SK-35DT
SK-35DT
    4DSYSTEMS
    SK-35DT
SK-35DT 数据手册
SK-35DT (Starter Kit) This item includes the following: • uLCD-35DT Display Module • • • • • 2GB microSD Card uUSB-PA5 Programming Adaptor 150mm 5 way Female-Female jumper cable, for quick connection to another device or breadboard 5 way Male-Male adaptor (for converting the Female-Female cable to be Male-Female) Quick Start User Guide SK-35DT (Starter Kit) 4D Systems highly recommends all first time buyers of 4D Systems’ displays, to purchase the Starter Kit when purchasing their first 4D Systems display solution. The Starter Kit provides all the hardware that is required to get the user up and running. Not all development environments and features will be needed by every user, however by purchasing the display solution in a Starter Kit, it ensures that if you want to take full advantage of the 4D Systems display solution and try out each of the 4D Workshop4 Environments, upgrade PmmC/firmware, you can. The Designer environment can utilise every feature of the display, however depending on the user requirements, a micro-SD (μSD) card may not be required. The μSD card is used when displaying images/video/sound, along with datalogging to μSD, and a programming cable is definitely required for downloading compiled code and PmmC/Firmware updates. The ViSi environment is the same as Designer in terms of feature utilisation, but is image based so requires a μSD card, along with a programming cable. The ViSi-Genie environment is also image based, and therefore requires a μSD card and programming cable also. The Serial environment does not require either a μSD or Programming cable to be used, however can utilise both depending on the user requirements. The μSD card can be used for such things as storage of multimedia files and datalogging, and the Programming cable for PmmC/Firmware updates, or changing to one of the other three programming environments. http://www.4dsystems.com.au/product/uLCD_35DT/ 11/5/2015
SK-35DT 价格&库存
很抱歉,暂时无法提供与“SK-35DT”相匹配的价格&库存,您可以联系我们找货
