GU160X16-800A
GU160X16-800A
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 160X16
GU160X16-800A 数据手册
Dot Graphic VFD Module q q q q q q q GU160X16-800A 160 x 16 Dot Graphic Operating Temp -40° C to +85° C Single 5V Supply. High Brightness Blue Green Display Selectable Parallel (i80/M68)/Serial Interface Twin Screen Graphic RAM 16 Level Brightness Control Function The module includes the Vacuum Fluorescent Display glass, driver and control ASIC, with integral refresh Graphic RAM and logic for parallel and synchronous serial interfaces. The high speed 8 bit parallel interface is 5V CMOS compatible suitable for connection to a host CPU bus. Brightness control and power down functions are provided. A full data sheet is available. 15.0 31.0 39.0 21.95 103.85 12.0 150.5 154.0 135.0 1.75 29.0 4.0 10.8 ± 1mm 1 77.0 PWR(JST-B3B-XH-A) ELECTRICAL SPECIFICATION Parameter Symbol Power Supply Voltage VCC Power Supply Current ICC Logic High Input VIH Logic Low Input VIL Logic High Output VOH Logic Low Output VOL Reset Input Voltage VRH Reset Input Voltage VRL IDC(IMSA-9032B-26P) Dimensions in mm & subject to tolerances. Mounting holes 3.5mm dia. BLOCK DIAGRAM Value 5.0VDC +/- 5% 400mADC typ. 4.0 VDC min. 1.0 VDC max. 4.7 VDC min. 0.3 VDC max. 4.0 VDC min. 0.6 VDC max. Condition GND=0V VCC= 5V IIH = 2uA IIL = -600uA IOH = -300uA IOL = 300uA IRH = 5uA IRL = -600uA The power on rise time should be less than 100ms.The inrush current at power on can be 2 x ICC. OPTICAL and ENVIRONMENTAL SPECIFICATIONS Parameter Value Display Area (XxY mm) 103.85 x 15.0 Dot Size/Pitch (XxY mm) 0.5 x 0.75/0.65 x 0.95 Luminance 350 cd/m2 Min. Colour of Illumination Blue-Green (Filter for colours) Operating Temperature -40°C to +85°C Storage Temperature -40°C to +85°C Operating Humidity (non condensing) 20 to 80% RH @ 25°C SOFTWARE COMMANDS Instruction C/D Instruction Byte No. Bytes Set Display On/Off / Layer Merge 1 20H-2FH 2 Set Display Brightness 1 40H-4FH 1 Clear Display 1 52H-5FH 1 Set Cursor XY Address 1 60H-67H 3 Set Display Start X Address 1 70H-7FH 2 Set Write Address Mode 1 80H-8FH 1 Scroll Display Vertically Up/Down 1 B0H-BFH 1 Read Cursor XY Address 1 D4H-D7H 3 Write Data 0 00H-FFH 1 TIMING PARAMETERS (min) i80/M68 Parameters Write /WR/EN Cycle Time Write /WR/EN Pulse Width Set Up To Write /WR/EN Hold after Write /WR/EN Time 400ns 100ns 30ns 20ns 12.5 max. 1.6 Serial Parameters Time SCK Cycle Time 200ns SCK Pulse Width 80ns Set Up To SCK, /CSS=’L’ 40ns Delay After 8th bit, /CSS=’H’ 150ns SCROLLING GRAPHIC DISPLAY The pattern in GRAM can be scrolled around the display. Horizontal scroll is achieved by increment/decrement of the Display Start X Address. The vertical scroll process considers layer 0, then layer 1 as a continuous 64 bit high vertical area within RAM. NORITAKE ITRON VFD MODULES D0~D7 SO SI WR (R/W) RD (EN)(SCK) CSS C/D FRP /RES VCC GND DISPLAY CONTROLLER BD VFD GRAPHIC RAM DC/DC + AC Conv. FILAMENT (AC) ANODE + GRID (DC) GRAPHIC RAM BYTE FORMAT X ADDRESS 00H………………………….FFH D0 0H D1 D2 1H D3 D4 2H D5 D6 3H Y ADDRESS D7 The Graphic RAM is composed of 16384 6H bits arranged as (256 x 32 bits) x 2 and the access is operated by 8 bit vertical data 7H IDC DATA CONNECTOR Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 i80 M68 Serial Pin Sig D7 D7 X D6 D6 X D5 D5 X D4 D4 X D3 D3 X D2 D2 X D1 D1 SO D0 D0 SI /WR R//W X C//D C//D C//D /RD ENCK SCK /CSS /CSS /CSS FRP FRP FRP 2 4 6 8 10 12 14 16 18 20 22 24 26 GND GND GND GND GND GND GND GND GND GND GND GND /RES Subject to change without notice. IUK Doc Ref :03472 Iss:1 23/7/01 GRAM Layer 0 …………….FFH GRAM Layer 1 3 PIN POWER CONNECTOR Pin Sig 1 2 3 Vcc Test (Factory only) GND PCB JUMPERS (O)pen (L)ink Interface J1 J2 Serial L O/L i80 Parallel O O M68 Parallel O L CONTACT Noritake Sales Office Tel Nos Nagoya Japan: +81 (0)52-561-9867 Canada: +1-416-291-2946 Chicago USA: +1-847-439-9020 Munchen (D): +49 (0)89-3214-290 Itron UK: +44 (0)1493 601144 Rest Europe: +49 (0)61-0520-9220 www.noritake-itron.com 160 x 16 Dot Graphic
GU160X16-800A 价格&库存
很抱歉,暂时无法提供与“GU160X16-800A”相匹配的价格&库存,您可以联系我们找货
