COM-13999
COM-13999
    SPARKFUNELECTRONICS
    DIP14
    COM-13999
COM-13999 数据手册
0.56” Tri-color Digit Number Display ACD8143 ADH-Tech ADH-Tech 0.56” Tri-color Digit Number Display ACD8143 Official Product ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. www.adh-tech.com.tw Dec. 30, 2015 Version of 1.0 Page 1/8 sales@adh-tech.com.tw 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech Revision History Revision Page DS original Official Product Version No. Revision Date 1.0 12-30-2015 ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 2/8 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech FEATURES *0.56-inch (14.22 mm) DIGIT HEIGHT *CONTINUOUS UNIFORM SEGMENTS *LOW POWER REQUIREMENT *EXCELLENT CHARACTERS APPEARANCE *HIGH BRIGHTNESS & HIGH CONTRAST *WIDE VIEWING ANGLE *SOLID STATE RELIABILITY *CATEGORIZED FOR LUMINOUS INTENSITY *LEAD-FREE PACKAGE Official Product ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 3/8 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech 0.45 PACKAGE DIMENSIONS NOTES: 1.All dimensions are in millimeters. Tolerances are  0.25mm (0.01“) unless otherwise noted. INTERNAL CIRCUIT DIAGRAM Official Product ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 4/8 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech ABSOLUTE MAXIMUM RATING AT Ta = 25℃ PARAMETER R G B UNIT Power Dissipation Per Segment 150 150 150 mW Continuous Forward Current Per Segment 10 5 5 mA Peak Froward Current 30 15 15 mA Reverse Voltage Per Segment 5 5 5 V Operating Temperature Range -30℃ to +80℃ Storage Temperature Range -40℃ to +100℃ Soldering Conditions:Max 260℃ for max 3sec at 1.6mm below seating plane. Remarks:This product should be operated in forward bias.If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ELECTRICAL / OPTICAL CHARACTERISTICS AT Ta = 25oC RED PARAMETER SYMBOL MIN. TYP. MAX. UNIT Average Luminous Intensity Iv Peak Emission Wavelength 21.7 mcd IF=10mA p 629 nm IF=10mA Spectral Line Half-Width  16 nm IF=10mA Dominant Wavelength d 622 nm IF=10mA Forward Voltage Per Dot VF 2.0 2.4 V IF=10mA Reverse Current Per Dot IR 100 A VR=5V Iv-m 2:1 Luminous Intensity Matching Ratio Official Product 13.7 TEST CONDITION IF=10mA ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 5/8 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech GREEN PARAMETER SYMBOL MIN. TYP. MAX. UNIT Average Luminous Intensity Iv Peak Emission Wavelength CONDITION 70 mcd IF=10mA p 520 nm IF=5mA Spectral Line Half-Width  32 nm IF=5mA Dominant Wavelength d 530 nm IF=5mA Forward Voltage Per Dot VF 2.85 3.4 V IF=5mA Reverse Current Per Dot IR 100 A VR=5V Iv-m 2:1 Luminous Intensity Matching Ratio 34 TEST IF=10mA BLUE PARAMETER SYMBOL MIN. TYP. MAX. UNIT Average Luminous Intensity Iv Peak Emission Wavelength 21.7 mcd IF=10mA p 464 nm IF=5mA Spectral Line Half-Width  22 nm IF=5mA Dominant Wavelength d 470 nm IF=5mA Forward Voltage Per Dot VF 2.95 3.4 V IF=25mA Reverse Current Per Dot IR 100 A VR=5V Iv-m 2:1 Luminous Intensity Matching Ratio 13.7 TEST CONDITION IF=5mA Note:Luminous intensity is measured with a light sensor and filter combination that approximates the CIE (Commision Internationale De L’Eclairage) eye-response curve. Official Product ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 6/8 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech TYPICAL ELECTRICAL / OPTICAL CHARACTERISTIC CURVES (25oC Ambient Temperature Unless Otherwise Noted) RELATIVE INTENSITY VS WAVELENGTH 1.0 0.5 0 450 500 550 600 Wavelength(nm) I F~ V F Luminous Intensity Relative Value at L F=10mA Forward Current L F(mA) 90 80 70 60 50 40 30 20 10 IV~ I F 2.5 2.0 1.5 1.0 0.5 0 0 1.0 2.0 3.0 4.0 0 5.0 10 20 30 40 50 60 70 80 90 100 Forward Voltage V F (V) Forward Current I F (mA) IV~ Ta IF~ Ta 3.0 Relative Luminous Intensity 50 Forward Current L F(mA) 700 3.0 100 40 30 20 10 0 0 20 40 60 80 100 Ambient TemperatureTa( ℃ ) Official Product 650 2.5 2.0 1.5 1.0 0.5 0 -40 -20 0 20 40 60 80 100 Ambient Temperature Ta( ℃ ) ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 7/8 0.56” Tri-color Digit Number Display ACD8143 ADH-Tech Pack process: PART NO. DATE CODE 20PCS/TUBE 1100PCS/I-CARTON 4400PCS/O-CARTON Official Product ACD8143 Customer Part No. Data Sheet No. **************** **************** ACD8143 Specifications are subject to change without notice. Data and drawings herein are copyrighted. Dec. 30, 2015 Version of 1.0 Page 8/8
COM-13999 价格&库存
很抱歉,暂时无法提供与“COM-13999”相匹配的价格&库存,您可以联系我们找货
