2279
2279
    ADAFRUIT
2279 数据手册
Luckylight Pitch 3.0mm (0.12″) 64×32 Pixel Indoor Full Color LED Module Technical Data Sheet Model No.: MI-T21P3RGBE-AB Spec No.: Mi-T21XX Approved: JoJo Rev No.: V.3 Checked: Wu Lucky Light Electronics Co., Ltd. Date: Nov./08/2006 Drawn: Li Page: 1 OF 5 http://www.luckylightled.com Luckylight Features: ◇ Pitch 3mm (0.12″) indoor LED module. ◇ 64×32 pixel dot matrix. ◇ High luminous intensity output. ◇ 2121RGB SMD assembly. ◇ Well defined spatial radiation. ◇ Wide viewing angle (2θ1/2): ≥120°. ◇ Low power consumption. ◇ Reliable and robust. ◇ Solder state reliability. ◇ Emitting color: Red. ◇ The product itself will remain within RoHS compliant Version. Descriptions: ◇ The series are 64×32 pixel 2121RGB SMD LED display. ◇ The indoor LED module provide excellent reliability in bright ambient light. ◇ The indoor LED module with LED dot matrix displays are assembled in the epoxy and plastic package. Applications: ◇ Single graphic signs. ◇ Message boards. ◇ Variable message signs (VMS). ◇ Commercial indoor advertising, etc. Spec No.: Mi-T21XX Approved: JoJo Rev No.: V.3 Checked: Wu Lucky Light Electronics Co., Ltd. Date: Nov./08/2006 Drawn: Li Page: 2 OF 5 http://www.luckylightled.com Luckylight Package Dimension: Front view and negative map Single LED 2121RGB Spec No.: Mi-T21XX Approved: JoJo Rev No.: V.3 Checked: Wu Lucky Light Electronics Co., Ltd. Date: Nov./08/2006 Drawn: Li Page: 3 OF 5 http://www.luckylightled.com Luckylight Main Specifications: ITEM Description Pixel Pitch (mm) 3 One Pixel 1R1G1B Density of Pixel (dots/m2) 111,111 Drive Method 1/16 scan Constant current Driver IC MBI 5024 Brightness in White Color(cd/m2) 1100~1300 Gray scale 14bit Color Quantity ≥68.7billion Frame frequency ≥60HZ/S Refresh frequency ≥1000HZ/S Brightness adjust way Manual R.G.B each color 256,are levele,automatic 8 grades are adjustable Viewing Distance ≥4m Viewing angle (hor/vert) 160°/160° Protection against water and dust IP50 front/IP4X rear Life span >100000 hours Display resolution/Module(dots) 64×32=2048dots Module Size (mm) 192×96 Cabinet size (W/H)(mm) 576×576×80 Weight with cabinet (kg) ≤10 40kg/㎡ Cabinet resolution (W/H)(dot) 192×192 Working temperature -10℃~+40℃ Working voltage 220/110VAC,50/60Hz Max.power consumption (W/ m2) Adopted spare parts ≤1200 DVI display card + main controller + fibre transmission or Rj45 (optional) S-VHS,DVD,TV,Satellite,Color-camera,PC-VG A Leds, IC, cables etc. Certificates CE,ROHS,CCC Software Led studio/LEDT9 software is free Interface Definition HUB75D Control system transmission Video signal Spec No.: Mi-T21XX Approved: JoJo Rev No.: V.3 Checked: Wu Lucky Light Electronics Co., Ltd. Date: Nov./08/2006 Drawn: Li Page: 4 OF 5 http://www.luckylightled.com Luckylight LED Optical Characteristics (Ta=25℃): Item Luminous Intensity Peak Emission Wavelength Symbol IV λp Description R 80~120MCD G 200~220MCD B 45~65MCD R 620~630 G 520~525 B 465~470 Viewing Angle Spec No.: Mi-T21XX Approved: JoJo Unit 20MA mcd Lucky Light Electronics Co., Ltd. 10MA 5MA nm 120 Rev No.: V.3 Checked: Wu Test Condition Degree Date: Nov./08/2006 Drawn: Li Page: 5 OF 5 http://www.luckylightled.com
很抱歉,暂时无法提供与“2279”相匹配的价格&库存,您可以联系我们找货
