Website: www.displaytech.com.hk
LCD Module
Product Specification
Product: DT028ATFT & DT028ATFT-TS
2.8'' TFT Display Module (240RGBx320DOTS)
Contents in this document are subject to change without notice. No part of this document
may be reproduced or transmitted in any form or by any means, electronic or mechanical,
for any purpose, without the express written permission of Displaytech Ltd.
3 November 2011.
Displaytech Ltd
LCD MODULE
DT028ATFT / DT028ATFT-TS
Version: 2.1
1. REVISION RECORD
VERSION
1.0
2.0
2.1
CHANGES
Initial revision
Added details of TS version in pages 3, 5, 7, & 8
Changed the temperature range of TS version
1
DATE
26 April 2011
9 June 2011
3 November 2011
Displaytech Ltd
LCD MODULE
Version: 2.1
Table of Content
1.
REVISION RECORD .......................................................................... 1
2.
Introduction .......................................................................................... 3
3.
General Specifications .......................................................................... 3
4.
Mechanical Drawing............................................................................. 4
5.
Interface Description ............................................................................ 6
6.
Absolute Maximum Ratings ................................................................ 8
7.
Electrical Characteristics ..................................................................... 8
8.
Display Controller /Power Supply Timing ......................................... 8
9.
Backlight specification ......................................................................... 9
10.
Optical Characteristics......................................................................... 9
11.
Safety Precaution ................................................................................ 12
2
Displaytech Ltd
LCD MODULE
Version: 2.1
2. Introduction
DT028ATFT and DT028ATFT-TS is a display module that contains a TFT display with a
320 * 240 RGB resolution. The driver used for this project is the Ilitek ILI9341 or
compatible and can display 262K colors. The driver is mounted on the glass and the
interconnection via FPC including components to drive the display module.
3. General Specifications
Item
Specification
Unit
LCD mode
Transmissive
240(RGB)
Line
320
Line
2.8
Inch
50.00
mm
69.20
mm
43.20
mm
57.60
mm
Optimum Viewing Direction
6 o’clock
Driver IC
ILI9341
Interface type
MCU parallel / RGB (1)
Colours
262K
Operation temperature range
-20~70
°C
Storage temperature range
-30~80
°C
Resolution
Diagonal Size
Overall Size
Active area
Remarks:
(1) Serial interface is available, but not recommendable, as the speed of it is very slow.
(2) Recommended mating connector: Hirose FH19SC-45S-0.5SH, FH12S-45S-0.5SH; or
Molex 0512964593, 0512964594; or equivalent
(3) Color tune may be changed slightly by temperature and driving voltage.
(4) RoHS compliant.
Component Life Cycle
1) Storage Life: min. 1 Year
2) Operation Life (*1): min. 43 x 10³ h (24hr/day x 7days/week x 52weeks/year x 5years)
(Not include backlight)
3) Storage and Operation Life Times are defined for a temperature of +25°C
Notes:
*1. Operation life ends when one of the listed faults occurs:
The on/off response-times reach 1.5 times of the max. value specified for a new display
The contrast is reduced to 0.5 of the original contrast value
Loss of function
The number of cosmetic defects exceeds the maximum defined
3
Displaytech Ltd
LCD MODULE
4. Mechanical Drawing
DT028ATFT
4
Version: 2.1
Displaytech Ltd
LCD MODULE
DT028ATFT-TS
5
Version: 2.1
Displaytech Ltd
LCD MODULE
Version: 2.1
5. Interface Description
Pin no
1
2
3
4
5
Symbol
LED A
LED K1
LED K2
LED K3
LED K4
6
IM0
7
IM1
I/O
Description
Backlight anode.
Backlight cathode K1
Backlight cathode K2
Backlight cathode K3
Backlight cathode K4
I
8
IM2
9
IM3
10
FMARK
O
11
VSYNC
I
12
HSYNC
I
13
DOTCLK
I
14
ENABLE
I
15~32
DB17~DB0
I/O
33
CS
I
34
WR
I
Tearing effect output pin to synchronize MPU to frame writing, activated by S/W
command. When this pin is not activated, this pin is low.
If not used, open this pin.
Frame synchronizing signal for RGB interface operation.
Fix to VDDI or VSS level when not in use.
Line synchronizing signal for RGB interface operation.
Dot clock signal for RGB interface operation.
Data enable signal for RGB interface operation.
18-bit parallel bi-directional data bus for MCU system and RGB interface mode
Fix to VSS level when not in use.
Please refer to the IM[0:3] setting.
Chip select input pin (“Low” enable).
This pin can be permanently fixed “Low” in MPU interface mode only.
- 8080-I / 8080-II system (WRX): Serves as a write signal and writes data at the
rising edge.
- 4-line system (D/CX): Serves as command or parameter select.
6
Displaytech Ltd
Pin no
Symbol
I/O
35
RS/SCL
I
36
RD
I
37
RESET
I
38
SDO
O
39
SDI
I
40
41
42
43
44
45
VCC
GND
NC / YD
NC / XR
NC / YU
NC / XL
LCD MODULE
Version: 2.1
Description
This pin is used to select “Data or Command” in the parallel interface or 4-wire 8bit serial data interface.
When RS = ‘1’, data is selected.
When RS = ‘0’, command is selected.
This pin is used serial interface clock in 3-wire 9-bit / 4-wire 8-bit serial data
interface.
If not used, this pin should be connected to VDDI or VSS.
8080-I / 8080-II system (RDX): Serves as a read signal and MCU read data at the
rising edge.
Reset pin.
Serial output signal.
The data is outputted on the falling edge of the SCL signal.
When IM[3] : Low, Serial in/out signal.
When IM[3] : High, Serial input signal.
The data is applied on the rising edge of the SCL signal.
If not used, fix this pin at VDDI or VSS.
Power supply 2.8V
Power ground 0V
No connection (DT028ATFT) / YD of touch screen (DT028ATFT-TS)
No connection (DT028ATFT) / XR of touch screen (DT028ATFT-TS)
No connection (DT028ATFT) / YU of touch screen (DT028ATFT-TS)
No connection (DT028ATFT) / XL of touch screen (DT028ATFT-TS)
7
Displaytech Ltd
LCD MODULE
Version: 2.1
6. Absolute Maximum Ratings
(Ta=25°C)
Item
Symbol
Min.
Max.
Unit
Power supply voltage
VCC
-0.3
+ 4.6
V
Logic signal input/output
voltage
Vcc
-0.3
+ 4.6
V
Operating Temperature
TOP
-20
+70
°C
Storage Temperature
TST
-30
+80
°C
Note:
• When temperature is below 0°C, the response time of liquid crystal (LC) will be slower and the
color of panel will be darker.
• If module driving condition exceeds the absolute maximum ratings, permanent damaged may be
resulted. If module is driven within the absolute maximum ratings but exceeded the DC
characteristics, mal-function may be resulted.
• VDD/VCC > VSS
7. Electrical Characteristics
DC Characteristics
(Vss=0V, Ta=25°C)
Item
Power supply
Symbol
Condition
Min.
Typ.
Max.
Unit
2.5
2.8
3.3
V
VCC / VDD
Input voltage “H”
VIH
0.7 VCC
VCC
V
Input voltage “L”
VIL
VSS
0.3 VCC
V
Output voltage “H”
VOH
IOL=-1.0mA
0.8 VCC
VCC
V
Output voltage “L”
VOL
IOL=1.0mA
VSS
0.2 VCC
V
8. Display Controller /Power Supply Timing
See Display Controller Specification: Ilitek ILI9341
8
Displaytech Ltd
LCD MODULE
Version: 2.1
9. Backlight specification
Item
Supply voltage
Forward current
Uniformity
Color coordination
Symbol
Condition
Min
Typ
Vf
If
ΔBp
X
Y
If=80mA
2.9
--80
0.270
0.270
3.2
If=80mA
(Vcc=2.8V, Vss=0V, Ta=25°C)
Max
Unit
Note
3.5
80
--0.315
0.315
V
mA
1
2
LED circuit diagram:
Constant current If=4x20mA=80mA; Vf=3.2V(typ)
Note:
1) The LED’s driver mode needs to be constant current mode.
2) Permanent damage to the device may occur if maximum values are exceeded. Functional operation should be
restricted to the conditions described under normal operating conditions.
10. Optical Characteristics
Item
Brightness
Uniformity
Viewing Angle
Contrast ratio
Response Time
CIE (x,y)
Chromaticity
White
Red
Green
Blue
NTSC Ratio
Symbol
Condition
Min
Typ
Bp
ΔBp
θ1
(Ф=90°
or 270°)
θ2
(Ф=0°
or
180°)
Cr
Tr
Tf
x
y
x
y
x
y
x
y
S
θ=0º
Ф=0º
180
80
220
Max
Unit
Note
cd/m²
1
1, 2
deg
3
-70 ~ 50
Cr≥10
-70 ~ 70
θ=0º
Ф=0º
θ=0º
Ф=0º
9
400
500
4
25
30
ms
5
0.230
0.248
0.580
0.279
0.288
0.557
0.093
0.025
0.280
0.298
0.630
0.329
0.338
0.607
0.143
0.075
65
0.330
0.348
0.680
0.379
0.388
0.657
0.193
0.125
1, 6
Displaytech Ltd
Note 1:
LCD MODULE
Version: 2.1
The data are measured after LEDs are turned on for 5 minutes. LCM displays full white.
The brightness is the average value of 9 measured spots. Measurement equipment PR-705 (Φ8mm)
Measuring condition:
- Measuring surroundings: Dark room.
- Measuring temperature: Ta=25°C.
- Adjust operating voltage to get optimum contrast at the center of the display.
Measured value at the center point of LCD panel after more than 5 minutes while backlight turning on.
Note 2:
The luminance uniformity is calculated by using following formula.
ΔBp = Bp (Min.) / Bp (Max.)×100 (%)
Bp (Max.) = Maximum brightness in 9 measured spots
Bp (Min.) = Minimum brightness in 9 measured spots.
W/3
W/3
L/3
L/3
L/6
W/6
Note 3:
The definition of viewing angle:
Refer to the graph below marked by θ and Ф
10
Displaytech Ltd
LCD MODULE
Version: 2.1
Note 4:
The definition of contrast ratio (Test LCM using PR-705):
Luminance When LCD is at “White” state
Contrast Ratio (CR) =
Luminance When LCD is at “Black” state
(Contrast Ratio is measured in optimum common electrode voltage)
Note 5:
Definition of Response time. (Test LCD using DMS501):
The output signals of photo detector are measured when the input signals are changed from “black” to
“white” (falling time) and from “white” to “black” (rising time), respectively.
The response time is defined as the time interval between the 10% and 90% of amplitudes. Refer to figure
as below.
The definition of response time
Note 6:
Definition of Color of CIE Coordinate and NTSC Ratio.
Color gamut:
area of RGB triangle
area of NTSC triangle
S=
11
x 100%
Displaytech Ltd
LCD MODULE
Version: 2.1
11. Safety Precaution
Handling precautions:
This device is susceptible to Electro-Static Discharge (ESD) damage. Observe Anti-Static precautions.
Power supply precautions:
Identify and, at all times, observe absolute maximum ratings for both logic and LC
there is some variance between models.
drivers. Note that
Prevent the application of reverse polarity to VCC and GND, however briefly.
Use a clean power source free from transients. Power up conditions are occasionally “jolting” and may
exceed the maximum ratings of the modules.
The VCC power of the module should also supply the power to all devices that may access the display.
Don’t allow the data bus to be driven when the logic supply to the module is turned off.
Operating precautions:
DO NOT plug or unplug the module when the system is powered up.
Minimize the cable length between the module and host MPU.
Operate the module within the limits of the modules temperature specifications.
Mechanical/Environmental precautions:
Improper soldering is the major cause of module difficulty. Use of flux cleaner is not recommended as
they may seep under the elastomeric connection and cause display failure.
Mount the module so that it is free from torque and mechanical stress.
Surface of the LCD panel should not be touched or scratched. The display front surface is an easily
scratched, plastic polarizer. Avoid contact and clean only when necessary with soft, absorbent cotton
dampened with petroleum benzene.
Always employ anti-static procedure while handling the module.
Prevent moisture build-up upon the module and observe the environmental constraints for storage
temperature and humidity.
Do not store in direct sunlight
If leakage of the liquid crystal material should occur, avoid contact with this material, particularly
ingestion. If the body or clothing becomes contaminated by the liquid crystal material, wash thoroughly
with water and soap
12
很抱歉,暂时无法提供与“DT028ATFT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+325.561611+42.30756
- 10+264.2805510+34.34394
- 225+220.38784225+28.63997
