SLY2016
SLY2016
    AMSOSRAM(艾迈斯半导体)
    插件
    Dot Matrix Display Module 5 x 7 Yellow 7-Bit ASCII 0.78" L x 0.40" W x 0.20" H (19.7mm x 10.2mm x ...
SLY2016 数据手册
X/Y Stackable 0.180’’ 4-Digit 5x7 Dot Matrix Alphanumeric Intelligent Display® Devices with Memory/Decoder/Driver Lead (Pb) Free Product - RoHS Compliant Red SLR2016 Super-red SLO2016 Green SLG2016 Yellow SLY2016 DESCRIPTION The SLR/SLO/SLG/SLY2016 is a four digit 5 x 7 dot matrix display module with a built-in CMOS integrated circuit. This display is X/Y stackable. The integrated circuit contains memory, a 128 ASCII ROM decoder, multiplexing circuitry and drivers. Data entry is asynchronous. A display system can be built using any number of SLR/SLO/SLG/SLY2016 since each digit can be addressed independently and will continue to display the character last stored until replaced by another. System interconnection is very straightforward. Two address bits (A0, A1) are normally connected to the like-named inputs of all displays in the system. Data lines are connected to all SLR/SLO/SLG/SLY2016s directly and in parallel as is the write line (WR). The display will then behave as a write-only memory. The SLR/SLO/SLG/SLY2016 has several features superior to competitive devices. 100% burn-in processing insures that the SLR/SLO/SLG/SLY2016 will function in more stressful assembly and use environments. True “blanking” allows the designer to dim the display for more flexibility of display presentation. Finally the CLR clear function will clear the ASCII character RAM. The character set consists of 128 special ASCII characters for English, German, Italian, Swedish, Danish, and Norwegian. All products are 100% burned-in and tested, then subjected to out-going AQL’s of 0.25% for brightness matching, visual alignment and dimensions, 0.065% for electrical and functional. 2006-01-23 FEATURES • Very Close Multi-line Spacing, 0.4" Centers • 4.72 mm (0.180") 5 x 7 Dot Matrix Characters • 128 Special ASCII Characters for English, German, Italian, Swedish, Danish, and Norwegian Languages • Wide Viewing Angle: X axis 50° Maximum, Y Axis ± 75° Maximum • Fast Access Time, 110 ns at 25°C • Full Size Display for Stationary Equipment • Built-in Memory • Built-in Character Generator • Built-in Multiplex and LED Drive Circuitry • Direct Access to Each Digit Independently and Asynchronously • Clear Function that Clears Character Memory • True Blanking for Intensity Dimming Applications • End-stackable, 4-Character Package • Intensity Coded for Display Uniformity • Extended Operating Temperature Range: - 40°C to +85°C • Superior ESD Immunity • 100% Burned-in and Tested • Wave Solderable • TTL Compatible over Operating Temperature Range See Appnotes 18, 19, 22, and 23 at www.osram-os.com for additional information. 1 SLR2016, SLO2016, SLG2016, SLY2016, SCD5584A Ordering Information Type Color of Emission SLR2016 standard red SLO2016 super-red SLG2016 green SLY2016 yellow Character Height mm (inch) Ordering Code Q68000A8640 Q68000A8641 4.72 (0.180) Q68000A8642 Q68000A8643 SLX2016 Z OSRAM XXYY V EIA Date Code Luminous Intensity Code Pin 1 Indicator 0.46 (0.018) 2.54 (0.100) 12 pl. Non cumulative 5.08 (0.200) Part Number 4.06 (0.160) ±0.51 (0.020) Dimensions in mm (inch) 3.81 (0.150) Package Outlines 0.3 (0.012) ±0.05 (0.002) 7.62 (0.300) ±0.51 (0.020) 19.91 (0.784) 2006-01-23 5 (0.197) 3 pl. 4.57 (0.180) 10.16 (0.400) ±0.38 (0.015) 2.54 (0.100) Tolerance: ±0.25 (0.010) IDOD5215 2 SLR2016, SLO2016, SLG2016, SLY2016, SCD5584A Maximum Ratings Parameter Symbol Value Unit Operating temperature range Top – 40 … + 85 °C Storage temperature range Tstg – 40 … + 100 °C DC Supply Voltage VCC -0.5 to + 7.0 V -0.5 to VCC +0.5 V 260 °C 85 % Input Voltage, Respect to GND (all inputs) Solder Temperature 1.59 mm (0.063“) below seating plane, t < 5.0 s TS Relative Humidity Optical Characteristics at 25°C (VCC=5.0 V at 100% brightness level, viewing angle: X axis ± 50°, Y axis ± 75°) (typ.) λpeak Spectral Peak Wavelength Yellow SLY2016 (min.) IV (typ.) 50 60 75 60 µcd/LED 660 635 565 585 nm Notes: 1. Peak luminous intensity values can be calculated by multiplying these vaues by 7. 2. LED to LED intensity matching 1.8:1.0 Top View 14 13 12 11 10 9 8 Digit 3 Digit 2 Digit 1 Digit 0 1 2 3 4 5 6 7 IDPA5119 2006-01-23 3 Unit Green SLG2016 Time Averaged Luminous Intensity1) Values Super-red SLO2016 Symbol Red SLR2016 Description SLR2016, SLO2016, SLG2016, SLY2016, SCD5584A Pin Function Pin Function Pin Function Pin Function Pin Function Pin Function 1 WR Write 8 D3 Data 5 D0 Data 12 BL Display Blank D4 Data 6 D1 Data 13 CLR Clear 7 D2 Data 14 GND 2 A1 Digit Select 9 3 A0 Digit Select 10 D5 Data 4 VCC 11 D6 Data DC Characteristics at 25°C Parameters Min. Typ. Max. Units Conditions VCC 4.5 5.0 5.5 V — ICC Blank — 2.3 3.0 mA VCC=5.0 V ICC (80 dots on) — 80 105 mA VCC=5.0 V VIL (all inputs) — — 0.8 V 4.5 V
SLY2016 价格&库存
很抱歉,暂时无法提供与“SLY2016”相匹配的价格&库存,您可以联系我们找货
