GU256X64F-3900B
GU256X64F-3900B
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 256X64
GU256X64F-3900B 数据手册
VFD Module GU-3000 series GU256X64F-3900B ■ Features SIMPLIFIED DATASHEET ■ Physical dimension Uses the largest VFD in the 256x64 dot size. High-visibility display area, approximately 2x that of GU256X64C Specifications ■ Electrical Ratings Parameter Power supply voltage Symbol VCC Min. 22.8 Typ. 24.0 Max. 25.2 ■ Electrical Characteristics Unit VDC Symbol Parameter Min. Typ. Max. Unit Palrallel IF Logic input current IpIH 1.0 μADC D0-D7,/WR IpIL -200 μADC Logic input voltage VpIH 4.0 5.3 VDC D0-D7,/WR VpIL 0 1.0 VDC Open Collector (Output) Logic output voltage VpOH RDY VpOL 0 0.3 VDC RS232 I/F Logic Input Voltage VsIH 3 15 VDC RXD, DSR VsIL -15 -3 VDC Logic Output Voltage VsOH 5 VDC TXD, DTR VsOL -5 VDC Logic Input Impedance RXD, DSR RsIN 3 7 KΩ General-purpose I/O port Power Supply Current 1 ICC1 0.28 0.37 ADC Power Supply Current 2 ICC2 0.23 0.3 ADC Power Supply Current 3 20 30 mADC Power Consumption ICC2 6.7 8.9 W *1) external pull-up (10 to 47KΩ) required Condition - Condition *1 IOL=10mA RL=3KΩ Abbreviation All dots ON All dots OFF Display power OFF All dots ON ■ Optical Specifications Parameter Luminance Color of illumination 350 cd/m2 Min. (700 cd/m2 Typ.) Green (Blue-Green) ■ Interface Parallel(CMOS), Asynchronous Serial (RS232), I/O port ■ Pin Assignment (Parallel) Pin No. 1 3 5 7 9 11 13 15 Signal D7 D5 D3 D1 GND GND GND VCC -40 ~ +70 degrees celsius -40 ~ +85 degrees celsius 20 ~ 80% R.H. (non-condensing) 10-55-10Hz, all amplitude 1mm, 30 minutes, X-Y-Z 392m/s2 (40G) 9ms x-y-z, 3 times each direction ■ Physical Specifications Parameter Number of Dots Display Area Dot Size (X x Y) Dot Pitch (X x Y) Weight 16,384 (256x64) 166.25 mm x 41.45 mm 0.5 mm x 0.5 mm 0.65 mm x 0.65 mm About 320 g Signal D6 D4 D2 D0 /WR RDY GND VCC (Asynchronous Serial) Pin No. Signal Baud Rate Setting 1 RXD 4800bps 2 DTR 9600bps 3 DSR 19200bps 4 TXD 38400bps* 5 TEST 57600bps 6 VCC 115200bps 7 GND (*:Default setting) (General-purpose I/O port: Abbreviation) ■ Selectable Font Parameter ASCII, KANA International 2-byte character Japanese Character numbers ■ Environmental Specifications Parameter Operating Temperature Storage Temperature Storage Humidity Vibration (non-operating) Shock (non-operating) Pin No. 2 4 6 8 10 12 14 16 All Font Size 6 x 8 / 8 x 16 / 12 x 24 / 16 x 32 dot 16 x 16 dot 32 x 32 dot 42 x 8 by 6 x 8 dot ASCII 21 x 2 by 12 x 24 dot ASCII 16 x 4 by 16 x 16 dot 2-byte character 8 x 2 by 32 x 32 dot Japanese ■ Functions Parameter Variable Character display Scroll function Display Power Auto ON/OFF User Windows function I/O Port Control Function Bit Image by dot Variable stored setting etc. Variable Action Commands Line / BOX Draw AND/OR/XOR Mixture display Program Macro function Graphic DMA mode Leaflet contents, and specifications and external appearance of products, may change without notice. Please confirm product details in the specification. (C)Copyright NORITAKE ITRON CORP. '15/08
GU256X64F-3900B 价格&库存
很抱歉,暂时无法提供与“GU256X64F-3900B”相匹配的价格&库存,您可以联系我们找货
