1484
1484
    ADAFRUIT
    ROUND SPACER #8 BRASS 1"
1484 数据手册
Sign In SHOP BLOG LEARN FORUMS 0 Items   VIDEOS LEDS / RGB MATRICES / 32X32 RGB LED MATRIX PANEL - 6MM PITCH 32x32 RGB LED Matrix Panel - 6mm pitch PRODUCT ID: 1484 IN STOCK ADD TO CART 1 1-9 10-99 100+ ADD TO WISHLIST DESCRIPTION TECHNICAL DETAILS DESCRIPTION Bring a little bit of Times Square into your home with this sweet 32 x 32 square RGB LED matrix panel. These panels are normally used to make video walls, here in New York we see them on the sides of busses and bus stops, to display animations or short video clips. We thought they looked really cool so we picked up a few boxes of them from a factory. They have 1024 bright RGB LEDs arranged in a 32x32 grid on the front on a 6mm grid. On the back there is a PCB with a set of dual IDC connectors (one input, one output: in theory you can chain these together) and 12 16-bit latches that allow you to drive the display with a 1:16 scan rate. These displays are technically 'chainable' - connect one output to the next input - but our Arduino example code does not support this (yet). It requires a high speed processor and more RAM than the Arduino has! These panels require 13 digital pins (6 bit data, 7 bit control) and a good 5V supply, up to 4A per panel. We suggest our 4A regulated 5V adapter and then connecting a 2.1mm jack. Please check out our tutorial for more details! Comes with: a single 32x32 RGB panel, one IDC cable and a power cable. If we happen to get them from the factory we also include 4 mounting screws and mini-magnets (it appears these are often mounted on a magnetic base). Keep in mind that these displays are designed to be driven by FPGAs or other high speed processors: they do not have built in PWM control of any kind. Instead, you're supposed to redraw the screen over and over to 'manually' PWM the whole thing. On a 16 MHz arduino, we managed to squeeze 12-bit color (4096 colors) with 40% CPU usage but this display would really shine if driven by any FPGA, CPLD, Propeller, XMOS or other high speed multi-core controller. The good news is that the display is pre-white balanced with nice uniformity so if you turn on all the LEDs it's not a particularly tinted white. Of course, we wouldn't leave you with a datasheet and a "good luck!" We have a full wiring diagrams and working Arduino library code with examples from drawing pixels, lines, rectangles, circles and text. You'll get your color blasting within the hour! On an Arduino, you'll need 13 digital pins, and about 1600 bytes of RAM to buffer the 12-bit color image. At this time we do not have wiring documentation for the MEGA. Please note! These panels are remainder stock from factories that make huge light boards. For that reason, the look and size might vary from batch to batch, even though the basic operation, codebase and tutorial is the same. Medium 32x32 RGB LED matrix panel (9:31) TECHNICAL DETAILS We don't have a spec or datasheet at this time. However, these are the specifications from the factory Dimensions: 190.5mm x 190.5mm x 14mm / 7.5" x 7.5" x 0.55" Panel weight with IDC cables and power cable: 357.51g 5V regulated power input, 4A max (all LEDs on) 5V data logic level input 2000 mcd LEDs on 6mm pitch 1/16 scan rate Indoor display, 150 degree visibility Displays are 'chainable' - connect one output to the next input - but our Arduino example code does not support this yet We have a full tutorial here! Please Note: As of April 23rd 2018 this product is not ROHS compliant. LEARN 32x16 and 32x32 RGB LED Matrix Hundreds of pixels of eyeblasting LED glory! DIY LED Video Cube Make your very own full-color video companion cube SmartMatrix Animated GIF Player Customize the display with your own GIF collection SmartMatrix Remote Controlled LED Art Display Remote controlled display to brighten up any room Creating GIFs for SmartMatrix Turn video and high resolution GIFs into 32x32 pixel GIFs Adafruit RGB Matrix + Real Time Clock HAT for Raspberry Pi DIY your very own Times Square sign Raspberry Pi LED Matrix Display Show the Pi's video output on a large RGB LED matrix display! Raspberry Pi RGB LED Matrix Webapp Control RGB LED panels from a Web application using Raspberry Pi. Adafruit RGB Matrix FeatherWing Blast those pixels! MAY WE ALSO SUGGEST... 16x24 Red LED Matrix Panel - Chainable HT1632C Driver Medium 16x32 RGB LED matrix panel 32x32 RGB LED Matrix Panel - 4mm Pitch 5V 2A (2000mA) switching power supply - UL Listed Female DC Power adapter 2.1mm jack to screw 5V 4A (4000mA) switching power supply - UL Listed 64x64 RGB LED Matrix 2.5mm Pitch Adafruit RGB Matrix Shield for Arduino 64x32 RGB LED Matrix 3mm pitch 64x32 RGB LED Matrix 6mm pitch DISTRIBUTORS CONTACT SUPPORT DISTRIBUTORS EDUCATORS JOBS Adafruit NeoPixel NeoMatrix 8x8 - 64 RGB LED Pixel Nootropic RGB Matrix Backpack Kit for 32x32 & EXPAND TO SEE DISTRIBUTORS "I don't think there's anything like saving someone's life to bring you satisfaction and happiness" Stephanie Kwolek FAQ SHIPPING & RETURNS TERMS OF SERVICE PRIVACY & LEGAL ABOUT US ENGINEERED IN NYC Adafruit ® 4.9
很抱歉,暂时无法提供与“1484”相匹配的价格&库存,您可以联系我们找货
