104990244
104990244
    SEEED(矽递科技)
    Graphic LCD Display Module Transmissive Red, Green, Blue (RGB) TFT - Color LVDS 7" (177.80mm) 1280 x...
104990244 数据手册
7 Inch HDMI 1280x800 IPS Display SKU: 104990244 Description This 7 inch High-resolution 1280*800 IPS LCD display module kit is especially designed as a monitor for Raspberry Pi 3,Pi 2 Model B and Raspberry Pi B+ B A+. For use with a Raspberry Pi we suggest editing config.txt to set the HDMI to the native 1280x800 in case it doesn't detect the resolution properly. The easiest way to edit the config.txt is to put the Pi TF card into an every day computer and edit config.txt with any text editor and save. Features Screen size:7 inch LCD Operating voltage: 7.5V-12V (current requirement 1A-2A) Rated power: 6-7W Signal input: 2 AV + VGA + HDMI (HDMI 1.2) Resolution: 1280 * 800, Plug and Play: Support OSD language: Simplified Chinese, Traditional Chinese, English, Japanese, Korean, Spanish, French, German, Italian, Portuguese Control: Multi-function OSD operation or potentiometer adjust the brightness and color Features: Using mature program, clear display Support image flip up and down, the image can conversion 4: 3 / 16: 9 display format Specification Display size: 7 inch Touch screen: Not support Resolution : 1280(RGB)×800 Display Mode : HS-IPS, Normally Black, Transmissive Outline : 161.6×105.8×4.85 mm Active Area : 150.72×94.2 mm Brightness : 690 cd/m2 (Typ.) Contrast Ratio : 800:1 (Typ.) Viewing Angle : 89/89/89/89 (Typ.)(CR≥10) (L/R/U/D) Display Colors : 262K (6-bit) Lamp Type : WLED Signal Interface :LVDS (1 ch, 6-bit) , 30 pins Applications: mobile DVD, digital photo frame, car systems, multimedia applications and other audiovisual systems Part List 1× HDMI+VGA+2AV LCD controller board 1× 7inch 1280x800 IPS LCD panel 1× LVDS Cable with adapte 1× Keyboard with Wire Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved.
104990244 价格&库存
很抱歉,暂时无法提供与“104990244”相匹配的价格&库存,您可以联系我们找货
