GU140X16G-7003
GU140X16G-7003
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 140X16
GU140X16G-7003 数据手册
Graphic VFD Module GU140x16G-7003 CLICK HERE FOR COMMANDS LIST Ref: MC-018 Dec.02 The module includes the Vacuum Fluorescent Display glass, driver and micro-controller Ics with refresh RAM, character generator and interface logic. This module have CMOS sync or asyn serial interface. The module can simultaneously display graphic pattern and / or characters on screen. Character Graphic, Transformerless display Size compatible with LCD Module (U-Version) Single 5V power supply High Brightness Blue Green display Operating temp -40°C to +85°C Proportional and scalable fonts Screen saver & window definition function 8 level brightness control function CMOS serial Interface 3.5 140 x 16 Dot Display Area : 69.85 x 11.45 29.0 37.0 Sample software available 116.0 108.0 3.5 □ □ □ □ □ □ □ □ □ Φ3.5 10.4 Unit : mm ELECTRICAL SPECIFICATION Parameter Symbol Power Supply Voltage VCC Power Supply Current ICC Logic High Input VIH Logic Low Input VIL Logic High Output VOH Logic Low Output VOL COMMON FONT INTERNATIONAL FONTS n=0 Value 5.0VDC 260mADC typ. 0.8VDC min. Vcc max. 0VDC min. 0.2VDC max. 3.5VDC min. 3.8VDC min. 0VDC min. 0.6 DC max. n=19 OPTICAL and ENVIRONMENTAL SPECIFICATIONS Value Parameter 80.00 x 36.00 PCB Size (X x Y mm) 52.5 x 11.45 Display Area (X x Y mm) 0.33 x 0.58 / 0.47 x 0.73 Dot size / Pitch (X x Y mm) 700 cd/m2 Typ. Luminance Color of Illumination Blue Green (Filter for more colors) Operating Temperature -40°C to +85°C 20 to 80 % RH (non condensing) Operating Humidity SOFTWARE COMMANDS - Popular codes, more included Command Code Write Character to Display 20H~FFH 1FH 24H xL xH yL yH Cursor Set 1BH 40H Initialize Display Specify International Font 1BH 52H n Vertical / Horizontal Scroll Mode 1FH 02H / 1FH 03H 1FH 28H 61H 40H p Screen Saver Display Blink 1FH 28H 61H 11H p t1 t2 c Bit Image Display Group 1FH 28H 66H 11H xL xH Font Magnified Display 1FH 28H 67H 40H x y Brightness Level Setting 1FH 58H n CMOS Serial Interface - CN2 Pin Asyn. Sig Syn. Sig 1 Vcc Vcc 2 SIN SIN 3 GND GND 4 SBUSY SBUSY 5 NC SCK 6 /RESET /RESET CN1 is not used on this Module Please inquire for full specification. ** Subject to change without notice ** Atlanta Boston Chicago Dallas 1-888-326-3423 1-888-395-3423 1-800-779-5846 1-888-318-3423 Los Angels 1-888-795-3423 New York 1-888-296-3423 Canada 1-416-291-2946
GU140X16G-7003 价格&库存
很抱歉,暂时无法提供与“GU140X16G-7003”相匹配的价格&库存,您可以联系我们找货
