COM-13795
COM-13795
    SPARKFUNELECTRONICS
    SPARKFUNLEDARRAY-8X7
COM-13795 数据手册
 SparkFun LED Array - 8x7 COM -1 3795 RO HS   images are CC BY-NC-SA 3.0 Description: The SparkFun LED Array is a set of 56 red LEDs arranged in a nice 8x7 grid. This little board requires eight pins while the library supports any ATmega 168 and 328-based Arduino device. The SparkFun LED Array was developed to be used in conjunction with the BadgerStick as a fun and interactive way for people to learn about soldering and engage with SparkFun products at the multiple trade shows we appeared at. Now this LED array is available to everyone! This board relies on the Charlieplexing technique to control individual LEDs, which means less GPIO pins are used (as opposed to a traditional grid format). Through the use of Charlieplexing we have been able to control all 56 LEDs with a total of only eight pins (labeled ‘A’ through ‘H’). With a little bit of code you will be able to cycle through all combinations of the pins to turn each LED on individually, and if cycled fast enough, you can create simple images and text! https://www.sparkfun.com/products/13795 3/29/2016
COM-13795 价格&库存
很抱歉,暂时无法提供与“COM-13795”相匹配的价格&库存,您可以联系我们找货
