DT024DTFT
DT024DTFT
    DISPLAYTECH
DT024DTFT 数据手册
TFT LCD Module Product Specification DT024DTFT 2.4” (240RGB x 320 DOTS) TFT Module May 6, 2016 Remark: Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. Displaytech Ltd. Tel: (852) 2311 2080 ; Fax: (852) 2722 6998 ; Email: sales@displaytech.com.hk Address: 31E Billion Plaza 2, No. 10 Cheung Yue Street, Cheung Sha Wan, Kowloon, Hong Kong. Website: http://www.displaytech.com.hk DT024DTFT Displaytech Ltd. Rev 0.0 Revision Record REV 0.0 CHANGES First release DATE May 6, 2016 (Ref 1.0 20160415) 1 DT024DTFT Displaytech Ltd. Rev 0.0 Table of Content Revision Record ...........................................................................1 1. Scope.....................................................................................3 2. Application ............................................................................3 3. General Information ..............................................................3 4. Outline Drawing ....................................................................4 5. Interface Signals ...................................................................5 6. Absolute Maximum Ratings .................................................5 7. Electrical Specifications .......................................................6 8. Optical Specification.............................................................6 9. Environmental / Reliability Tests .........................................9 10. Precautions for Use of LCD Modules ..................................9 2 DT024DTFT Displaytech Ltd. Rev 0.0 1. Scope This data sheet is to introduce the specification of DT024DTFT, active matrix TFT module. It is composed of a color TFT-LCD panel, driver ICs, FPC and a backlight unit. The 2.40” display area contains 240(RGB) x 320 pixels. 2. Application Digital equipment which need color display, mobile phone, mobile navigator/video systems. 3. General Information Item Size Resolution Technology Type Interface Pixel Configuration Outline Dimension (W x H x D) Active Area Display Mode Backlight Type Driver IC Weight Contents 2.4 240(RGB) x 320 IPS TFT RGB/MCU R.G.B. Vertical Stripe 42.72 x 59.46 x 2.20 36.72 x 48.96 Transmissive/ Normally Black LED ILI9341V TBD 3 Unit Inch mm mm g DT024DTFT Displaytech Ltd. 4. Outline Drawing Displaytech Ltd. DT024DTFT 4 Rev 0.0 DT024DTFT Displaytech Ltd. Rev 0.0 5. Interface Signals No 1 2 3 4 5 6 7 8 9 10 11 ~ 28 29 30 31 Symbol NC IM0 IM1 IM2 IM3 RESET VSYNC HSYNC DOTCLK ENABLE DB17 ~ DB0 SDO SDI RD 32 RS/SCL 33 34 35 36 37 38 39 40 41 42 ~ 45 WR CS FMARK VCC VCC GND GND LEDA LEDK NC Description No connection System interface select System reset Frame sync signal Line sync signal Data clock Data enable pin Data bus Serial data output in serial bus system interface Serial data Input in serial bus system interface Read enable pin I80 parallel bus system interface DNC: Command / parameter or display data selection pin SCL: Serial data clock in serial bus system Write Enable Chip select signal Tearing effect output pin to synchronize MPU to frame writing Power supply Power supply Ground Ground LED backlight (Anode) LED backlight (Cathode) No connection 6. Absolute Maximum Ratings 6.1 Electrical Absolute Max. Ratings Item Symbol Min Max Unit Remark Power supply voltage VCC -0.3 3.6 V Notes: 1. If the module is above these absolute maximum ratings. It may become permanently damaged. Using the module within the following electrical characteristic conditions are also exceeded, the module will malfunction and cause poor reliability. 2. VCC >VSS must be maintained. 6.2 Environment Conditions Item Symbol Min Max Unit ℃ Operating Temperature TOPR -20 70 ℃ Storage Temperature TSTG -30 80 Note: 1. The response time will become lower when operated at low temperature. 2. Background color changes slightly depending on ambient temperature. The phenomenon is reversible. 3. Ta=40℃:Absolute humidity must be lower than the humidity of 85%RH at 40℃. 5 Remark DT024DTFT Displaytech Ltd. Rev 0.0 7. Electrical Specifications 7.1 Electrical Characteristics Parameter Symbol Min Typ Max Unit Note VCC VIH VIL ICC1 ICC2 Ta=25℃ VCC=2.8V VCC=2.8V Normal mode Sleep mode 2.6 0.8VCC 0 - 2.8 7 0.05 3.3 VCC 0.2VCC 12 0.1 V V V mA mA 1 1 Power supply “H” “L” Input voltage GND=0V, Ta=25℃ Condition Current consumption Note: 1. Tested in 1╳1 chessboard pattern. 7.2 LED Backlight Ta=25℃ Parameter Symbol Min Typ Max Unit Remarks Forward current VF 15 mA Forward voltage IF 12 V LED life time 50,000 Hr Note 2 Note: 2. The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL =15mA. The LED lifetime could be decreased if operating IL is lager than15mA. 8. Optical Specification Ta=25℃ Item Contrast Ratio Response Time View Angles White Red Chromaticity Green Blue NTSC Symbol Condition Min Typ Max CR θ=0° 300 500 - 50 10 10 80 80 80 80 0.28 0.33 0.51 0.34 0.31 0.56 0.15 0.14 60 - Tr Tf θT θB θL θR X Y X Y X Y X Y S 25℃ CR≧10 Brightness is on Unit ms ms Degree Note 4 Note 1 Note 5 % 2 Luminance L 170 220 - cd/m Uniformity U - 80 - % 6 Remark Note 1 Note 2 Note 1 Note 3 Note 5 Note 1 Note 6 Note 1 Note 7 DT024DTFT Displaytech Ltd. Rev 0.0 Note 1: Definition of optical measurement system. Temperature = 25℃(±3℃) LED back-light: ON, Environment brightness < 150 lx Note 2: Contrast ratio is defined as follow: Note 3: Response time is defined as follow: Response time is the time required for the display to transition from black to white (Rise Time, Tr) and from white to black(Decay Time, Tf). Note 4: Viewing angle range is defined as follow: Viewing angle is measured at the center point of the LCD. 7 DT024DTFT Displaytech Ltd. Rev 0.0 Note 5: Color chromaticity is defined as follow: (CIE1931) Color coordinates measured at center point of LCD. Note 6: Luminance is defined as follow: Luminance is defined as the brightness of all pixels “White” at the center of display area on optimum contrast. Note 7: Luminance Uniformity is defined as follow: Active area is divided into 9 measuring areas (Refer Fig. 2). Every measuring point is placed at the center of each measuring area. 8 DT024DTFT Displaytech Ltd. Rev 0.0 9. Environmental / Reliability Tests No 1 2 3 4 Test Item High Temp Operation Low Temp Operation High Temp Storage Low Temp Storage Condition Ts=+70℃, 96hrs Ta=-20℃, 96hrs Ta=+80℃, 96hrs Ta=-30℃, 96hrs 5 High Temp & High Humidity Storage Ta=+60℃, 90% RH 96 hours 6 Thermal Shock (Non-operation) 7 ESD (Operation) -30℃ 30 min~+80℃ 30 min, Change time: 5min, 5 Cycles C=150pF, R=330Ω, 5points/panel Air:±8KV, 5times; Contact:±4KV, 5 times; 8 9 10 Vibration (Non-operation) Shock (Non-operation) Package Drop Test Inspection Appearance Alignment of LCD Panel Electrical current Function / Display Judgment Criteria Per table in below Per table in below Per table in below Per table in below Per table in below (polarizer discoloration is excluded) Per table in below Per table in below 10Hz~150Hz, 100m/s2, 120min Per table in below Half- sine wave,300m/s2,11ms Per table in below Height: 80 cm, 1 corner, 3 edges, 6 surfaces Per table in below Criterion (after test) No Crack on the FPC, on the LCD Panel No Bubbles in the LCD Panel No other Defects of Alignment in Active area Within device specifications No Broken Circuit, No Short Circuit or No Black line No Other Defects of Display 10. Precautions for Use of LCD Modules 10.1 Safety The liquid crystal in the LCD is poisonous. Do not put it in your mouth. If the liquid crystal touches your skin or clothes, wash it off immediately using soap and water. 10.2 Handling A. The LCD and touch panel is made of plate glass. Do not subject the panel to mechanical shock or to excessive force on its surface. B. Do not handle the product by holding the flexible pattern portion in order to assure the Reliability C. Transparency is an important factor for the touch panel. Please wear clear finger sacks, gloves and mask to protect the touch panel from finger print or stain and also hold the portion outside the view area when handling the touch panel. D. Provide a space so that the panel does not come into contact with other components. E. To protect the product from external force, put a covering lens (acrylic board or similar board) and keep an appropriate gap between them. 9 DT024DTFT Displaytech Ltd. Rev 0.0 F. Transparent electrodes may be disconnected if the panel is used under environmental conditions where dew condensation occurs. G. Property of semiconductor devices may be affected when they are exposed to light, possibly resulting in IC malfunctions. H. To prevent such IC malfunctions, your design and mounting layout shall be done in the way that the IC is not exposed to light in actual use. 10.3 Static Electricity A. Ground soldering iron tips, tools and testers when they are in operation. B. Ground your body when handling the products. C. Power on the LCD module before applying the voltage to the input terminals. D. Do not apply voltage which exceeds the absolute maximum rating. E. Store the products in an anti-electrostatic bag or container. 10.4 Storage A. Store the products in a dark place at +25℃±10℃ with low humidity (40% RH to 60% RH). Don't expose to sunlight or fluorescent light. B. Storage in a clean environment, free from dust, active gas, and solvent. 10.5 Cleaning A. Do not wipe the touch panel with dry cloth, as it may cause scratch. B. Wipe off the stain on the product by using soft cloth moistened with ethanol. Do not allow ethanol to get in between the upper film and the bottom glass. It may cause peeling issue or defective operation. Do not use any organic solvent or detergent other than ethanol. 10.6 Cautions for installing and assembling Bezel edge must be positioned in the area between the Active area and View area. The bezel may press the touch screen and cause activation if the edge touches the active area. A gap of approximately 0.5mm is needed between the bezel and the top electrode. It may cause unexpected activation if the gap is too narrow. There is a tolerance of 0.2 to 0.3mm for the outside dimensions of the touch panel and tail. A gap must be made to absorb the tolerance in the case and connector. 10
DT024DTFT 价格&库存
很抱歉,暂时无法提供与“DT024DTFT”相匹配的价格&库存,您可以联系我们找货
DT024DTFT
  • 1+220.952191+28.71330
  • 16+206.4307316+26.82620
  • 32+199.2134932+25.88830
  • 80+190.8658280+24.80350
  • 160+184.17030160+23.93340
  • 240+179.90952240+23.37970
  • 384+175.12700384+22.75820
库存:30
DT024DTFT
  • 1+215.73576
  • 16+201.55381
  • 32+194.51074
  • 80+186.35372
  • 160+179.82571
  • 240+175.65737
  • 384+170.98595
库存:30
