BEZ-202C-V1-W-OEM
BEZ-202C-V1-W-OEM
    MATRIXORBITAL
    MOUNTING BEZEL 20X2 ABS BLACK
BEZ-202C-V1-W-OEM 数据手册
Mounting Bezel Including BEZ-202C-V1 and BEZ-204A-V1 Technical Manual Revision 1.0 Revision History Revision 1.0 Date March 31, 2014 Description Initial Release Author Simon Contents 1 Introduction ............................................................................................................................................... 1 2 Physical Description ................................................................................................................................... 3 2.1 Size ...................................................................................................................................................... 3 2.2 Material ............................................................................................................................................... 5 3 Versions...................................................................................................................................................... 6 3.1 -KIT ...................................................................................................................................................... 6 3.2 -OEM ................................................................................................................................................... 6 4 Mounting.................................................................................................................................................... 7 5 Contact ....................................................................................................................................................... 9 1 Introduction Figure 1: BEZ-202C-V1 Figure 2: BEZ-204A-V1 The Bezel and Mounting Kit is a system to mount Matrix Orbital displays while providing a clean and visually pleasing appearance. It is made from injection molded plastic, with threaded brass inserts allowing easy attachment and removal of the bezel and display. A clear plastic window is included to protect the display. Each bezel is available in two versions; a kit including all required mounting hardware, and an OEM version which includes only the bezel and window. There are several sizes available, each of which fits a different size of display. Sizes currently available include: Bezel Compatible Displays BEZ-202C-V1 LK/VK202-25 LK/VK202-25-USB MOS/MOI/MOU-AL/AV202C MOP-AL/AV202C Many other industry LCDs with 108mm x 29mm mounting holes BEZ-204A-V1 LCD/VFD2041 LK/VK204-25 LK/VK204-25-USB MOP-AL/AV204A GLK12232-25-FGW/WB Many other industry LCDs with 93mm x 55mm mounting holes 2 Physical Description 2.1 Size Figure 3: Bez-202C-V1 Dimensions Figure 4: Bez-204A-V1 Dimensions 2.2 Material The bezel is made from injection molded ABS plastic. The pre-installed threaded inserts are brass. The window is polycarbonate, with 3M 9795MP adhesive. The screws are steel. The cup washers and spacers are nylon. 3 Versions 3.1 -KIT The kit version of the bezel includes the bezel, instructions, and all required mounting hardware. Description Bezel Clear window with adhesive Cup Washer 4-40 x 1/8 machine screw 4-40 x 5/8 machine screw 4-40 x 3/8 machine screw 6mm nylon spacer Cut out guide sticker Instruction Sheet No. Included 1 1 2 2 4 4 4 1 1 3.2 -OEM The OEM version of the bezel includes the bezel and window only. Description Bezel Window with adhesive No. Included 1 1 4 Mounting For detailed mounting instructions, please refer to the instruction booklet included with the kit version of the bezel, or available at www.matrixorbital.ca See below for cut out guides. Please ensure proper size by using the guides available at www.matrixorbital.ca 5 Contact Sales Support Online Phone: 403.229.2737 Phone: 403.204.3750 Purchasing: www.matrixorbital.com Email: sales@matrixorbital.ca Email: support@matrixorbital.ca Support: www.matrixorbital.ca Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Matrix Orbital: BEZ-202C-V1-W-KIT BEZ-204A-V1-W-OEM BEZ-202C-V1-W-OEM BEZ-204A-V1-W-KIT
BEZ-202C-V1-W-OEM
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种嵌入式应用。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于工业控制、消费电子等领域。
3. 引脚分配:该器件共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考数据手册。
4. 参数特性:工作电压为2.0V至3.6V,工作频率可达72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(如UART、SPI、I2C)等多种功能模块。
6. 应用信息:适用于需要高性能处理和丰富外设的嵌入式系统,如工业自动化、医疗设备、智能家居等。
7. 封装信息:采用LQFP48封装,尺寸为7x7mm,适用于表面贴装技术。
BEZ-202C-V1-W-OEM 价格&库存
很抱歉,暂时无法提供与“BEZ-202C-V1-W-OEM”相匹配的价格&库存,您可以联系我们找货
