MIKROE-240
MIKROE-240
    MIKRO
    DISPL GLCD 128X64 W/TOUCHPANEL
MIKROE-240 数据手册
SPECIFICATION CUSTOMER : MIKROELEKTRONIKA MODULE NO.: WDG0151-TMI-V#N00 APPROVED BY: ( FOR CUSTOMER USE ONLY ) PCB VERSION: SALES BY VERSION APPROVED BY DATE DATA: CHECKED BY REVISED SUMMARY PAGE NO. 0 2009/11/10 First issue 1 of 30 PREPARED BY MODLE NO: DOC. FIRST ISSUE RECORDS OF REVISION VERSION DATE 0 2009/11/10 REVISED PAGE NO. SUMMARY First issue 2 of 30 Contents 1.Module classification information 2.Precautions in Use of LCM 3.General Specification 4.Absolute Maximum Ratings 5.Electrical Characteristics 6.Optical Characteristics 7.Interface Pin Function 8.Counter Drawing & Block Diagram 9.Timing Characteristics 10.Display Control Instruction 11.Detailed Explanation 12.Reliability 13.Backlight Information 14.Inspection specification 15.Material List of Components for RoHs 3 of 30 1.Module Classification Information W D G 0151- T M I-   V# N00    Brand:WINSTAR DISPLAY CORPORATION  Custom:D  Display Type:H→ Character Type ; G→ Graphic Type N → LCD Display  Model serials no.0000 - ZZZZ  Backlight Type:  LCD Mode: N→ Without backlight P→ LED, Blue B→ EL, Blue green A→ LED, Amber D→ EL, Green R→ LED, Red W→ EL, White O→ LED, Orange F→ CCFL, White G→ LED, Green Y→ LED, Yellow Green T→ LED, White B→ TN Positive, Gray T→ FSTN Negative N→ TN Negative, G→ STN Positive, Gray Y→ STN Positive, Yellow Green M→ STN Negative, Blue F→ FSTN Positive  LCD Polarizer A→ Reflective, N.T, 6:00 H→ Transflective, W.T,6:00 Type/ D→ Reflective, N.T, 12:00 K→ Transflective, W.T,12:00 Temperature G→ Reflective, W. T, 6:00 C→ Transmissive, N.T,6:00 range/ View J→ Reflective, W. T, 12:00 F→ Transmissive, N.T,12:00 direction B→ Transflective, N.T,6:00 I→ Transmissive, W. T, 6:00 E→ Transflective, N.T.12:00 L→ Transmissive, W.T,12:00  Special Code V:Build in Negative Voltage N:IC NT7107,NT7108C # : Fit in with the ROHS Directions and regulations; 0:Sales code 0:Version 4 of 30 2.Precautions in Use of LCD Module (1)Avoid applying excessive shocks to the module or making any alterations or modifications to it. (2)Don’t make extra holes on the printed circuit board, modify its shape or change the components of LCD Module. (3)Don’t disassemble the LCM. (4)Don’t operate it above the absolute maximum rating. (5)Don’t drop, bend or twist LCM. (6)Soldering: only to the I/O terminals. (7)Storage: please storage in anti-static electricity container and clean environment. (8). Winstar have the right to change the passive components (9). Winstar have the right to change the PCB Rev. 3.General Specification ITEM STANDARD VALUE UNIT Number of dots 128 ×64 dots Outline dimension 78.0 (W) ×70.0 (H) ×14.3 (T) mm View area 62.0(W) ×44.0(H) mm Active area 56.3(W) ×38.38(H) mm Dot size 0.42(W) ×0.58(H) mm Dot pitch 0.44(W) ×0.60(H) mm LCD type View direction Backlight STN Negative, Blue, Transmissive (In LCD production, It will occur slightly color difference. We can only guarantee the same color in the same batch.) 6 o’clock LED , White 5 of 30 4.Absolute Maximum Ratings ITEM SYMBOL MIN. TYP. MAX. UNIT Operating Temperature TOP -20 - +70 ℃ Storage Temperature TST -30 - +80 ℃ Input Voltage VI 0 - VDD V Supply Voltage For Logic VDD-VSS 0 - 6.5 V Supply Voltage For LCD VDD-VLCD 0 - 17.0 V 5.Electrical Characteristics ITEM Logic Voltage SYMBOL CONDITION MIN. TYP. MAX. UNIT VDD-VSS - 4.5 5.0 5.5 V Ta=-20℃ - - - V Ta=25℃ 7.62 8.51 9.26 V Ta=+70℃ - - - V Supply Voltage For LCD VDD-VO *Note Input High Volt. VIH - 2.0 - VDD V Input Low Volt. VIL - 0 - 0.8 V Output High Volt. VOH - 2.4 - VDD V Output Low Volt. VOL - 0 - 0.4 V Supply Current IOP 5.0 2.8 3.1 3.4 mA * Note: Please design the VOP adjustment circuit on customer's main board Vdd VR 10K~20K Vo LCM Module Vee 6 of 30 6.Optical Characteristics ITEM View Angle Contrast Ratio SYMBAL CONDITION MIN TYP MAX UNIT (V)θ CR≧ 2 20 - 40 deg. (H)φ CR≧ 2 -30 - 30 deg. CR - - 3 - - T rise - - 200 300 ms T fall - - 150 200 ms Response Time Definitions ( Visual angle direction ) Brightness at selected state ( BS ) Brightness at non-selected state ( Bns ) Selected state CR = X Brightness (%) Z φ 6.1 Non-selected state Bs Bns θY Operating voltage for LCD driving ■ View Angles ■ Contrast Ratio ■ Response time Selected Condition Nonselected Condition 90 % 100 % Brightness Nonselected Condition 10 % tr Rise Time Page 7 of 30 7 of 30 td Decay Time ( fall time tf ) 7.Interface Pin Function Pin No. Symbol Level Description 1 CS1 L Select Segment 1 ~ Segment 64 2 CS2 L Select Segment 65 ~ Segment128 3 Vss 0V 4 VDD 5.0V 5 VO 6 D/I H/L H: Data , L: Instruction 7 R/W H/L H: Read(MPU Module) , L :Write(MPU→ Module) 8 E H Enable signal 9 DB0 H/L Data bus line 10 DB1 H/L Data bus line 11 DB2 H/L Data bus line 12 DB3 H/L Data bus line 13 DB4 H/L Data bus line 14 DB5 H/L Data bus line 15 DB6 H/L Data bus line 16 DB7 H/L Data bus line 17 RST L 18 VEE Negative Voltage Output 19 A Power supply for B/L(+) 20 K Power supply for B/L(-) Ground Supply voltage for logic (Variable) Operating voltage for LCD Reset the LCM 8 of 30 8.Counter Drawing & Block diagram 7 8 .0 2 .0 8 .0 5 6 .3 (A A ) 1 0 .8 5 2 0 - 1 .0 P T H 2 0 - 2 .0 P A D 1 1 4 .3 M a x 9 .7 20 64.92 1 2 8 X 6 4 D o ts 4 - 2 .5 P T H 4 - 5 .0 P A D 6 8 .0 1 .6 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 L E D B /L 0.6 0 .4 4 0 .4 2 T h e n o n -sp e cified to le ran c e o f d im e n sio n is 0.58 15.81 38.38(AA) 7.4 13.0 55.2 70.0 0.5 44.0(VA) 1 .8 2.54 P 2 .5 4 * 1 9 = 4 8 .2 6 2.54 1 3 .0 5 .0 0 .5 7 4 .0 6 2 .0 (V A ) D O T S IZ E S C A L E 1 0 /1 9 of 30 0 .3 m m . CS1 CS2 V ss VDD Vo D /I R /W E DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 RST VEE A K NT7108C Seg65~128 Seg Driver 80 series or 68 series E D/I R/W DB0~DB7 Com Driver NT7107C Com1~64 N.V. Generator MPU Seg Driver Bias and Power Circuit NT7108C Seg1~64 FR,M,CL,CLK1,CLK2 128X64 DOT CS1 CS2 RST Power on reset circuit Vdd VO Vss VR 10K or 20K Vee Optional External contrast adjustment. 10 of 30 9.Timing Characteristics MPU Interface Characteristic (T=25℃, VDD=+5.0V±0.5) Symbol Min Typ Max Unit E cycle tcyc 1000 - - ns E high level width twhE 450 - - ns E low level width twlE 450 - - ns E rise time tr - - 25 ns E tall time tf - - 25 ns Address set-up time tas 140 - - ns Address hold time tah 10 - - ns Data set-up time tdsw 140 - - ns Data delay time tddr - - 320 ns Data hold time (write) tdhw 10 - - ns Data hold time (read) tdhr 20 - - ns 11 of 30 12 of 30 10.Display Control Instruction The display control instructions control the internal state of the NT7108. Instruction is received from MPU to NT7108 for the display control. The following table shows various instructions. 13 of 30 11.Detailed Explanation The display data appears when D is 1 and disappears when D is 0. Though the data is not on the screen with D=0, it remains in the display data RAM. Therefore, you can make it appear by changing D=0 into D=1. SET ADDRESS (Y ADDRESS) Y address (AC0-AC5) of the display data RAM is set in the Y address counter. An address is set by instruction and increased by 1 automatically by read or write operations of display data. SET PAGE (X ADDRESS) X address (AC0-AC2) of the display data RAM is set in the X address register. Writing or reading to or from MPU is executed in this specified page until the next page is set. DISPLAY START LINE (Z ADDRESS) Z address (AC0-AC5) of the display data RAM is set in the display start line register and displayed at the top of the screen. When the display duty cycle is 1/64 or others (1/32-1/64), the data of total line number of LCD screen, from the line specified by display start line instruction, is displayed. 14 of 30 STATUS READ BUSY When BUSY is 1, the Chip is executing internal operation and no instructions are accepted. When BUSY is 0, the Chip is ready to accept any instructions. ON/OFF When ON/OFF is 1, the display is OFF. When ON/OFF is 0, the display is ON. RESET When RESET is 1, the system is being initialized. In this condition, no instructions except status read can be accepted. When RESET is 0, initializing has finished and the system is in usual operation condition. WRITE DISPLAY DATA Writes data (D0-D7) into the display data RAM. After writing instruction, Y address is increased by 1automatically. READ DISPLAY DATA Reads data (D0-D7) from the display data RAM. After reading instruction, Y address is increased by 1 automatically. 15 of 30 12.RELIABILITY Content of Reliability Test (wide temperature, -20℃~70℃ ℃) Environmental Test Test Item High Temperature storage Content of Test Endurance test applying the high storage temperature for a long time. Test Condition Note 80℃ 200hrs 2 Low Temperature storage Endurance test applying the high storage temperature for a long time. -30℃ 200hrs 1,2 High Temperature Operation Endurance test applying the electric stress (Voltage & Current) and the thermal stress to the element for a long time. 70℃ 200hrs —— Low Temperature Operation Endurance test applying the electric stress under low temperature for a long time. -20℃ 200hrs 1 The module should be allowed to stand at 60 High Temperature/ Humidity Operation Thermal shock resistance ℃,90%RH max For 96hrs under no-load condition excluding the polarizer, Then taking it out and drying it at normal temperature. The sample should be allowed stand the following 10 cycles of operation -20℃ 30min 25℃ 5min 1 cycle 70℃ 60℃,90%RH 96hrs -20℃/70℃ 10 cycles 1,2 —— 30min Vibration test Total fixed amplitude : 1.5mm Vibration Frequency : Endurance test applying the vibration during 10~55Hz transportation and using. One cycle 60 seconds to 3 directions of X,Y,Z for Each 15 minutes Static electricity test Endurance test applying the electric stress to the terminal. VS=800V,RS=1.5k CS=100pF 1 time Note1: No dew condensation to be observed. Note2: The function test shall be conducted after 4 hours storage at the normal Temperature and humidity after remove from the test chamber. 16 of 30 3 —— Note3: Vibration test will be conducted to the product itself without putting it in a container. 17 of 30 13.Backlight Information PARAMETER SYMBOL MIN TYP MAX UNIT Supply Current ILED 57.6 64 100 mA Supply Voltage V 3.4 3.5 3.6 V Reverse Voltage VR - - 5 V Luminous Intensity IV 282 344 - CD/M2 - 50K - Hr. LED Life Time (For Reference only) Color TEST CONDITION V=3.5V ILED=64mA ILED 64mA 25℃ ℃,50-60%RH, (Note 1) White Note: The LED of B/L is drive by current only, drive voltage is for reference only. drive voltage can make driving current under safety area (current between minimum and maximum). Note1 :50K hours is only a estimate for reference. 2.Drive from pin19,pin20 R A B/L K LCM 18 of 30 14. Inspection specification NO Item Criterion AQL 01 Electrical Testing 1.1 Missing vertical, horizontal segment, segment contrast defect. 1.2 Missing character , dot or icon. 1.3 Display malfunction. 1.4 No function or no display. 1.5 Current consumption exceeds product specifications. 1.6 LCD viewing angle defect. 1.7 Mixed product types. 1.8 Contrast defect. 0.65 02 Black or white spots on LCD (display only) 2.1 White and black spots on display 0.25mm, no more than three white or black spots present. 2.2 Densely spaced: No more than two spots or lines within 3mm 2.5 3.1 Round type : As following drawing 2.5 03 LCD black spots, white spots, contamination (non-display) 3.2 Line type : (As following drawing) Length Width --W L 0.02 W L 0.03 W 0.05 W --- 19 of 30 Acceptable Q TY Accept no dense 2.5 2 As round type 04 Polarizer bubbles If bubbles are visible, judge using black spot specifications, not easy to find, must check in specify direction. Size Acceptable Q TY Accept no dense 3 2 0 Total Q TY 20 of 30 3 2.5 NO Item 05 Scratches Criterion AQL Follow NO.3 LCD black spots, white spots, contamination Symbols Define: x: Chip length y: Chip width z: Chip thickness k: Seal width t: Glass thickness a: LCD side length L: Electrode pad length: 6.1 General glass chip : 6.1.1 Chip on panel surface and crack between panels: C 06 C C Chipped glass 2.5 C C C 21 of 30 C NO Item Criterion AQL x: Chip length y: Chip width z: Chip thickness k: Seal width t: Glass thickness a: LCD side length L: Electrode pad length 6.2 Protrusion over terminal : 6.2.1 Chip on electrode pad : C C C Glass 06 2.5 cra ck C C L 22 of 30 C L 23 of 30 NO Item 07 Cracked glass 08 Backlight elements Criterion AQL LCD 2.5 0.65 2.5 LCD 0.65 2.5 09 Bezel 0.65 C C C The height of the COB should not exceed the height indicated in the 10 PCB COB assembly diagram. 10.4 There may not be more than 2mm of sealant outside the seal area on the PCB. And there should be no more than three places. 10.5 No oxidation or contamination PCB terminals. 10.6 Parts on PCB must be the same as on the production characteristic chart. There should be no wrong parts, missing parts or excess parts. 10.7 The jumper on the PCB should conform to the product characteristic chart. 10.8 If solder gets on bezel tab pads, LED pad, zebra pad or screw hold pad, make sure it is smoothed down. 10.9 The Scraping testing standard for Copper Coating of PCB 2.5 2.5 0.65 2.5 2.5 0.65 0.65 2.5 2.5 X Y X * Y
MIKROE-240 价格&库存
很抱歉,暂时无法提供与“MIKROE-240”相匹配的价格&库存,您可以联系我们找货
