DT035BTFT-PTS1
DT035BTFT-PTS1
    DISPLAYTECH
    LCDDISPTFT3.5"320X240
DT035BTFT-PTS1 数据手册
TFT LCD Module Product Specification DT035BTFT-PTS1 3.5” (320(RGB) x 240 DOTS) TFT Module with Capacitive Touch Screen October 28, 2016 Remark: Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. Displaytech Ltd. Tel: (852) 2311 2080 ; Fax: (852) 2722 6998 ; Email: sales@displaytech.com.hk Address: 31E Billion Plaza 2, No. 10 Cheung Yue Street, Cheung Sha Wan, Kowloon, Hong Kong. Website: http://www.displaytech.com.hk Displaytech Ltd. DT035BTFT-PTS1 Rev 0.0 Revision Record REV 0.0 CHANGES First release DATE Oct 28, 2016 (Ref. 1.0 20160930) 1 Displaytech Ltd. DT035BTFT-PTS1 Rev 0.0 Table of Content Revision Record ...........................................................................1 1. Scope .....................................................................................3 2. Application ............................................................................3 3. General Information ..............................................................3 4. Outline Drawing ....................................................................4 5. Interface Signals ...................................................................5 6. Absolute Maximum Ratings .................................................5 7. Electrical Specifications .......................................................6 8. Command / AC Timing ..........................................................7 9. Optical Specification........................................................... 10 10. Environmental / Reliability Tests ....................................... 13 11. Precautions for Use of LCD Modules ................................ 13 2 DT035BTFT-PTS1 Displaytech Ltd. Rev 0.0 1. Scope This data sheet is to introduce the specification of DT035BTFT-PTS1, active matrix TFT module. It is composed of a color TFT-LCD panel, driver ICs, FPC, capacitive touch panel and a backlight unit. The 3.5” display area contains 320 (RGB) x 240 pixels. 2. Application Digital equipment which need color display, mobile phone, mobile navigator/video systems. 3. General Information Item Contents Unit Size 3.5 inch Resolution 320(RGB) x 240 / Interface CPU / Technology Type a-Si TFT / Pixel Configuration R.G.B. Vertical Stripe / Pixel Pitch 0.219 x 0.219 mm Outline Dimension (W x H x D) 76.90 x 64.00 x 4.8 mm Active Area 70.08 x 52.56 mm Display Mode Transmissive, Normally White / Backlight Type LED / Driver IC for PCAP FT5346 Weight TBD g 3 Displaytech Ltd. DT035BTFT-PTS1 4. Outline Drawing Displaytech DT035BTFT-PTS1 4 Rev 0.0 DT035BTFT-PTS1 Displaytech Ltd. Rev 0.0 5. Interface Signals No 1~5 6 7 8 9 10 11 12 13 14 15 16 ~ 39 40 41 42 43 44 45 Symbol NC VDD VDD RESET SPDA SPCK SPENA ENABLE HSYNC VSYNC DCLK DATA23 ~ DATA0 GND GND NC LEDA LEDK NC Description No connection Power supply Power supply Global reset pin SPI Serial data input/output SPI interface clock Serial port data enable signal Data enable input Horizontal sync input Vertical sync input Data clock Data bit Power ground Power ground No connection LED backlight (Anode) LED backlight (Cathode) No connection Remark CTP signal interface No. 1 2 3 4 5 6 Symbol SCL SDA VDD RESET INT GND Function Clock for the data input Data input Power supply Reset Interrupt output pin Ground 6. Absolute Maximum Ratings 6.1 Electrical absolute maximum ratings Parameter Power supply voltage Symbol VDD MIN -0.3 MAX 5.0 Unit V Remark 6.2 Environment conditions Parameter Operating Temperature Storage Temperature Symbol TOPR TSTG MIN -20 -30 5 MAX +70 +80 Unit C C Remark DT035BTFT-PTS1 Displaytech Ltd. Rev 0.0 7. Electrical Specifications 7.1 Electrical characteristics Item Supply voltage Low level Input signal voltage High level TFT Common electrode Voltage TFT Gata ON voltage TFT Gata OFF voltage Symbol VDD VIL VIH VcomH VcomL VcomH VcomL MIN 3 GND 0.8xVDD 2.5 -3 TYP 3.3 - MAX 3.6 0.1xVDD VDD 4.5 0 15 Unit V V V V V V V MAX 25 21.6 - Unit mA V Hr -10 Remark 7.2 LED backlight Item Forward current Forward voltage LED life time Symbol IF VF - MIN 16.8 - TYP 20 19.2 25,000 The figure below shows the connection of LED 6 Ta=25 C Remark Displaytech Ltd. DT035BTFT-PTS1 8. Command / AC Timing 8.1 AC Electrical Characteristics 8.2 24 Bit RGB Mode (@ SEL\[3:0] = 1100 or 1101) 7 Rev 0.0 Displaytech Ltd. DT035BTFT-PTS1 8.3 Timing Diagram 8 Rev 0.0 Displaytech Ltd. DT035BTFT-PTS1 8.4 Vertical Timing Diagram (HV Mode) 8.5 Vertical Timing Diagram (DE Mode) 9 Rev 0.0 DT035BTFT-PTS1 Displaytech Ltd. Rev 0.0 8.6 Input Data Timing (24 bit RGB mode for 960 x 240 @ SEL\[3:0] = 1100b) 9. Optical Specification Ta=25 C Item Contrast ratio Response time View angles Red Green Chromaticity Blue White NTSC Luminance Uniformity Symbol CR Tr / Tf T B L R x y x y x y x y Condition =0 25 C MIN 350 50 75 CR≧10 Brightness is on L U 10 TYP 500 10 65 55 65 65 0.51 0.34 0.31 0.56 0.15 0.14 0.28 0.33 60 480 80 MAX - Unit ms Degree Remark Note 1, 2 Note 1, 3 Note 4 Note 1, 5 % cd/m2 % Note 5 Note 1, 6 Note 1, 7 Displaytech Ltd. DT035BTFT-PTS1 Rev 0.0 Note 1: Definition of optical measurement system. Note 2: Contrast ratio is defined as follow: Note 3: Response time is defined as follow: Response time is the time required for the display to transition from black to white (Rise time, Tr) and from white to black (Decay Time, Tf). Note 4: Viewing angle range is defined as follow: Viewing angle is measured at the center point of the LCD. 11 DT035BTFT-PTS1 Displaytech Ltd. Rev 0.0 Note 5: Color chromaticity is defined as follow (CIE1931) Color coordinates measured at center point of LCD. Note 6: Luminance is defined as follow: Luminance is defined as the brightness of all pixels “White” at the center of display area on optimum contrast. Note 7: Luminance Uniformity is defined as follow: Active area is divided into 9 measuring areas (Refer Fig.2). Every measuring point is placed at the center of each measuring area. Fig. 2 Definition of uniformity 12 Displaytech Ltd. DT035BTFT-PTS1 Rev 0.0 10. Environmental / Reliability Tests No 1 2 3 4 5 6 Test Item High Temp Operation Low Temp Operation High Temp Storage Low Temp Storage High Temp & High Humidity Storage Thermal Shock (Non-operation) 7 ESD (Operation) 8 Vibration (Non-operation) 9 Shock (Non-operation) 10 Package Drop Test Inspection Appearance Alignment of LCD panel Electrical current Function / Display Condition Ta=+70 C, 120hrs Ta=-20 C, 120hrs Ta=+80 C, 120hrs Ta=-30 C, 120hrs Ta=+60 C, 90% RH, 120hrs -30 C 30 min ~ +80 C 30 min, Change time: 5 min, 10 cycles C=150pF, R=330Ω, 5points/panel Air:±8KV, 5 times; Contact:±4KV, 5 times Frequency range:10~55Hz, Stroke:1.5mm Sweep:10Hz~55Hz~10Hz 2 hours for each direction of X.Y.Z. 60G 6ms, ±X, ±Y, ±Z, 3 times, for each direction Height: 80cm, 1 corner, 3 edges, 6 surfaces Judgment Criteria Per table below Per table below Per table below Per table below Per table below (polarizer discoloration is excluded) Per table below Per table below Per table below Per table below Per table below Criterion (after test) No crack on the FPC, on the LCD panel No bubbles in the LCD panel No other defects of alignment in active area Within device specifications No broken circuit, no short circuit or no black line No other defects of display 11. Precautions for Use of LCD Modules 11.1 Safety The liquid crystal in the LCD is poisonous. Do not put it in your mouth. If the liquid crystal touches your skin or clothes, wash it off immediately using soap and water. 11.2 Handling a. The LCD and touch panel is made of plate glass. Do not subject the panel to mechanical shock or to excessive force on its surface. b. Do not handle the product by holding the flexible pattern portion in order to assure the reliability. c. Transparency is an important factor for the touch panel. Please wear clear finger sacks, gloves and mask to protect the touch panel from finger print or stain and also hold the portion outside the view area when handling the touch panel. d. Provide a space so that the panel does not come into contact with other components. e. To protect the product from external force, put a covering lens (acrylic board or similar board) and keep an appropriate gap between them. f. Transparent electrodes may be disconnected if the panel is used under environmental conditions where dew condensation occurs. 13 Displaytech Ltd. DT035BTFT-PTS1 Rev 0.0 g. Property of semiconductor devices may be affected when they are exposed to light, possibly resulting in IC malfunctions. h. To prevent such IC malfunctions, your design and mounting layout shall be done in the way that the IC is not exposed to light in actual use. 11.3 Static electricity a. Ground soldering iron tips, tools and testers when they are in operation. b. Ground your body when handling the products. c. Power on the LCD module before applying the voltage to the input terminals. d. Do not apply voltage which exceeds the absolute maximum rating. e. Store the products in an anti-electrostatic bag or container. 11.4 Storage a. Store the products in a dark place at +25 C±10 C with low humidity (40% RH to 60% RH). Don’t expose to sunlight or fluorescent light. b. Storage in a clean environment, free from dust, active gas, and solvent. 11.5 Cleaning a. Do not wipe the touch panel with dry cloth, as it may cause scratch. b. Wipe off the stain on the product by using soft cloth moistened with ethanol. Do not allow ethanol to get in between the upper film and the bottom glass. It may cause peeling issue or defective operation. Do not use any organic solvent or detergent other than ethanol. 11.6 Cautions for installing and assembling Bezel edge must be positioned in the area between the Active area and View area. The bezel may press the touch screen and cause activation if the edge touches the active area. A gap of approximately 0.5mm is needed between the bezel and the top electrode. It may cause unexpected activation if the gap is too narrow. There is a tolerance of 0.2 to 0.3mm for the outside dimensions of the touch panel and tail. A gap must be made to absorb the tolerance in the case and connector. 14
DT035BTFT-PTS1 价格&库存
很抱歉,暂时无法提供与“DT035BTFT-PTS1”相匹配的价格&库存,您可以联系我们找货
