate Power Connector ................................................................................................................ 16 Common Features................................................................................................................................... 17 2 General Purpose Outputs ................................................................................................................... 17 Dallas One-Wire Connector ................................................................................................................ 17 Keypad Header .................................................................................................................................... 18 Power ...................................................................................................................................................... 19 Display ..................................................................................................................................................... 19 Communication ....................................................................................................................................... 20 Manual Override ..................................................................................................................................... 20 Commands .................................................................................................................................................. 21 1. Communications ............................................................................................................................. 21 2. Text ................................................................................................................................................. 22 3. Special Characters ........................................................................................................................... 24 4. General Purpose Output ................................................................................................................. 27 5. Dallas One-Wire .............................................................................................................................. 28 6. Keypad............................................................................................................................................. 29 7. Display Functions ............................................................................................................................ 31 8. Data Security ................................................................................................................................... 32 9. Miscellaneous ................................................................................................................................. 33 Appendix ..................................................................................................................................................... 34 Command Summary ............................................................................................................................... 34 Character Sets ......................................................................................................................................... 36 Block Diagram ......................................................................................................................................... 37 Environmental Specifications.................................................................................................................. 37 Electrical Tolerances ............................................................................................................................... 38 Optical Characteristics ............................................................................................................................ 38 Dimensional Drawings ............................................................................................................................ 39 Ordering ...................................................................................................................................................... 41 Part Numbering Scheme ......................................................................................................................... 41 Options .................................................................................................................................................... 41 Accessories .............................................................................................................................................. 42 Definitions ................................................................................................................................................... 44 Contact ........................................................................................................................................................ 44 3 Introduction Figure 1: LK204-25 Display The LK204-25 is an intelligent alphanumeric liquid crystal display designed to decrease development time by providing an instant solution to any project. In addition to the RS232, TTL and I2C protocols available in the standard model, USB and RS422 communication models allow the LK204-25 to be connected to a wide variety of host controllers. Communication speeds of up to 115.2kbps for serial protocols and 100kbps for I2C ensure lightning fast data display. The simple command structure permits easy software control of many settings including backlight brightness, screen contrast, and baud rate. On board memory provides up to forty custom characters which can be saved within the unit and recalled for start screens, bar graphs or larger numbers. User input is available through a five by five matrix style keypad, and six general purpose outputs provide simple switchable five volt sources. In addition, a Dallas One-Wire header provides a convenient communication interface for up to thirty-two devices. The versatile LK204-25, with all the features mentioned above, is available in a variety of colour, voltage, and temperature options to suit almost any application. 4 Quick Connect Guide Standard Module Table 1: Standard Headers # 1 2 3 4 Header Communication/Power DB9 Keypad GPO 5 Dallas One-Wire Mate SCCPC5V/BBC CSS1FT/CSS4FT KPP4x4 None Offered Temperature Probe Figure 2: Standard Connections The standard version of the LK204-25 allows for user configuration of three common communication protocols. First, the unit can communicate using serial protocol at either RS323 or TTL voltage levels. Second, it can communicate using the Inter-Integrated Circuit, or I2C protocol. Connections for each protocol can be accessed through the four pin Communication/Power Header as outlined in the Serial Connections and I2C Connections sections below. Recommended Parts The most common cable choice for any standard Matrix Orbital display, the Communication/Power Cable offers a simple connection to the unit with familiar interfaces. DB9 and floppy power headers provide all necessary input to drive your display. Figure 3: Communication/Power Cable (SCCPC5V) For a more flexible interface to the LK204-25, a Breadboard Cable may be used. This provides a simple four wire connection that is popular among developers for its ease of use in a breadboard environment. Figure 4: Breadboard Cable (BBC) 5 Serial Connections The serial interface provides a classic connection to the LK204-25. The Communication/Power Cable is most commonly used for this set up as it provides connections for DB9 serial and floppy power cables. To place your board in serial mode, adhere to the steps laid out below. 1. Set the Protocol Select Jumpers.  RS232: Connect the three jumpers* in the 232 protocol box with the zero ohm jumper resistors provided or an alternate wire or solder solution.  TTL: Connect the two jumpers* in the TTL protocol box. *Note: Jumpers must be removed from all protocol boxes save for the one in use. 2. Make the connections. a. Connect the four pin female header of the Communication/Power Cable to the Communication/Power Header of your LK204-25. b. Insert the male end of your serial cable to the corresponding DB9 header of the Communication/Power Cable and the mate the female connector with the desired communication port of your computer. c. Select an unmodified floppy cable from a PC power supply and connect it to the power header of the Communication/Power Cable. 3. Create.  uProject or hyperterminal will serve to get you started, and then move on with your own development. Instructions for the former can be found below and a variety of application notes are available for the latter at www.matrixorbital.ca/appnotes. 6 I2C Connections A more advanced connection to the LK204-25 is provided by the I2C protocol setting. This is best accomplished using a breadboard and the Breadboard Cable. Power must be supplied from your breadboard or another external source. To dive right into your application and use the LK204-25 in I2C mode, get started with the guidelines below. 1. Set the Protocol Select switches.  I2C: Ensure that the two I2C jumpers in the corresponding protocol box are connected while all others are open. 2. Make the connections. a. Connect the Breadboard Cable to the Communication/Power Header on your LK204-25 and plug the four leads into your breadboard. The red lead will require power, while the black should be connected to ground, and the green and yellow should be connected to your controller clock and data lines respectively. b. Pull up the clock and data lines to five volts using a resistance between one and ten kilohms on your breadboard. 3. Create.  This time you're on your own. While there are many examples within the Matrix Orbital AppNote section, www.matrixorbital.ca/appnotes, too many controllers and languages exist to cover them all. If you get stuck in development, it is possible to switch over to another protocol on the standard board, and fellow developers are always on our forums for additional support. 7 USB Module Table 2: Standard Headers Figure 5: USB Connections # Header 1 Mini USB 2 3 4 5 6 Alternate USB Alternate Power Keypad GPO Dallas One-Wire Mate EXTMUSB3FT/ INTMUSB3FT None Offered PCS KPP4x4 None Offered Temperature Probe The LK204-25-USB offers a single USB protocol for easy connection to a host computer. The simple and widely available protocol can be accessed using the on board mini B style USB connector as outlined in the USB Connections section. Recommended Parts The External Mini USB cable is recommended for the LK204-25-USB display. It will connect to the miniB style header on the unit and provide a connection to a regular A style USB connector, commonly found on a PC. Figure 6: External Mini USB Cable (EXTMUSB3FT) 8 USB Connections The USB connection is the quickest, easiest solution for PC development. After driver installation, the LK204-25-USB will be accessible through a virtual serial port, providing the same result as a serial setup without the cable hassle. To connect to your LK204-25-USB, please follow the steps below. 1. Set the Protocol Select Jumpers.  USB: The LK204-25-USB offers USB protocol only. Model specific hardware prevents this unit from operating in any other protocol, and does not allow other models to operate in the USB protocol. Protocol Select Jumpers on the USB model cannot be moved. 2. Make the connections.  Plug the mini-B header of your External Mini USB Cable into your LK204-25-USB and the regular USB header into your computer USB jack. 3. Install the drivers. a. Download the latest drivers at www.matrixorbital.ca/drivers, and save them to a known location. b. When prompted, install the USB bus controller driver automatically. c. If asked, continue anyway, even though the driver is not signed. d. When the driver install is complete, your display will turn on, but communication will not yet be possible. e. At the second driver prompt, install the serial port driver automatically. f. Again, if asked, continue anyway. 4. Create.  Use uProject or hyperterminal to get started, and then move on with your own development. Instructions for the former can be found below and a number of application notes are available for the latter at www.matrixorbital.ca/appnotes. 9 RS422 Module Table 3: Standard Headers # 1 2 3 4 5 Header RS422 Alternate Power Keypad GPO Dallas One-Wire Mate 16-30 AWG Wire PCS KPP4x4 None Offered Temperature Probe Figure 7: RS422 Connections The LK204-25-422 provides an industrial alternative to the standard RS232 communication protocol. Rather than single receive and transmit lines, the RS422 model uses a differential pair for each of the receive and transmit signals to reduce degradation and increase transmission lengths. Power can be transmitted at distance to a -VPT module or supplied from the immediate vicinity to a regular or -V unit. RS422 signals are available in a six pin connector as described in the RS422 Connections section. RS422 Connections The LK204-25-422 provides a robust RS422 interface to the display line. For this interface, a series of six wires are usually screwed into the RS422 terminal block provided. An alternate header is also available to provide local power to a regular or -V unit. To connect to your LK204-25-422, follow the steps below. 1. Set the Protocol Select Jumpers.  RS422: The LK204-25-422 offers only RS422 protocol and does not require any jumper changes. 2. Make the connections. a. Screw one wire; sized 16 to 30 on the American Wire Gauge, into each of the six terminal block positions. When local power is supplied, a floppy cable may link to the alternate power header. b. Connect the Vcc wire to the positive terminal of your power supply and the GND terminal to the negative or ground lead to provide appropriate power as in Table 43. c. Secure the A and B wires to your non-inverting and inverting output signals respectively, while attaching the Z and Y wires to your inverting and non-inverting inputs. 3. Create.  In a PC environment, uProject or hyperterminal will serve to get you started. In addition, a variety of application notes are also available in a number of different languages to aid in development. Instructions for the former can be found below and the simple C# example at www.matrixorbital.ca/appnotes is a great first reference for the latter. 10 Software The multiple communication protocols available and simple command structure of the LK204-25 means that a variety of applications can be used to communicate with the display. Text is sent to the display as a character string, for example, sending the decimal value 41 will result in an 'A' appearing on the screen. A number of control characters are also activated. Commands are merely values prefixed with a special command byte, 254 in decimal. While many software programs are available to communicate with the LK204-25, a number of more common samples are detailed in depth below. Table 4: Reserved Control Characters 8 Backspace 10 Control Characters Line feed / New line 12 Clear screen / New page 13 Carriage return Hyperterminal Installed on most Windows computers, hyperterminal can be run by selecting run and typing 'hypertrm' in the command line. This basic program will allow communication between a PC and your display. When starting up, a name must be given to your connection, and an icon may be chosen, neither is consequential. Next, it's important to select the appropriate communication port to which your display is connected. Finally, the settings below must be entered to complete the port setup. Table 5: Hyperterminal Settings BPS 19200 Data Bits 8 Parity None Stop Bits 1 Flow Control None Once a port is successfully set up, data can be sent to an attached display by typing on the keyboard. At this point, it may be helpful to echo keys to the monitor by selecting properties from the file menu and opening the ASCII settings from settings tab. Commands can be sent to an attached display by issuing decimal commands using the number pad. While the ALT key is held down, four digit decimal values can be sent as a single ASCII character. For example, to clear the screen, try the following sequence. ALT +0254 ALT +0088 Figure 8: Hyperterminal Command Any commands or text desired can be sent to the communication port using this method to provide total control of any Matrix Orbital display. 11 uProject The Matrix Orbital alphanumeric display tuner, or uProject, is offered as a free download from the www.matrixorbital.ca support site. It allows the basic functionality of any display* to be tested using a simple graphical user interface system. While basic functionality can be tested using the GUI portion of the program, more advanced users will enjoy the scripting capability found in the uploader tab. Here commands can be stacked, run, and saved for later use. Although many commands are available to be dragged into the script dialog, perhaps the most powerful is the raw data command found in the other branch. This command allows raw bytes to be sent to the display, permitting many different formats for entry and displaying in decimal notation. Any command from this manual may be entered in decimal notation separated by slashes. /254/ /88/ Figure 9: uProject Command Again, the clear screen command is sent to a connected display, this time using uProject raw data command style. Scripts can be run as a whole using the execute command from the script menu, or as single commands by selecting execute once. Before issuing commands, it is a good idea to ensure communication with a display is successful using some of the more basic GUI functions in the main window. This program provides scratch pad upon which a tome of display projects and ideas can be assembled. *Note: The uProject AutoDetect function will not perform correctly when a USB display is connected. Please manually configure any USB display. Application Notes Full demonstration programs and code are available for Matrix Orbital displays in the C# language from Simple C# AppNote Pack in the Matrix Orbital Application Note section at www.matrixorbital.ca/appnotes. Difficulty increases from beginner, with the Hello World program, to advanced with the Dallas One-Wire temperature reading application. Many additional applications are available in a number of different programming languages. These programs are meant to showcase the capability of the display and are not intended to be integrated into a final design. For additional information regarding code, please read the On Code document also found on the support site. 12 Hardware Standard Model Communication/Power Header Table 6: Communication/Power Pinout Figure 10: Communication/Power Header Pin 1 2 3 4 Function Vcc Rx (SCL) Tx (SDA) Gnd The Communication/Power Header provides a standard connector for interfacing to the LK204-25. Voltage is applied through pins one and four of the four pin Communication/Power Header. Please ensure the correct voltage input for your display by referencing the electrical specifications in Table 43 before connecting power. Pins two and three are reserved for serial transmission, using either the RS232/TTL or clocking data through the I²C protocol, depending on what has been selected by the Protocol Select Jumpers. The versatile Tyco 640456-4-LF style header employed here can be mated to a wide array of female connectors for a perfect fit in any project. Serial DB9 Connector Table 7: Serial DB9 Pinout Pin 5 3 2 9 Function Gnd Rx Tx NC/Vcc* Figure 11: Serial DB9 Connector The LK204-25 provides a DB-9 Connector to readily interface with serial devices using EIA232 standard signal levels. It is also possible to communicate at TTL levels of 0 to +5V by setting the Protocol Select Jumpers to TTL. As an added feature it is also possible to apply power through pin 9 of the DB-9 Connector in order to reduce cable clutter. A standard male DB9 header will provide the perfect mate for this connector. *Note: Do not apply voltage through pin 9 of the DB-9 Connector AND through the Communication/Power Header at the same time. 13 Power Through DB9 Jumper In order to provide power through pin 9 of the DB-9 Connector you must connect the Power Through DB-9 Jumper labelled R17, as illustrated below. This connection can be made using a zero ohm resistor, recommended size 0603, or a solder bridge. The LK204-25 allows all voltage models to use the power through DB-9 option, see the electrical specifications in Table 43 for voltage requirements. Power Through DB9 Jumper Protocol Select Jumpers The Protocol Select Jumpers provide the means necessary to toggle the standard LK204-25 model between RS-232, TTL and I²C protocols. As a default, the jumpers are set to RS-232 mode with solder jumps on the 232 jumpers. In order to place the display module in I²C mode you must first remove the solder jumps from the 232 jumpers and then place them on the I2C jumpers. The display will now be in I²C mode and have a default slave address of 0x50, unless it has been changed. Similarly, in order to change the display to TTL mode, simply remove the zero ohm resistors from the 232 or I²C jumpers and solder them to the TTL jumpers. Protocol tables are shown below where an `X` designates a connected jump while an ‘O’ signifies an open connection. Table 8: RS232 Protocol Settings RS232 X X X TTL 0 0 2 IC 0 0 Table 9: TTL Protocol Settings RS232 O O O TTL X X 2 IC O O 2 Table 10: I C Protocol Settings RS232 O O O TTL O O 2 IC X X 14 USB Model Mini USB Connector Table 11: Mini USB Pinout Figure 12: Mini USB Connector Pin 1 2 3 5 Function Vcc DD+ Gnd The LK204-25-USB comes with a familiar Mini USB Connector to fulfill both communication and power needs. The standard MiniB style header can be connected to any other USB style using the appropriate cable. Most commonly used with a PC, this connection creates a virtual com port that offers a simple power solution with a familiar communication scheme. Alternate USB Header Table 12: Alternate USB Pinout Figure 13: Alternate USB Header Pin 1 2 3 4 Function Vcc D+ DGnd Some advanced applications may prefer the straight four pin connection offered through the Optional Alternate USB Header. This header offers power and communication access in a simple interface package. The Optional Alternate USB Header may be added to the LK204-25-USB for an added charge as part of a custom order. Please use the Contact section to request more information from the friendly Matrix Orbital sales team. Alternate Power Connector Table 13: Alternate Power Pinout Figure 14: Alternate Power Connector Pin 1 2 3 4 Function NC Gnd Gnd Vcc The Alternate Power Connector provides the ability to power the LK204-25-USB using a second cable. The Tyco 171825-4 style header is particularly useful for connecting to an unmodified floppy power cable from a PC power supply for a simple bench power solution. 15 RS422 Model RS422 Header Table 14: RS422 Pinout Figure 15: RS422 Header Pin 1 2 3 4 5 6 Function Gnd Rx (Y) Inv Rx (Z) Inv Tx (B) Tx (A) Vcc The six pin RS422 interface header of the LK204-25-422 offers power and ground connections as well as two differential pair communication lines. Regular and inverted lines are provided for both receive and transmit signals. Power is supplied locally to the regular or –V variants while the –VPT can receive power over a distance. The Tyco 282834-6 style header is most suited to a simple wire connection. Alternate Power Connector Table 15: Alternate Power Pinout Figure 16: Alternate Power Connector Pin 1 2 3 4 Function NC Gnd Gnd Vcc The Alternate Power Connector provides the ability to power the LK204-25-422 using a second cable. This is particularly useful for the regular or -V modules that are to be powered locally. The Tyco 1718254 style header will fit a floppy power cable from a PC power supply for a simple bench power solution. 16 Common Features General Purpose Outputs Table 16: GPO Pinout Figure 17: GPO Header Pin 1 2 3 4 5 6 7 Function GPO 1 GPO 1 GPO 1 GPO 1 GPO 1 GPO 1 Vcc Pin 8 9 10 11 12 13 14 Function Gnd Gnd Gnd Gnd Gnd Gnd Gnd A unique feature of the LK204-25 is the ability to control relays* and other external devices using one of six General Purpose Outputs. Each can source up to 20mA of current at five volts when on or sink 10mA at zero volts when off. The two row, fourteen pin header can be interfaced to a number of female connectors to provide control to any peripheral devices required. *Note: If connecting a relay, be sure that it is fully clamped using a diode and capacitor in order to absorb any electro-motive force (EMF) which will be generated. Dallas One-Wire Connector Table 17: Dallas One-Wire Pinout Figure 18: Dallas One-Wire Connector Pin 1 2 3 Function Vcc D Gnd In addition to the six general purpose outputs the LK204-25 offers an Optional Dallas One-Wire bridge, to allow for an additional thirty two one-wire devices to be connected to the display. This header can be populated with a Tyco 173979 connector at an added cost by custom order only. Please use the Contact section to request for more information from the Matrix Orbital sales team. 1.1. 17 Keypad Header Table 18: Keypad Pinout Figure 19: Keypad Header Pin 1 2 3 4 5 6 7 8 9 10 11 12 Function Gnd Row 1 Row 2 Row 3 Row 4 Row 5 Column 1 Column 2 Column 3 Column 4 Column 5 Gnd/Vcc* To facilitate user input, the LK204-25 provides a Keypad Interface Connector which allows a matrix style keypad of up to twenty-five keys to be directly connected to the display module. Key presses are generated when a short is detected between a row and a column. When a key press is generated, a character specific to that key press is automatically sent on the Tx communication line. If the display module is running in I²C mode, the “Auto Transmit Keypress” function may be turned off to allow the key presses to remain in the buffer so that they may be polled. The character that is associated with each key press may also be altered using the “Assign Key Codes” command. The straight twelve pin header of the Keypad Interface Connector will interface to a variety of different devices including the Matrix Orbital KPP4x4 keypad. *Note: The Ground / +5V pin is toggled by the jumper to the right of the keypad connector. Jump pads 1 & 2 for +5V or 2 & 3 for GND. 18 Troubleshooting Power In order for your Matrix Orbital display to function correctly, it must be supplied with the appropriate power. If the D2 power LED near the top right corner of the board is not illuminated, power is not applied correctly. Try following the tips below. • • • • • First, make sure that you are using the correct power connector. Standard floppy drive power cables from your PC power supply may fit on the Communication/Power Header; however they do not have the correct pin out to provide power. Matrix Orbital supplies power cable adapters for connecting to a PC, which can be found in the accessories section. Next, check the power cable which you are using for continuity. If you don't have an ohm meter, try using a different power cable, if this does not help try using a different power supply. If power is applied through the DB9 connector, ensure that the Power Through DB9 Jumper is connected. If changes have been made to the protocol select block, ensure all the appropriate Protocol Select Jumpers are connected and all unused protocol jumpers are disconnected. The last step will be to check the power interface connector in use on your display. If the power connections have become loose, or you are unable to resolve the issue, please contact Matrix Orbital for more information. Display If your display is powered successfully, the Matrix Orbital logo, or user created screen should display on start up. If this is not the case, check out these tips. Ensure the contrast is not too high or too low. This can result in a darkened or blank screen respectively. See the • • 19 Manual Override section to reset to default. Make sure that the start screen is not blank. It is possible to overwrite the Matrix Orbital logo start screen, if this happens the screen may be blank. Try writing to the display to ensure it is functional, after checking the contrast above. Communication When communication of either text or commands is interrupted, try the steps below. • • • • • • • • First, check the communication cable for continuity. If you don't have an ohm meter, try using a different communication cable. If you are using a PC try using a different Com Port. Next, please ensure that the display module is set to communicate on the protocol that you are using, by checking the Protocol Select Jumpers. In serial protocol, ensure that the host system and display module are both communicating on the same baud rate. The default baud rate for the display module is 19200 bps. Match Rx from the LK204-25 to the transmitting pin from your host and the Tx pin to the receiving pin. If you are communicating to the display via I²C* please ensure that the data is being sent to the correct address. The default slave address for the display module is 80. In I2C mode, connect Rx to the data line of your controller and Tx to the data output. Unlock the display. See the Set and Save Data Lock command for more info. Finally, you may reset the display to its default settings using the Manual Override procedure outlined below. *Note: I²C communication will always require pull up resistors on SCL and SDA of one to ten kilohms. Manual Override Should the settings of your display become altered in a way that dramatically impacts usability, the default settings can be temporarily restored. To override the display, please follow the steps below. 1. Disconnect power from your display. 2. Place a jumper on the middle two pins of the keypad header, R5 and C1. 3. Reconnect power to your unit, and wait for the start screen before removing the override jumper. 4. Settings will be temporarily** overridden to the defaults listed in the Manual Override Settings table. At this point any important settings, such as contrast, backlight, or baud rate, should not only be set but saved so they remain when the override is removed. Parameter Backlight Contrast Baud Rate 2 I C Address Value 255 128 19200 80 Table 19: Manual Override Settings **Note: The display module will revert back to the old settings once turned off, unless desired settings are saved. 20 Commands 1. Communications 1.1. Changing the I2C Slave Address Dec 254 51 Address Hex FE 33 Address ASCII ■ 3 Address Immediately changes the I2C write address. Only even values are permitted as the next odd address will become the read address. Default is 80. Address 1 byte, even value 1.2. Changing the Baud Rate Dec 254 57 Speed Hex FE 39 Speed ASCII ■ 9 Speed Immediately changes the baud rate. Not available in I2C. Baud rate can be temporarily forced to 19200 by a manual override. Speed 1 byte, valid settings shown below Table 20: Accepted Baud Rate Values Rate Speed 1200 83 2400 41 4800 207 9600 103 19200 51 28800 34 38400 25 57600 16 115200 8 1.3. Set a Non-Standard Baud Rate Dec 254 164 Speed Hex FE A4 Speed ASCII ■ ñ Speed Immediately changes the baud rate to a non-standard value. Baud must be a whole number between 977 and 153800. Due to rounding, error increases with baud rate, actual baud must be within 3% of desired baud to ensure accurate communication. Not available in I2C. Can be temporarily forced to 19200 by a manual override. Speed Calculations shown below, standard crystal speed is 16MHz. 𝑆𝑝𝑒𝑒𝑑 = 𝐶𝑟𝑦𝑠𝑡𝑎𝑙𝑆𝑝𝑒𝑒𝑑 −1 (8 × 𝐷𝑒𝑠𝑖𝑟𝑒𝑑𝐵𝑎𝑢𝑑) Equation 1: Speed Byte Calculation 𝐴𝑐𝑡𝑢𝑎𝑙𝐵𝑎𝑢𝑑 = 𝐶𝑟𝑦𝑠𝑡𝑎𝑙𝑆𝑝𝑒𝑒𝑑 (8 × (𝑆𝑝𝑒𝑒𝑑 + 1)) Equation 2: Actual Baud Rate Calculation |𝐷𝑒𝑠𝑖𝑟𝑒𝑑𝐵𝑎𝑢𝑑 − 𝐴𝑐𝑡𝑢𝑎𝑙𝐵𝑎𝑢𝑑| < 0.03 𝐷𝑒𝑠𝑖𝑟𝑒𝑑𝐵𝑎𝑢𝑑 Equation 3: Baud Rate Error Calculation 1.4. Transmission Dec 254 160 Protocol Protocol Select Hex FE A0 Protocol Selects the protocol used for data transmission from the display. Data transmission to the display is not affected. Must be set to the protocol in use to receive data correctly. Protocol 1 byte, 1 for Serial (RS232/RS422/TTL/USB) or 0 for I2C 21 2. Text 2.1. Auto Scroll On Dec 254 81 Hex FE 51 ASCII ■Q The entire contents of screen are shifted up one line when the end of the screen is reached. Default is on. 2.2. Auto Scroll Off Dec 254 82 Hex FE 52 ASCII ■R New text is written over the top line when the end of the screen is reached. Default is Auto Scroll on. 2.3. Clear Screen Dec 254 88 Hex FE 58 ASCII ■X Clears the contents of the screen. 2.4. Changing the Start Up Screen Dec 254 64 Characters Hex FE 40 Characters ASCII ■ @ Characters Changes the message displayed on start up. Custom characters can be included by adding their decimal value (07). Characters will automatically wrap on the display. Characters 80 bytes, space characters can be added as needed 2.5. Set Auto Line Wrap On Dec 254 67 Hex FE 43 ASCII ■C Text will wrap to the next consecutive line once a row becomes full. Default is Auto Line Wrap on. 2.6. Set Auto Line Wrap Off Dec 254 68 Hex FE 44 ASCII ■D Text will skip one line when wrapping once a row becomes full. Writing order will be rows 1, 3, 2, and then 4. Default is Auto Line Wrap on. 22 2.7. Set Cursor Position Dec 254 71 Column Row Hex FE 47 Column Row ASCII ■ G Column Row Sets the cursor to a specific position where the next transmitted character is printed. Column 1 byte, value between 1 and 20 Row 1 byte, value between 1 and 4 2.8. Go Home Dec 254 72 Hex FE 48 ASCII ■H Returns the cursor to the top left of the screen. 2.9. Move Cursor Back Dec 254 76 Hex FE 4C ASCII ■L Moves cursor one position to the left. Cursor will obey wrap settings. 2.10. Move Cursor Forward Dec 254 77 Hex FE 4D ASCII ■M Moves cursor one position to the right. Cursor will obey wrap settings. 2.11. Underline Cursor On Dec 254 74 Hex FE 4A ASCII ■J Displays a line under the current cursor position. Can be used with block cursor. 2.12. Underline Cursor Off Dec 254 75 Hex FE 4B ASCII ■K Removes line under current cursor position. 2.13. Blinking Block Cursor On Dec 254 83 Hex FE 53 ASCII ■S Displays a blinking block over the current cursor position. Can be used with underline. 2.14. Blinking Block Cursor Off Dec 254 84 Hex FE 54 ASCII ■T Removes blinking block over current cursor position. 23 3. Special Characters 3.1. Creating a Custom Character Dec 254 78 ID Data Hex FE 4E ID Data ASCII ■ N ID Data Creates a custom character. Each character is divided into 8 rows of 5 pixels; each data byte represents one row. Each byte is padded by three zero bits followed by five bits representing each pixel state. A one represents an on condition while a zero is off. Characters are lost when a new memory bank is loaded, unless they are saved. ID 1 byte, character ID, value between 0 and 7 Data 8 bytes, character pixel data as shown below Table 21: Custom Degree Character Data1 000 p1 p2 p3 p4 p5 00001000 8 Data2 000 p1 p2 p3 p4 p5 00010100 20 Data3 000 p1 p2 p3 p4 p5 00001000 8 Data4 000 p1 p2 p3 p4 p5 00000011 3 Data5 000 p1 p2 p3 p4 p5 00000100 4 Data6 000 p1 p2 p3 p4 p5 00000100 4 Data7 000 p1 p2 p3 p4 p5 00000011 3 Data8 000 p1 p2 p3 p4 p5 00000000 0 3.2. Saving Custom Dec 254 193 Bank ID Data Characters Hex FE C1 Bank ID Data Provides access to all memory banks to create and save custom characters, graph bars, and large digits. Any new characters saved will overwrite the old, so care should be taken when writing to any bar or digit memory bank. Bank structure is shown below. Bank 1 byte, memory bank ID, value between 0 and 4 ID 1 byte, value between 0 and 7 Data 8 bytes, character pixel data as above Table 22: Custom Character Banks 0 Start-up Characters 1 Horizontal Bars 2 Vertical Bars 3 Medium Digits 4 Large Digits 3.3. Loading Custom Dec 254 192 Bank Characters Hex FE C0 Bank Loads a bank of custom characters into memory for use. Must be issued before using a bank of characters. Alternatively, an appropriate initialize command can be used. Bank 1 byte, memory bank ID, value between 0 and 4 24 3.4. Save Start Up Screen Dec 254 194 ID Data Custom Characters Hex FE C2 ID Data Saves a custom character to memory for the start up screen or repeated use. Start up characters are displayed by sending their ID to the screen. ID 1 byte, value between 0 and 7 Data 8 bytes, character pixel data, see custom character example 3.5. Initialize Medium Number Dec 254 109 Hex FE 6D ASCII ■m Loads the medium number custom character bank into memory. Medium numbers must be initialized before use. 3.6. Place Medium Numbers Dec 254 111 Row Column Digit Hex FE 6F Row Column Digit ASCII ■ o Row Column Digit Places a single medium decimal digit of 2 row height and 1 column width on the display at the position specified. Medium numbers must be initialized before being placed. Row 1 byte, value between 1 and 20 Column 1 byte, value between 1 and 4 Digit 1 byte, single decimal digit to display 3.7. Initialize Large Numbers Dec 254 110 Hex FE 6E ASCII ■n Loads the large number custom character bank into memory. Large numbers must be initialized before use. 3.8. Place Large Number Dec 254 35 Column Digit Hex FE 23 Column Digit ASCII ■ # Column Digit Places a single large decimal digit, 4 rows in height and 3 columns in width, on the display at the position specified. Medium numbers must be initialized before being placed. Column 1 byte, value between 1 and 20 Digit 1 byte, single decimal digit to display 3.9. Initialize Horizontal Bar Dec 254 104 Hex FE 68 ASCII ■h Loads the horizontal bar graph custom character bank into memory. Horizontal bar characters must be initialized before a graph is displayed. 25 3.10. Place Horizontal Dec 254 124 Column Row Direction Length Bar Graph Hex FE 7C Column Row Direction Length Places a horizontal bar graph on the screen beginning at the column and row specified. The bar extends either right or left to the length indicated. New bars will overwrite old. Column 1 byte, value between 1 and 20 Row 1 byte, value between 1 and 4 Direction 1 byte, 0 for right and 1 for left Length 1 byte, length in pixels of the graph, value between 0 and 100 3.11. Initialize Narrow Vertical Bar Dec 254 115 Hex FE 73 ASCII ■s Loads the narrow horizontal bar graph custom character bank into memory. A narrow bar is 2 pixels wide. Horizontal bar characters must be initialized before a graph is displayed. 3.12. Initialize Dec 254 118 Wide Hex FE 76 Vertical Bar ASCII ■v Loads the wide horizontal bar graph custom character bank into memory. A wide bar is 5 pixels wide. Horizontal bar characters must be initialized before a graph is displayed. 3.13. Place Vertical Bar Dec 254 61 Column Length Hex FE 3D Column Length ASCII ■ = Column Length Places a vertical bar graph on the screen extending from the first row of the column specified. The bar extends upwards to the length indicated. A new bar will over write the old. Column 1 byte, value between 1 and 20 Length 1 byte, height in pixels of the graph, value between 0 and 32 26 4. General Purpose Output 4.1. General Purpose Output Off Dec 254 86 Number Hex FE 56 Number ASCII ■ V Number Turns the specified GPO off, sinking current to an output of zero volts. Number 1 byte, GPO to be turned off, value between 1 and 6 4.2. General Purpose Output On Dec 254 87 Number Hex FE 57 Number ASCII ■ W Number Turns the specified GPO on, sourcing current from an output of five volts. Number 1 byte, GPO to be turned on, value between 1 and 6 4.3. Set Start Up Dec 254 195 Number State GPO State Hex FE C3 Number State Sets and saves the start up state of the specified GPO in non volatile memory. Changes will be seen on start up. Number 1 byte, GPO to be controlled, value between 1 and 6 State 1 byte, 1 for on or 0 for off 27 5. Dallas One-Wire 5.1. Search for a One-Wire Dec 254 200 2 Device Hex FE C8 02 Sends a search query to each of the up to 32 devices on the one wire bus. Any connected device will respond with an identification packet. Response 14 bytes, identification packet as shown below Table 23: Dallas One-Wire Packet Information Offset 0 2 Length 2 1 3 4 5 13 1 1 8 1 Value 9002 138 10 49 0 0 Description Preamble Another device packet will follow OR Last device packet Packet Type Error Code (0 indicates success) Device Address CRC8 address check (0 indicates validity) 5.2. Dallas One-Wire Dec 254 200 1 Flags Send Bits Receive Bits Data Transaction Hex FE C8 01 Flags Send Bits Receive Bits Data Performs a single Dallas 1-Wire transaction. Consult your device documentation for information regarding device specific protocols. If an error is encountered, a corresponding value will be returned by the device. Flags 1 byte, flags for transaction, see below Send Bits 1 byte, number of bytes to be sent to the device Receive Bits 1 byte, number of bytes expected to be received from the device Data Variable, data to be transmitted LSB to MSB Table 24: Dallas One-Wire Flag Table Bit 7 6 5 4 3 2 1 0 Flag Description Unused 0 (Future Compatibility) Add CRC8 to transaction 0 (Future Compatibility) Read CRC8 from transaction Reset Bus prior to transaction Table 25: Dallas One-Wire Error Table Code 0 1 2 3 Error Description Success Unknown Command No Devices Found Fatal Search Error 28 6. Keypad 6.1. Auto Transmit Key Presses On Dec 254 65 Hex FE 41 ASCII ■A Key presses are automatically sent to the host when received by the display. Default is Auto Transmit on. 6.2. Auto Transmit Key Presses Off Dec 254 79 Hex FE 4F ASCII ■O Key presses are held in the 10 key buffer to be polled by the host using the Poll Key Press command. Use this mode for I2C transactions. Default is Auto Transmit on. 6.3. Poll Key Press Dec 254 38 Hex FE 26 ASCII ■& Reads the last unread key press from the 10 key display buffer. If another key is stored in the buffer the MSB will be 1, the MSB will be 0 when the last key press is read. If there are no stored key presses a value of 0 will be returned. Auto transmit key presses must be turned off for this command to be successful. Response 1 byte, value of key pressed (MSB determines additional keys to be read) 6.4. Clear Key Buffer Dec 254 69 Hex FE 45 ASCII ■E Clears all key presses from the key buffer. 6.5. Set Debounce Time Dec 254 85 Time Hex FE 55 Time ASCII ■ U Time Sets the time between a key press and a key read by the display. Most switches will bounce when pressed; the debounce time allows the switch to settle for an accurate read. Default is 8 representing a debounce time of approximately 52ms. Time 1 byte, debounce increment (debounce time = Time * 6.554ms) 29 6.6. Set Auto Repeat Dec 254 126 Mode Mode Hex FE 7E Mode Sets key press repeat mode to typematic or hold. In typematic mode if a key press is held, the key value is transmitted immediately, then 5 times a second after a 1 second delay. In hold mode, the key down value is transmitted once when pressed, and then the key up value is sent when the key is released. Default is typematic. Mode 1 byte, 1 for hold mode or 0 for typematic 6.7. Auto Repeat Dec 254 96 Mode Off Hex FE 60 Turns auto repeat mode off. Default is on (typematic). 6.8. Assign Keypad Dec 254 213 Key Down Key Up Codes Hex FE D5 Key Down Key Up Assigns the key down and key up values sent to the host when a key press is detected. A key up and key down value must be sent for every key, a value of 255 will leave the key unaltered. Defaults are shown below. Key Down 25 bytes, key down values Key Up 25 bytes, key up values Table 26: Default Key Down Values Table 27: Default Key Up Values Key Down B(66) C(67) D(68) G(71) H(72) I(73) L(76) M(77) N(78) Q(81) R(82) S(83) V(86) W(87) X(88) Key Up c(99) h(104) m(109) r(114) w(119) A(65) F(70) K(75) P(80) U(85) E(69) J(74) O(79) T(84) Y(89) a(97) f(102) k(107) p(112) u(117) b(98) g(103) l(108) q(113) v(118) d(100) i(105) n(110) s(115) x(120) e(101) j(106) o(111) t(116) y(121) 6.9. Set Typematic Delay Dec 254 159 Delay Hex FE 9F Delay ASCII ■ ƒ Delay Sets the delay between the first key press and first typematic report when a key is held in typematic mode. Delay 1 byte Time key must be held to trigger typematic reports, specified in 100ms, default is 10 (1s). 6.10. Set Dec 254 158 Interval Typematic Hex FE 9E Interval Interval ASCII ■ ₧ Interval Sets the interval between reported key presses when a key is held and the display is in typematic mode. Interval 1 byte Time between key reports, specified in 100ms increments, default is 2 (200ms). 30 7. Display Functions 7.1. Display On Dec 254 66 Minutes Hex FE 42 Minutes ASCII ■ B Minutes Turns the display backlight on for a specified length of time. If an inverse display color is used this command will essentially turn on the text. Minutes 1 byte, number of minutes to leave backlight on, a value of 0 leaves the display on indefinitely 7.2. Display Off Dec 254 70 Hex FE 46 ASCII ■F Turns the display backlight off. If an inverse display colour is used this command will turn off the text. 7.3. Set Brightness Dec 254 153 Brightness Hex FE 99 Brightness Immediately sets the backlight brightness. If an inverse display color is used this represents the text colour intensity instead. Default is 255. Brightness 1 byte, brightness level from 0(Dim) to 255(Bright) 7.4. Set and Save Dec 254 152 Brightness Brightness Hex FE 98 Brightness Immediately sets and saves the backlight brightness. Although brightness can be changed using the set command, it is reset to the saved value on start up. Default is 255. Brightness 1 byte, brightness level from 0(Dim) to 255(Bright) 7.5. Set Contrast Dec 254 80 Contrast Hex FE 50 Contrast ASCII ■ P Contrast Immediately sets the contrast between background and text. If an inverse display color is used this also represents the text brightness. Default is 128. Contrast 1 byte, contrast level from 0(Light) to 255(Dark) 7.6. Set and Save Dec 254 145 Contrast Contrast Hex FE 91 Contrast Immediately sets and saves the contrast between background and text. Although contrast can be changed using the set command, it is reset to this saved value on start up. Default is 128. Contrast 1 byte, contrast level from 0(Light) to 255(Dark) 31 8. Data Security 8.1. Set Remember Dec 254 147 Switch Hex FE 93 Switch Allows changes to specific settings to be saved to the display memory. Writing to non-volatile memory can be slow and each change consumes 1 write of approximately 100,000 available. The Command Summary outlines which commands are saved always, never, and when this command is on only. Remember is off by default. Switch 1 byte, 1 for on or 0 for off 8.2. Set Data Lock Dec 254 202 245 160 Level Hex FE CA F5 A0 Level Temporarily locks certain aspects of the display to ensure no inadvertent changes are made. The lock is released after a power cycle. A new level overrides the old, and levels can be combined. Default is 0. Level 1 byte, each bit representing a level, see Table 28 Table 28: Data Lock Bits Display 7 Command 6 Reserved 5 Setting 4 Address 3 Reserved 2 Reserved 1 Reserved 0 Table 29: Lock Parameters Reserved Address Setting Command Display Place holders only, should be 0 2 Locks the Baud Rate and I C address Locks all settings from being saved Locks all commands, text can still be written Locks entire display, no new text can be displayed 8.3. Set and Save Dec 254 203 245 160 Level Data Lock Hex FE CB F5 A0 Level Locks certain aspects of the display to ensure no inadvertent changes are made. The lock is not affected by a power cycle. A new level overrides the old, and levels can be combined. Default is 0. Level 1 byte, see data lock table 32 9. Miscellaneous 9.1. Write Customer Data Dec 254 52 Data Hex FE 34 Data ASC ■ 4 Data II Saves a user defined block of data to non-volatile memory. Useful for storing display information for later use. Data 16 bytes, user defined data 9.2. Read Dec 254 53 Customer Hex FE 35 Data ASCII ■5 Reads data previously written to non-volatile memory. Data is only changed when written, surviving power cycles. Response 16 bytes, previously saved user defined data 9.3. Read Version Number Dec 254 54 Hex FE 36 ASCII ■6 Causes display to respond with its firmware version number. Response 1 byte, convert to hexadecimal to view major and minor revision numbers 9.4. Read Module Type Dec 254 55 Hex FE 37 ASCII ■7 Causes display to respond with its module number. Response 1 byte, module number, see partial list below Table 30: Sample Module Type Responses 9 87 89 33 LK204-25 LK204-25-USB LK204-25-422 Appendix Command Summary Available commands below include identifying number, required parameters, the returned response and an indication of whether the setting is remembered always, never, or with remember set to on. Table 31: Communication Command Summary Name Changing the I2C Slave Address Changing the Baud Rate Set a Non-Standard Baud Rate Transmission Protocol Select Dec 51 57 164 160 Hex 33 39 A4 A0 ASCII 3 9 ñ á Parameters Address BaudRate Speed Protocol Response None None None None Remembered Always Always Always Remember On Table 32: Text Command Summary Name Auto Scroll On Auto Scroll Off Clear Screen Changing the Start Up Screen Set Auto Line Wrap On Set Auto Line Wrap Off Set Cursor Position Go Home Move Cursor Back Move Cursor Forward Underline Cursor On Underline Cursor Off Blinking Block Cursor On Blinking Block Cursor Off Dec 81 82 88 64 67 68 71 72 76 77 74 75 83 84 Hex 51 52 58 40 43 44 47 48 4C 4D 4A 4B 53 54 ASCII Q R X @ C D G H L M J K S T Parameters None None None Characters [80] None None Col, Row None None None None None None None Response None None None None None None None None None None None None None None Remembered Remember On Remember On Never Always Remember On Remember On Never Never Never Never Remember On Remember On Remember On Remember On Table 33: Special Character Command Summary Name Creating a Custom Character Saving Custom Characters Loading Custom Characters Save Start Up Screen Custom Characters Initialize Medium Number Place Medium Numbers Initialize Large Numbers Place Large Number Initialize Horizontal Bar Dec 78 193 192 194 109 111 110 35 104 Hex 4E C1 C0 C2 6D 6F 6E 23 68 ASCII N ┴ └ ┬ m o n # h Place Horizontal Bar Graph 124 7C | Initialize Narrow Vertical Bar Initialize Wide Vertical Bar Place Vertical Bar 115 118 61 73 76 3D s v = Parameters ID, Data [8] Bank, ID, Data [8] Bank ID, Data [8] None Row, Col, Digit None Col, Digit None Col, Row, Dir, Length None None Col, Length Response None None None None None None None None None Remembered Remember On Always Never Always Never Never Never Never Never None Never None None None Never Never Never 34 Table 34: General Purpose Output Command Summary Name General Purpose Output Off General Purpose Output On Set Start Up GPO State Dec 86 87 195 Hex 56 57 C3 ASCII V W ├ Parameters Number Number Number, State Response None None None Remembered Never Never Always Table 35: Dallas One-Wire Command Summary Name Search for a One-Wire Device Dallas One-Wire Transaction Dec 200, 2 200, 1 Hex C8, 02 C8, 01 ASCII ╚, ☻ ╚, ☺ Parameters None Flags, Send, Receive, Data [] Response Data [14] Data [] Remembered Never Never Table 36: Keypad Command Summary Name Auto Transmit Key Presses On Auto Transmit Key Presses Off Poll Key Press Clear Key Buffer Set Debounce Time Set Auto Repeat Mode Auto Repeat Mode Off Assign Keypad Codes Set Typematic Delay Set Typematic Interval Dec 65 79 38 69 85 126 96 213 159 158 Hex 41 4F 26 45 55 7E 60 D5 9F 9E ASCII A O & E U ~ ` ╒ ƒ ₧ Parameters None None None None Time Mode None KeyUp [25], KeyDown [25] Delay Delay Response None None KeyPress None None None None None None None Remembered Remember On Remember On Never Never Remember On Remember On Remember On Always Remember On Remember On Table 37: Display Functions Command Summary Name Display On Display Off Set Brightness Set and Save Brightness Set Contrast Set and Save Contrast Dec 66 70 153 152 80 145 Hex 42 46 99 98 50 91 ASCII B F Ö ÿ P æ Parameters Minutes None Brightness Brightness Contrast Contrast Response None None None None None None Remembered Remember On Remember On Remember On Always Remember On Always Table 38: Data Security Command Summary Name Set Remember Set Data Lock Set and Save Data Lock Dec 147 202, 245, 160 203, 245, 160 Hex 93 CA, F5, A0 CB, F5, A0 ASCII ô ╩, ⌡, á ╦, ⌡, á Parameters Switch Level Level Response None None None Remembered Always Remember On Always Table 39: Miscellaneous Command Summary Name Write Customer Data Read Customer Data Read Version Number Read Module Type 35 Dec 52 53 54 55 Hex 34 35 36 37 ASCII 4 5 6 7 Parameters Data [16] None None None Response None Data [16] Version Module Remembered Always Never Never Never Character Sets Figure 20: European Character Set 36 Block Diagram Figure 21: Functional Diagram Environmental Specifications Table 40: Environmental Limits Operating Temperature Storage Temperature Operating Relative Humidity 37 LCD Standard LCD Extended (-E) 0°C to +50°C -20°C to +70°C -10°C to +60°C -30°C to +80°C Maximum 90% non-condensing Electrical Tolerances Current Consumption Table 41: Current Consumption Board 40mA + Backlight 70 to 150 mA + GPOs 20mA each maximum Table 42: Backlight Current Draw YG & IY 135mA R 150mA GW & WB 70mA Input Voltage Specifications Table 43: Voltage Specifications Standard* 4.75-5.25V Wide Voltage (-V)* 9.0-15.0V Extended Wide Voltage (-VPT) 9.0-35.0V *Note: Standard and Wide Voltage variants of the RS422 model should be powered from a local source only. Optical Characteristics Table 44: Display Optics Module Size Viewing Area Active Area Character Size Character Pitch Pixel Size Pixel Pitch Viewing Direction Viewing Angle Contrast Ratio Backlight Half-Life 98.00 x 60.00 x 30.5 76.0 x 25.2 70.4 x 20.8 2.95 x 4.75 3.55 x 5.35 0.55 x 0.55 0.60 x 0.60 12 -30 to +30 3 50,000 mm mm mm mm mm mm mm O’clock ° Hours 38 Dimensional Drawings Figure 22: LCD Dimensional Drawing Figure 23: LK204-25-USB Dimensional Drawing 39 Figure 24: LK204-25-422 Dimensional Drawing 40 Ordering Part Numbering Scheme Table 45: Part Numbering Scheme LK 1 -204 2 -25 3 -R 4 -VPT 5 -422 6 -E 7 Options Table 46: Display Options # Designator 1 Product Type 2 3 Display Size Keypad Size 4 Colour 5 Voltage 6 Protocol 7 Temperature Options LK: Liquid Crystal Display with Keypad Input OK: Organic Light Emitting Diode Display with Keypad Input VK: Vacuum Florescent Display with Keypad Input -204: 20 columns by 4 rows -25: 25 key maximum NP: Standard (YG for LCD) -GW: Grey Text with Grey-White Background -WB: White Text with Blue Background -IY: Yellow-Green Text with Black Background (Inverse Display) -R: Red Text with Black Background (Inverse Display) NP: Standard Voltage -V: Wide Voltage -VPT: Wide Voltage with Efficient Switching Power Supply NP: Standard Model -USB: USB Only Model -422: RS422 Only Model* NP: Standard -E: Extended Temperature *Note: The RS422 model should only be powered from a local source, unless the –VPT variant is used. 41 Accessories Power Table 47: Power Accessories PCS Standard Power Cable Communication Table 48: Communication Accessories CSS4FT 4 ft. Serial Cable EXTMUSB3FT Mini-USB Cable INTMUSB3FT Internal Mini-USB Cable SCCPC5V Serial Communication/5V Power Cable BBC Breadboard Cable 42 Peripherals Table 49: Peripheral Accessories KPP4x4 16 Button Keypad KPP204A-XX* 15 Button Keypad Overlay Temperature Probe Dallas One-Wire Temperature Probe Mounting Table 50: Mounting Accessories B2041-XX** Mounting Bracket with Coloured Overlay B204A-XX* Mounting Bracket with Keyed Overlay MK2041-XX** Coloured Overlay with Drill Guide Note*: Keyed overlays are available in Black Vinyl (-BK) and Beige Vinyl (no part extension). Note**: Non-keyed overlays are available in Black Vinyl (-BK), Black Brushed Aluminum (-BL), Silver Brushed Aluminum (-AL), and Beige Vinyl (no part extension). 43 Definitions ASCII: American standard code for information interchange used to give standardized numeric codes to alphanumeric characters. BPS: Bits per second, a measure of transmission speed. DOW: Dallas One-Wire protocol, similar to I2C, provides reduced data rates at a greater distance. One wire carries data, while two others supply power and ground. Matrix Orbital tests non-parasitic devices only, those that do not draw power from the data line; however, some parasitic devices may work. FFSTN: Double film super-twisted nematic in reference to an LCD. The addition of two layers of film between the STN display and polarizer improves contrast. GPO: General purpose output, used to control peripheral devices from a display. GUI: Graphical user interface. Hexadecimal: A base 16 number system utilizing symbols 0 through F to represent the values 0-15. I2C: Inter-integrated circuit protocol uses clock and data lines to communicate short distances at slow speeds from a master to up to 128 addressable slave devices. A display is a slave device. LSB: Least significant bit or byte in a transmission, the rightmost when read. MSB: Most significant bit or byte in a transmission, the leftmost when read. RS232: Recommended standard 232, a common serial protocol. A low level is -30V, a high is +30V. RS422: Recommended standard 422, a more robust differential pair serial protocol. SDA: Serial data line used to transfer data in I2C protocol. This open drain line should be pulled high through a resistor. Nominal values are between 1K and 10K Ω. SCL: Serial clock line used to designate data bits in I2C protocol. This open drain line should be pulled high through a resistor. Nominal values are between 1K and 10K Ω. STN: Super-twisted nematic in reference to an LCD. In a relaxed or nematic state, crystals orientate themselves in the same direction and pass light. In an excited state these crystals align to block light. Super-twisted crystals move from 180 to 270 degrees between to increase contrast over TN models. TTL: Transistor-transistor logic applied to serial protocol. Low level is 0V while high logic is 5V. Contact Sales Support Online Phone: 403.229.2737 Phone: 403.204.3750 Purchasing: www.matrixorbital.com Email: sales@matrixorbital.ca Email: support@matrixorbital.ca Support: www.matrixorbital.ca 44
LK204-25-USB-E
物料型号:LK204-25,包括LK204-25-422和LK204-25-USB。
器件简介:LK204-25是一款智能液晶显示器,旨在通过提供即时的项目解决方案来减少开发时间。
支持RS232、TTL、I2C协议,并有USB和RS422通信模型,适用于多种主机控制器。
引脚分配:文档中详细列出了不同模块的引脚分配,例如通信/电源头、DB9连接器、USB连接器、RS422头等。
参数特性:支持高达115.2kbps的串行协议通信速度和100kbps的I2C通信速度。
具有简单的命令结构,易于软件控制,包括背光亮度、屏幕对比度和波特率等。
功能详解:包括通用输出、达拉斯一线连接器、键盘头、电源、显示、通信、手动覆盖以及命令集等。
应用信息:LK204-25适用于多种应用场景,提供多种颜色、电压和温度选项。
封装信息:提供了详细的尺寸图纸和订购信息,包括部件编号方案和选项。
LK204-25-USB-E 价格&库存
很抱歉,暂时无法提供与“LK204-25-USB-E”相匹配的价格&库存,您可以联系我们找货
