DSM Series
Ultra Thin Surface Mount
Single Digit 7-Segment LED Display
DSM7UA20101 - 0.20” (5.08mm) Digit Height
Emitting Color: Red (AlGaInP/GaAs)
Applications
• People Movers
• Home Appliances
• Medical Devices
• Industrial Devices
• Automation and Controls
• Light Control
• IoT
• Transportation
• Food Service Appliances
Key Features
• 1-digit seven segment led numeric display
• Outer dimensions: 11.0 x 7.40 x 3.10mm
• Reduce overall thickness of PCB, with
major cost savings
• Available in 4 different digit heights and widths
• Excellent character appearance, with high
light output
• Super bright red chip
• Made from AlGaInP on transparent GaAs
substrate
• Made of white segments and gray surface
• Also available in pure green
• Available in cut tape or automation-friendly
tape and reel
engineered to light up your design
• Exclusive patented technology
• Low current operation and lower power
consumption
• Polarity: common anode
• Available for reverse mounting configuration
• Side by side mounting allows space saving
• Easy mounting on PC boards or sockets
• Moisture Sensitive Level (MSL): 2a
• Life expectancy: 100,000 hours
• Technically and mechanically rugged
• Quality tested with the highest industry
standard
www.vcclite.com
1
1.800.522.5546
09/15 Rev 1
Ordering Data
Series
D
Mounting
Type
SM
Number of
Segments
Thickness Type
7
Digit
Height
Number
of Digits
Color
A
01
U
Series
D
Polarity: Common
Polarity: Common
Display
A
Mounting Type
SM
Packaging
Color
Anode
01
Red
05
Pure Green
Digit Height
SMD
Number of Segments
7
7-Segments
Thickness Type
U
0.20"
30
0.30"
56
0.56"
70
0.70"
Packaging
Cut Tape
T
Tape & Reel
Number of Digits
Ultra Thin
1
1 digit
Dimensions and Internal Circuit Diagram
Dimensions in millimeters [inches]
Tolerance is ±0.25mm [.01”] unless othewise noted
www.vcclite.com
2
1.800.522.5546
09/15 Rev 1
Recommended Reverse Mount Solder Pattern
Reflector
Cut Out
Tolerance is ±0.25mm [.01"] unless otherwise noted
Pin Connections (Common Anode)
PIN No
1
2
3
4
5
6
7
8
9
10
Connection
CATHODE E
CATHODE D
COMMON ANODE
CATHODE C
CATHODE DP
CATHODE B
CATHODE A
COMMON ANODE
CATHODE F
CATHODE G
www.vcclite.com
1.800.522.5546
3
09/15 Rev 1
Product Specifications
Absolute Maximum Rating at Ta=25°C / 77°F (Ta= Ambient Temperature)
Maximum
Rating
Unit
PAD
70
mW
0.28/9.46
mA ˚C / ˚F
Continuous forward current
IAF
25
mA
Peak current (duty cycle 1/10, 1kHz)
I PF
90
mA
R everse voltage
VR
5
V
Operating Temperature
TOPR
-40 TO +105
-40 TO +221
˚C
˚F
Storage temperature
TSTG
-40 TO +105
-40 TO +221
˚C
˚F
Parameter
Symbol
Power dissipation
Derating liner from 25°C/77°F
Electrical - Optical Characteristics at Ta=25˚C / 77˚F (Ta= Ambient Temperature)
Charateristic
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage, (Per Dice)
VF
IF =20mA
2.0
2.6
V
Reverse Current, (Per Dice)
IR
V R =5V
10
µA
P
IF =20mA
632
nm
D
IF =20mA
619
629
nm
IV
IF =20mA
5
25
mcd
IF =20mA
nm
Peak Wavelength
Dominant Wavelength
Luminous Intensity
Spectral radiation bandwidth
www.vcclite.com
4
1.800.522.5546
09/15 Rev 1
FORWARD VOLTAGE VF (V)
FORWARD CURRENT VS. FORWARD VOLTAGE
RELATIVE INTENSITY [ XIV ]
NORMALIZE @ 20 mA
Typical Electro-optical Characteristic Curves
(25˚C / 77°F Free Air Temperature Unless Otherwise Specified)
FORWARD CURRENT IF (mA)
RELATIVE INTENSITY VS. FORWARD CURRENT
RELATIVE INTENSITY [ XIV ] @ 20 mA
NORMALIZE @ 25˚C
FORWARD VOLTAGE @ 20 mA [ XVF ]
NORMALIZE @ 25˚C
FORWARD CURRENT IF = mA
AMBIENT TEMPERATURE Ta (˚C)
RELATIVE INTENSITY VS. TEMPERATURE
MAX. DC CURRENT - mA
@ 20 mA
AMBIENT TEMPERATURE Ta(˚C)
FORWARD VOLTAGE VS. TEMPERATURE
MAX. ALLOWABLE DC CURRENT VS. AMBIENT
TEMPERATURE
WAVELENGTH (nm)
RELATIVE INTENSITY VS. WAVELENGTH
Circuit Design Notes
• Always use current limit resistors when necessary
• LEDs could be electrically connected in parallel, with each LED having its own
current limiting resistor
Correct
Incorrect
www.vcclite.com
1.800.522.5546
5
09/15 Rev 1
Recommended Reflow Soldering Profile
SMT Reflow Soldering Instructions
SMT Soldering Profile
Pb free reflow soldering Profile
TEMPERATURE
≦5 SEC.
255-260 °C
3 °C/SEC.MAX.
217 °C
200 °C
6 °C/SEC.MAX.
150 °C
3 °C/SEC.MAX.
60-120SEC.
100SEC.MAX.
TIME
We recommend the reflow temperature 245˚C / 473˚F (+/- 5˚C / 41˚F).
The maximum soldering temperature should be limited to 260˚C / 500˚F.
Number of reflow process shall be 2 time or less.
Soldering Iron
Basic spec is ≦4 sec when 260˚C / 500˚F. If temperature is higher, time should
be shorter (+10˚C / 50˚F →1 sec). Power dissipation of Iron should be smaller
than 15W, and temperature should be controllable. Surface temperature
of the device should be under 230˚C /446˚F.
Rework
Customer must finish rework within 3 sec. under 350˚C / 662˚F.
The head of soldering iron cannot touch copper foil.
Storage Condition
In factory original sealed bag package
TEMPERATURE CONDITION
HUMIDITY CONDITION
5°C ~ 30°C
Below 60%RH
After opened and not in factory original sealed bag package
STORAGE TIME
TEMPERATURE CONDITION HUMIDITY CONDITION
5°C ~ 30°C
Within 4 weeks (MSL as level 2a)
Below 60%RH
www.vcclite.com
1.800.522.5546
6
09/15 Rev
Tape & Reel Dimensions
7.09
[180.0]
15.00±0.01
[381.0±0.2]
1.47±0.04
[37.0±1.0]
0.07±0.02
[2.0±0.5]
0.41±0.02
[10.5±0.4]
ø0.51±0.02
[ø13.0±0.5]
1.28±0.01
[32.4±0.2]
Dimensions in inches [millimeters]
1350PCS / 1 REEL
Compliance and Approvals
www.vcclite.com
1.800.522.5546
7
09/15 Rev
很抱歉,暂时无法提供与“DSM7UA20101”相匹配的价格&库存,您可以联系我们找货
