GU140X16G-7000
GU140X16G-7000
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 140X16
GU140X16G-7000 数据手册
Graphic VFD Module GU140x16G-7000 CLICK HERE FOR COMMANDS LIST Ref: MC-016 Dec.02 The module includes the Vacuum Fluorescent Display glass, driver and micro-controller Ics with refresh RAM, character generator and interface logic. This module have 8 bit parallel & RS232C serial interface. The module can simultaneously display graphic pattern and / or characters on screen. Character Graphic, Transformerless display Size compatible with LCD Module (U-Version) Single 5V power supply High Brightness Blue Green display Operating temp -40°C to +85°C Proportional and scalable fonts Screen saver & window definition function 8 level brightness control function 8 bit Parallel, RS232C serial Interface 29.0 37.0 Sample software available 116.0 108.0 3.5 □ □ □ □ □ □ □ □ □ 3.5 140 x 16 Dot Display Area : 69.85 x 11.45 Φ3.5 ELECTRICAL SPECIFICATION Parameter Symbol Value Power Supply Voltage VCC 5.0VDC Power Supply Current ICC 260mADC typ. Logic Hi Input (Parallel) VIH 0.8VDC min. Vcc max. Logic Low Input (Parallel) VIL 0VDC min. 0.2VDC max. Logic HI output (Parallel) VOH 3.5VDC min. 3.8VDC min. Logic Low output (Parallel) VOL 0VDC min. 0.6 DC max. Logic Hi Input (RS232) VIH 3.0VDC min. 15VDC max. Logic Low Input (RS233) VIL -15VDC min. -3VDC max. Logic Hi output (RS233) VOH 5.0VDC min. Logic Low output (RS232) VOL -5VDC max. OPTICAL and ENVIRONMENTAL SPECIFICATIONS Parameter Value 116.00 x 37.00 PCB Size (X x Y mm) 69.85 x 11.45 Display Area (X x Y mm) 0.35 x 0.58 / 0.50 x 0.73 Dot size / Pitch (X x Y mm) Luminance 700 cd/m2 Typ. Color of Illumination Blue Green (Filter for more colors) Operating Temperature -40°C to +85°C Operating Humidity 20 to 80 % RH (non condensing) SOFTWARE COMMANDS - Popular codes, more included Command Code Write Character to Display 20H~FFH Cursor Set 1FH 24H xL xH yL yH Initialize Display 1BH 40H Specify International Font 1BH 52H n Vertical / Horizontal Scroll Mode 1FH 02H / 1FH 03H Screen Saver 1FH 28H 61H 40H p Display Blink 1FH 28H 61H 11H p t1 t2 c Bit Image Display Group 1FH 28H 66H 11H xL xH Font Magnified Display 1FH 28H 67H 40H x y Brightness Level Setting 1FH 58H n 10.4 Unit : mm COMMON FONT INTERNATIONAL FONTS n=0 n=19 RS232C Serial Interface - CN2 Pin Asyn. Sig 1 Vcc 2 SIN 3 GND 4 SBUSY 5 NC 6 /RESET Pin 1 3 5 7 9 11 13 Parallel interface- CN1 Sig Pin Sig GND 2 Vcc NC 4 RS /W 6 /RD D0 8 D1 D2 10 D3 D4 12 D5 D6 14 D7 Please inquire for full specification. ** Subject to change without notice ** Atlanta Boston Chicago Dallas 1-888-326-3423 1-888-395-3423 1-800-779-5846 1-888-318-3423 Los Angels 1-888-795-3423 New York 1-888-296-3423 Canada 1-416-291-2946
GU140X16G-7000 价格&库存
很抱歉,暂时无法提供与“GU140X16G-7000”相匹配的价格&库存,您可以联系我们找货
