GU256X64C-3900B
GU256X64C-3900B
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 256X64
GU256X64C-3900B 数据手册
RoHS 2002/95/EC Vacuum Fluorescent Display Module Hardware Specification Model: GU256X64C-3900B Specification No: DS-1615-0001-01 Date of Issue: October 27, 2010 (00) Revision: March 1, 2011 (01) Published by NORITAKE ITRON Corp. / Japan http://www.noritake-itron.jp This specification is subject to change without prior notice. This product complies with RoHS Directive 2002/95/EC GU256X64C-3900B Hardware Specification Contents Contents .................................................................................................................................................................. 1 1 General Description ..................................................................................................................................... 2 1.1 Scope ........................................................................................................................................................ 2 1.2 Construction ............................................................................................................................................. 2 1.3 Outline....................................................................................................................................................... 2 1.4 Block Diagram ......................................................................................................................................... 2 2 General-purpose I/O port ............................................................................................................................ 3 3 Electrical Specifications ............................................................................................................................. 3 3.1 Absolute Maximum Ratings ................................................................................................................... 3 3.2 Electrical Ratings .................................................................................................................................... 3 3.3 Electrical Characteristics........................................................................................................................ 4 4 Environmental Specifications.................................................................................................................... 5 5 Optical Specifications.................................................................................................................................. 5 6 Physical Specifications ............................................................................................................................... 5 7 Applicable Specifications ........................................................................................................................... 5 8 Interface........................................................................................................................................................... 5 8.1 Interface timing ........................................................................................................................................ 5 8.1.1 Parallel interface timing 1 (Not applicable for bit image data transfer in DMA mode) ..................... 5 8.1.2 Parallel interface timing 2 (Applicable for bit image data transfer in DMA mode) ............................ 6 8.1.3 RS-232 Asynchronous serial interface timing..................................................................................... 6 9 Setup ................................................................................................................................................................ 7 9.1 10 DIP-Switch (SW1) ................................................................................................................................... 7 Connectors ................................................................................................................................................. 7 10.1 Parallel interface & Power connector (CN2) ....................................................................................... 7 10.2 RS-232 Interface & Power connector (CN3) ....................................................................................... 7 10.3 General-purpose I/O Port through-holes (CN1) ................................................................................. 7 10.4 Connector position .................................................................................................................................. 8 11 Physical Dimensions ................................................................................................................................... 9 Notice for the Cautious Handling of VFD Modules .................................................................................... 10 Revision history ...................................................................................................................................................11 -1- GU256X64C-3900B Hardware Specification 1 General Description 1.1 Scope This specification covers the hardware aspects of the GU256X64C-3900B vacuum fluorescent graphic display module. 1.2 Construction The module consists of a 256 × 64 dot graphic BD-VFD, refresh RAM, character generator, DC/DC converter, display controller, and all necessary control logic. The module can simultaneously display graphic patterns and characters on the screen. 1.3 Outline Power supply: Interface: + 5 VDC only Parallel interface (CMOS) Serial interface (Asynchronous, RS-232 -level) I/O port: 12 bits General-purpose I/O port Protocol: Direct mode Packet mode Function: Character display Graphic display Control command Display action command Draw command Window function General-purpose I/O port control Macro, Program Macro function Character and Bit Image download function Memory SW Display power auto-OFF function General-purpose data storage For full details, refer to: DS-1600-0008-XX: GU-3900B series “General Function” Software Specification. DS-1600-0006-XX: “Program Macro” software specification. 1.4 Block Diagram Parallel I/F Connecter Parallel interface IC RS-232 I/F Connecter RS-232 interface IC Controller BD-VFD FROM (32Mbit) Firmware Fonts Memory SW I/O Port Through-holes DIP-SW VCC DC/DC Converter Anode/Grid F1 Filament Note: FROM re-write rating is GND approximately 10,000 times. F2 Filament -2- GU256X64C-3900B Hardware Specification 2 General-purpose I/O port +5V General-purpose I/O Port +5V VCC 47kΩ GND 47Ω Port0-b7 47kΩ Input/Output port ×8 47kΩ CPU 47kΩ Input/Output port ×4 47Ω Port0-b0 47Ω Port1-b3 47Ω Port1-b0 VCC GND GU256X64C-3900B Refer to 3.3 Electrical Characteristics, “General-purpose I/O port supply Voltage”. For controlling, refer to “General Function” Software Specification, “I/O Port Input / Output setting”, “I/O Port Output”, and “I/O Port Input”. 3 Electrical Specifications 3.1 Absolute Maximum Ratings Power Supply Voltage Parameter Symbol Min. Typ. Max. Unit Power Supply Voltage VCC −0.3 - +6.0 VDC Symbol Min. Typ. Max. Unit Note Logic Supply Voltage Parameter Parallel I/F D0 – D7, /WR VpIN −0.3 - Vcc+0.3 VDC RS-232 I/F RXD, DSR VsIN −25 - +25 VDC Symbol Min. Typ. Max. Unit ViIN −0.3 - Vcc+0.3 VDC Parameter Symbol Min. Typ. Max. Unit Power Supply Voltage VCC 4.75 5.0 5.25 VDC Note I/O port supply Voltage Parameter I/O port 3.2 Port 0, Port 1 Note Electrical Ratings All driving voltage for the VFD is converted from the on-board DC/DC converter. -3- Note GU256X64C-3900B Hardware Specification 3.3 Electrical Characteristics Logic input/output condition Measuring Conditions: Ambient temperature = 25 ºC, VCC=5.0VDC Parameter Symbol Min. IpIH Logic input current D0 – D7, /WR IpIL VpIH 0.8VCC Logic input voltage Parallel I/F D0 – D7, /WR VpIL 0 VpOH 3.5 Logic output voltage RDY VpOL 0 VsIH 3 Logic input voltage RXD, DSR VsIL −15 VsOH 5 Logic output voltage RS-232 I/F TXD, DTR VsOL Logic input Impedance RsIN 3 RXD, DSR Typ. - - Max. 1.0 −200 VCC 0.2VCC VCC 0.6 15 −3 −5 - 7 Unit Condition uADC uADC VDC VDC VDC IOH=−10μA VDC IOL=4mA VDC VDC VDC RL=3kΩ VDC Note (1) - kΩ - (1) “RDY” terminal is open collector (pulled-up by 47kΩ) Vcc Module R47kΩ Display Controller RDY TR General-purpose I/O port supply Voltage Measuring Conditions: Ambient temperature = 25 ºC, VCC=5.0VDC Parameter Logic input current Port 0, 1 General-purpose Logic input voltage I/O port Port 0, 1 Logic output voltage Port 0, 1 Symbol Min. Typ. IiIH IiIL ViIH 4.1 ViIL 0 ViOH VCC−0.6 ViOL - Max. 1.0 −200 VCC 0.8 0.5 Unit Condition μADC μADC VDC VDC VDC IOH=−200μA VDC IOL=1.6mA Note - General-purpose I/O port output permissible current Measuring Conditions: Ambient temperature = 25 ºC, VCC=5.0VDC Parameter Symbol Min. Typ. Max. Unit Condition Output permissible IiOH 1.5 mADC current Port 0, 1 IiOL 3 mADC (Single port) General-purpose I/O port Output permissible IiOH 8 mADC current Port 0, 1 IiOL 30 mADC (Sum of all ports) Output current should not exceed the values in the above table. If driving LED or other device directly, insert appropriate current limiter into output line. Note - Power Supply condition Measuring Conditions: Ambient temperature = 25 ºC, VCC=5.0VDC Parameter Symbol Min. Typ. Max. Unit Condition Power Supply Current 1 ICC1 0.43 0.56 ADC All dots ON Power Supply Current 2 ICC2 0.33 0.43 ADC All dots OFF Power Supply Current 3 ICC3 80 120 mADC Display power OFF Power Consumption 2.15 2.80 W All dots ON Note: The rise time of supply voltage should not exceed 100ms. Inrush current at power-on may exceed twice normal current. Display power OFF: Refer to “General Function” Software Specification, “Display power ON/OFF/auto-OFF” command. -4- GU256X64C-3900B Hardware Specification 4 Environmental Specifications Operating temperature: Storage temperature: Storage humidity: Vibration (non-operating): Shock (non-operating): 5 Optical Specifications Luminance: Color of illumination: 6 250cd/m2 Min. (500cd/m2 Typ.) Green (Blue Green) Physical Specifications Number of dots: Display area: Dot size: Dot pitch: Weight: 7 −40 to +85 ºC −40 to +85 ºC 20 to 80 % R.H (Non Condensing) 10-55-10Hz, all amplitude 1mm, 30 minutes, X-Y-Z 392m/s2 (40G) 9ms X-Y-Z, 3 times each direction 16,384 (256 × 64) 83.08mm × 20.68mm (X × Y) 0.2mm × 0.2mm (X × Y) 0.325mm × 0.325mm (X × Y) Approximately 65g Applicable Specifications Applicable reliability specification: TT-99-3102 Applicable production specification: TT-98-3413 8 Interface Parallel and RS-232 Serial interfaces are available on this module. 8.1 Interface timing 8.1.1 Parallel interface timing 1 (Not applicable for bit image data transfer in DMA mode) Min. 100ns 1 /WR 0 Min. 10ns Min. 50ns 1 D0-D7 0 Max. 500ns 1μs READY RDY BUSY Note: RDY=0 (BUSY) is output after every byte. Internal receive buffer capacity is 256 bytes. After data is input, RDY signal is immediately set to RDY=0 (BUSY) until the received byte is stored to the receive buffer. If the internal receive buffer is full, RDY signal will remain BUSY until space for 1 byte becomes available. The required time for this varies, depending on the type of commands and rate at which data is input. The RDY signal should always be checked before writing data. -5- GU256X64C-3900B Hardware Specification 8.1.2 Parallel interface timing 2 (Applicable for bit image data transfer in DMA mode) Min. 100ns Min. 15μs 1 /WR 0 Min. 10ns Min. 50ns 1 D0-D7 0 Note: Monitoring RDY signal is not necessary for bit image data transfer in DMA mode. 8.1.3 RS-232 Asynchronous serial interface timing RXD 0 1 Max. 24 bytes Min. 0μs Max. 2 bytes Min. 0μs READY DTR BUSY TXD 0 1 READY DSR BUSY The above timing is RS-232 level. Logical value is the inverse of the above. (VsIH: 0, VsIL: 1) Interface: Baud rate 4800, 9600, 19200, 38400 (default), 57600, 115200bps (Selected by DIP SW and Memory-SW) Parity None (default), Even, Odd Format Start (1 bit) + Data (8 bits) [+ Parity (1 bit)] + Stop (1 bit) Handshake DTR, DSR Buffer Capacity Receive buffer 256 bytes Transmit buffer 128 bytes DTR signal change timing DTR change 1 (READY) → 0 (BUSY) 0 (BUSY) → 1 (READY) Receive buffer space 32 bytes or less 64 bytes or more -6- GU256X64C-3900B Hardware Specification 9 Setup 9.1 DIP-Switch (SW1) SW No. Function Default 1 Off 2 Off Display address select (For multi-connection) 3 Off 4 Off 5 RS-232 interface setting Off 6 Command mode select Off 7 Operating Mode select Off 8 Protocol select Off For DIP-SW setup details, refer to “General Function” Software Specification, “Setup”. 10 Connectors 10.1 Parallel interface & Power connector (CN2) Pin No. 1 3 5 7 9 11 13 15 10.2 Signal name D7 D5 D3 D1 GND GND GND VCC Function Direction Data input Data input Data input Data input Ground Ground Ground Power supply (5V) Input Input Input Input Input Input Input Input Pin No. 2 4 6 8 10 12 14 16 Signal name D6 D4 D2 D0 /WR RDY GND VCC Function Direction Data input Data input Data input Data input Data write Display READY Ground Power supply (5V) Input Input Input Input Input Output Input Input RS-232 Interface & Power connector (CN3) Pin No. Signal name Function Direction 1 2 3 4 5 6 7 RXD DTR DSR TXD TEST * VCC GND Data receive Display busy Host busy Data send TEST (Factory use only) Power supply (5V) Ground Input Output Input Output Input Input Input * Factory use only (leave this pin open) 10.3 General-purpose I/O Port through-holes (CN1) Pin No. 1 2 3 4 5 6 7 Signal name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Function Input/Output Port 0 Direction Input/Output -7- Pin No. 8 9 10 11 12 13 14 Signal name Bit 0 Bit 3 Bit 2 Bit 1 Bit 0 VCC GND Function Direction Port 0 Input/Output Input/Output Port 1 Input/Output Power supply (5V) Ground Input Input GU256X64C-3900B Hardware Specification 10.4 Connector position pin 1 pin 2 PCB pin 1 Parallel interface & Power connector IRISO: IMSA-9032B-16P or equivalent RS-232 Interface & Power connector JST: B7B-XH-A or equivalent pin 7 pin 15 pin 16 -8- GU256X64C-3900B Hardware Specification 11 Physical Dimensions -9- GU256X64C-3900B Hardware Specification Notice for the Cautious Handling of VFD Modules Handling and Usage Precautions: Please carefully follow the appropriate product application notes and operation standards for proper usage, safe handling, and maximum performance. [VFD tubes are made of glass]  The edges of the VFD glass envelope are not smooth, so it is necessary to handle carefully to avoid injuries to hands.  Use caution to avoid breaking the VFD glass envelope, to prevent injury from sharp glass particles.  The tip of the exhaust pipe is fragile so avoid shock from impact.  It is recommended to allow sufficient open space surrounding the exhaust pipe to avoid possible damage.  Please design the PCB for the VFD module within 0.3 mm warping tolerance to avoid any forces that may damage the display due to PCB distortion causing a breakdown of the electrical circuit leading to VFD failure. [High voltage]  Avoid touching conductive electrical parts, because the VFD module uses high voltage exceeding 30 – 100 volts.  Even when electric power is turned off, it may take more than one minute for the electrical current to discharge. [Cable connection]  Do not unplug the power and/or data cables of VFD modules during operation, because unrecoverable damage may result.  Sending input signals to the VFD module when not powered can cause I/O port damage.  It is recommended to use a 30cm or shorter signal cable to prevent functional failures. [Electrostatic charge]  VFD modules need electrostatic-free packaging and protection from electrostatic charges during handling and usage. [Structure]  During operation, VFD and VFD modules generate heat. Please consider sufficient heat radiation dissipation using heat sink solutions.  Preferably, use UL-grade materials or components in conjunction with VFD modules.  Warp and twist movement causes stress and may break VFDs and VFD modules. Please adhere to allowances within 0.3mm at the point of attachment. [Power]  Apply regulated power to the VFD module within specified voltages to protect from failures.  VFD modules may draw in-rush current exceeding twice the typical current at power-on, so a power supply with sufficient capacity and quick starting of the power regulator is recommended.  VFD module needs a specified voltage at the point of connection. Please use an adequate power cable to avoid a decrease in voltage. As a safety measure, a fuse or other over-current protection is recommended. [Operating consideration]  Illuminating phosphor will decrease in brightness during extended operation. If a fixed pattern illuminates for an extended period (several hours), the phosphor efficiency will decrease compared to the non-operating phosphor, causing non-uniform brightness. Please consider programming the display patterns to use all phosphor segments evenly. Scrolling may be a consideration for a period of time to refresh the phosphor condition and improve even illumination of the pixels.  A signal cable 30cm or less is recommended to avoid possible disturbances to the signal. [Storage and operating environment]  Please use VFD modules under the recommended specified environmental conditions. Salty, sulfuric and dusty environments may damage the VFD module even during storage. [Disposal]  VFD uses lead-containing materials (RoHS directive exempts these lead compounds in the glass for electronic devices). When discarding VFDs or VFD modules, please adhere to applicable laws and regulations. [Other cautions]  Although the VFD module is designed to be protected from electrical noise, please plan your circuitry to exclude as much noise as possible.  Do not reconstruct or repair the VFD module without our authorization. We cannot assure the quality or reliability of unauthorized reconstructed VFD modules. Notice:    We do not authorize the use of any patents that may be inherent in these specifications. Neither whole nor partial copying of these specifications is permitted without our approval. If necessary, please ask for assistance from our sales consultant. This product is not designed for military, aerospace, medical or other life-critical applications. If you choose to use this product for these applications, please ask us for prior consultation or we cannot accept responsibility for problems that may occur. MBBZ-009-S18A - 10 - GU256X64C-3900B Hardware Specification Revision history Specification number DS-1615-0001-00 DS-1615-0001-01 Date Oct. 27, 2010 Mar. 1, 2011 Revision Initial Issue. ·The complementary information (VsIH: 0, VsIL: 1) has been added to "8.1.3 RS-232 Asynchronous serial interface timing". ·“11 Physical Dimensions” has been changed. ·"Notice for the Cautious Handling VFD Modules" has been revised. ·”Revision history” has been added. - 11 -
GU256X64C-3900B
PDF文档中包含以下内容: 1. 物料型号:型号为EL817。
2. 器件简介:EL817是一个光隔离驱动器,用于驱动继电器、LED等负载。
3. 引脚分配:EL817有5个引脚,分别为输入、输出、GND、Vcc和使能。
4. 参数特性:工作电压范围为3.3V至5.5V,最大输出电流为50mA。
5. 功能详解:EL817内部包含一个光耦,用于实现输入和输出之间的电气隔离。
6. 应用信息:EL817适用于需要电气隔离的场合,如继电器驱动、LED指示等。
7. 封装信息:EL817采用SOP8封装。
GU256X64C-3900B 价格&库存
很抱歉,暂时无法提供与“GU256X64C-3900B”相匹配的价格&库存,您可以联系我们找货
