GU160X16-800B
GU160X16-800B
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 160X16
GU160X16-800B 数据手册
VFD Module GU-800 series GU160X16-800B 160x16 dot size VFD module. Specifications Parameter Power Supply Voltage Symbol VCC Min. 4.75 Typ. 5.00 Max. 5.25 Unit VDC Condition - Parameter Logic Input Voltage H L Logic Output Voltage H L Reset Input Voltage H L Symbol Min. Typ. Max. Unit Condition VIH VIL 4.0 - - 1.0 VDC VOH VOL 4.7 - - 0.3 VDC VRH VRL Power Supply Current ICC 4.0 - 550 450 2.75 0.6 700 600 3.5 Power Consumption VDC VDC mA W All dots ON All dots OFF All dots ON Parameter Luminance Color of illumination 350 cd/m2 Min. Green (Blue-Green) Parameter Operating Temperature Storage Temperature Operating Humidity Vibration (Non operation) Shock (non-operating) -40 ~ +85 degrees celsius -40 ~ +85 degrees celsius 20 ~ 80% R.H. (non-condensing) 10-55-10Hz, all amplitude 1mm, 30 minutes, X-Y-Z 539m/s2 (55G) 10ms Parameter Number of Dots Display Area Dot Size (X x Y) Dot Pitch (X x Y) 2,560 (160 x 16) 103.85 mm x 15.0 mm 0.50 mm x 0.75 mm 0.65 mm x 0.95 mm Parallel(CMOS), Synchronous Serial (CMOS) Description Pin No. Parallel Parallel #1 #2 1 D7 D7 3 D6 D6 5 D5 D5 7 D4 D4 9 D3 D3 11 D2 D2 13 D1 D1 15 D0 D0 17 WR R/W 19 C/D C/D 21 RD ENCK 23 CSS CSS 25 FRP FRP Serial NC NC NC NC NC NC TXD RXD NC C/D SCK CSS FRP Description Pin No. All 2 4 6 8 10 12 14 16 18 20 22 24 26 GND GND GND GND GND GND GND GND GND GND GND GND RESET Pin No. Signal 1 VCC 2 Test 3 GND None Parameter High-speed interface Control command 2 Graphic Layers support Scroll function AND/OR/EXOR etc. Leaflet contents, and specifitaions and external appearance of products, may change without notice. Please confirm product details in the specification. (C)Copyright NORITAKE ITRON CORP. '12/06
GU160X16-800B 价格&库存
很抱歉,暂时无法提供与“GU160X16-800B”相匹配的价格&库存,您可以联系我们找货
