DT070ATFT
DT070ATFT
    DISPLAYTECH
    LCDDISPTFT7.0"800X480
DT070ATFT 数据手册
Website: www.displaytech.com.hk LCD Module Product Specification Product: DT070ATFT & DT070ATFT-TS 7.0'' TFT Display Module (800RGBx480DOTS) Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. 3 November 2011. Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 1. REVISION RECORD VERSION CHANGES DATE 1.0 1.1 1.2 Initial revision Added DT070ATFT-TS mechanical drawing on page 5 Added “Power Consumption” section and changed the temperature range for –TS version 21 July 2011 25 July 2011 3 November 2011 1 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 Table of Content 1.   REVISION RECORD .......................................................................... 1   2.   Introduction .......................................................................................... 3   3.   General Specifications .......................................................................... 3   4.   Mechanical Drawing............................................................................. 4   5.   Interface Description ............................................................................ 6   6.   Absolute Maximum Ratings ................................................................ 7   7.   Electrical Characteristics ..................................................................... 7   8.   Power Consumption ............................................................................. 7   9.   Display Controller /Power Supply Timing ......................................... 7   10.   Backlight specification ......................................................................... 8   11.   Optical Characteristics......................................................................... 8   12.   Safety Precaution ................................................................................ 11   2 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 2. Introduction DT070ATFT and DT070ATFT-TS is a display module that contains a TFT display with a 480 * 800 RGB resolution. The driver used for this project is the Himax HX8264 + HX8664 or compatible and can display 16.7M colors. The driver is mounted on the glass and the interconnection via FPC including components to drive the display module. 3. General Specifications Item Specification Unit LCD mode Transmissive --- 800(RGB) Line 480 Line 7.0 Inch 164.90 mm 100.00 mm 154.08 mm 85.92 mm Optimum Viewing Direction 12 o’clock --- Driver IC Himax HX8264 + HX8664 --- Interface type RGB 24-bit with TCON --- Colours 16.7M --- Operation temperature range -20~70 °C Storage temperature range -30~80 °C Resolution Diagonal Size Overall Size Active area Remarks: (1) Recommended mating connector: Hirose FH19SC-50S-0.5SH, FH12S-50S-0.5SH; or Molex 0512965093, 0512965094; or equivalent (2) Color tune may be changed slightly by temperature and driving voltage. (3) RoHS compliant. Component Life Cycle 1) Storage Life: min. 1 Year 2) Operation Life (*1): min. 43 x 10³ h (24hr/day x 7days/week x 52weeks/year x 5years) (Not include backlight) 3) Storage and Operation Life Times are defined for a temperature of +25°C Notes: *1. Operation life ends when one of the listed faults occurs:  The on/off response-times reach 1.5 times of the max. value specified for a new display  The contrast is reduced to 0.5 of the original contrast value  Loss of function  The number of cosmetic defects exceeds the maximum defined 3 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS 4. Mechanical Drawing • DT070ATFT 4 Version: 1.2 Displaytech Ltd • LCD MODULE DT070ATFT / DT070ATFT-TS DT070ATFT-TS 5 Version: 1.2 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS 5. Interface Description Pin no 1~2 3~4 5 6 7 8 9 10 11 12 13~18 19 20 21~26 27 28 29~34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 • Pin no 1 2 3 4 Symbol VLED+ VLEDGND VCOM DVDD MODE DE VS HS B7 B6~B1 B0 G7 G6~G1 G0 R7 R6~R1 R0 GND DCLK GND L/R U/D VGH VGL AVDD RESET NC VCOM DITHB GND NC NC I/O ------I --I I I I I I I I I I I I I --I --I I ------I --I I ------- Description Power for LED backlight (anode) Power for LED backlight (cathode) Power ground 0V Common voltage input Power for digital circuit DE/SYNC mode select (“H” = DE mode; “L” = SYNC mode) Data enable signal, active high to enable data Vertical sync input, negative polarity Horizontal sync input, negative polarity Blue data (MSB) Blue data Blue data (LSB) Green data (MSB) Green data Green data (LSB) Red data (MSB) Red data Red data (LSB) Power ground 0V Clock for input data Power ground 0V Source left or right sequence control Gate up or down scan control Positive power of TFT Negative power of TFT Analog power supply Global reset pin No connection Common voltage input Dithering setting. “H” = 6bit resolution, “L” = 8bit resolution Power ground 0V No connection No connection Touch Screen Interface (DT070ATFT-TS only) Symbol XL YD XR YU I/O O O O O Description X+ channel output Y+ channel output X- channel output Y- channel output 6 Version: 1.2 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 6. Absolute Maximum Ratings (AGND=GND=0V; Ta=25°C) Item Power voltage Operating Temperature Storage Temperature Symbol Min. Max. Unit VCC AVDD VGH VGL TOP TST -0.5 -0.5 -0.3 VGH-42 -20 -30 + 5.0 13.5 +42 +0.3 +70 +80 V V V V °C °C Note: • When temperature is below 0°C, the response time of liquid crystal (LC) will be slower and the color of panel will be darker. • If module driving condition exceeds the absolute maximum ratings, permanent damaged may be resulted. If module is driven within the absolute maximum ratings but exceeded the DC characteristics, mal-function may be resulted. • VDD/VCC > VSS 7. Electrical Characteristics DC Characteristics (AGND=GND=0V; Ta=25°C) Item Symbol Min. Typ. Max. Unit Digital supply voltage Analog supply voltage Gate On voltage Gate Off voltage Common electrode driving signal Logic supply voltage Low level Input signal voltage High level Low level Output signal voltage High level VCC AVDD VGH VGL VCOM DVDD VIL VIH VOL VOH --------3.5 (2.8) 0 0.7xDVDD --DVDD-0.4 3.3 10.4 16 -7 --3.3 --------- --------4.5 (3.6) 0.3xDVDD DVDD GND+0.4 --- V V V V V V V V V 8. Power Consumption (GND=VSS=0V; Ta=25°C) Item Digital Supply Current Analog Supply Current Gate On Current Gate Off Current Power Consumption Symbol Condition Typ Max. Unit IDVDD V IAVDD IVGH IVGL Panel & Gamma Backlight Total DVDD=3.3 AVDD=10.4V VGH=16.0V VGL=-7.0V ------- 3.22 15.69 0.20 0.20 177.67 1.152 1.330 8.70 23.01 0.22 0.22 254.65 1.267 1.522 mA mA mA mA mW W W 9. Display Controller /Power Supply Timing See Display Controller Specification: Himax HX8264 + HX8664 7 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 10. Backlight specification Item (Vcc=3.3V, Vss=0V, Ta=25°C) Max Unit Note Symbol Min Typ Vf If ----- 9.6 20 --25 V mA WBL --- 1.152 1.267 W Supply voltage Forward current Backlight power consumption 18 LEDs Notes: 1) The LED’s driving condition is defined for each LED backlight (3 LEDs in series per line, and 6 lines per module). 2) In operation, constant forward current should be supplied, the forward voltage is for reference only. 11. Optical Characteristics Item Luminance Uniformity Viewing Angle Contrast ratio Response Time CIE (x,y) Chromaticity White Red Green Blue NTSC Ratio Symbol Condition Min (Vcc=3.3V, Vss=0V, Ta=25°C) Typ Max Unit Note L U θT θB θL θR Cr Tr Tf x y x y x y x y S θ=0º Ф=0º 200 --50 60 60 60 400 250 75 60 70 70 70 500 --------------- cd/m² % 1, 2 1, 2 deg 3 --- 1, 4 --- 25 --- ms 1, 5 0.267 0.284 0.567 0.305 0.289 0.483 0.092 0.049 --- 0.317 0.334 0.617 0.355 0.339 0.533 0.142 0.099 50 0.367 0.384 0.667 0.405 0.389 0.583 0.192 0.149 --- Cr≥10 θ=0º θ=0º 8 --- % 1, 6 Displaytech Ltd Note 1: LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 The data are measured after LEDs are turned on for 5 minutes. LCM displays full white. The brightness is the average value of 9 measured spots. Measurement equipment PR-705 (Φ8mm) Measuring condition: - Measuring surroundings: Dark room. - Measuring temperature: Ta=25°C. - Adjust operating voltage to get optimum contrast at the center of the display. Measured value at the center point of LCD panel after more than 5 minutes while backlight turning on. Note 2: The luminance uniformity is calculated by using following formula. L = L (Min.) / L (Max.)×100 (%) L (Max.) = Maximum brightness in 9 measured spots L (Min.) = Minimum brightness in 9 measured spots. W/3 W/3 L/3 L/3 L/6 W/6 Measurement equipment PR-705 (Φ8mm) Note 3: The definition of viewing angle: 9 Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 Note 4: The definition of contrast ratio (Test LCM using PR-705): Luminance When LCD is at “White” state Contrast Ratio (CR) = Luminance When LCD is at “Black” state (Contrast Ratio is measured in optimum common electrode voltage) Note 5: Definition of Response time. (Test LCD using DMS501): The output signals of photo detector are measured when the input signals are changed from “black” to “white” (falling time) and from “white” to “black” (rising time), respectively. The response time is defined as the time interval between the 10% and 90% of amplitudes. Refer to figure as below. The definition of response time Note 6: Definition of Color of CIE Coordinate and NTSC Ratio. Color gamut: area of RGB triangle area of NTSC triangle S= 10 x 100% Displaytech Ltd LCD MODULE DT070ATFT / DT070ATFT-TS Version: 1.2 12. Safety Precaution Handling precautions: • This device is susceptible to Electro-Static Discharge (ESD) damage. Observe Anti-Static precautions. Power supply precautions: • Identify and, at all times, observe absolute maximum ratings for both logic and LC there is some variance between models. drivers. Note that • Prevent the application of reverse polarity to VCC and GND, however briefly. • Use a clean power source free from transients. Power up conditions are occasionally “jolting” and may exceed the maximum ratings of the modules. • The VCC power of the module should also supply the power to all devices that may access the display. Don’t allow the data bus to be driven when the logic supply to the module is turned off. Operating precautions: • DO NOT plug or unplug the module when the system is powered up. • Minimize the cable length between the module and host MPU. • Operate the module within the limits of the modules temperature specifications. Mechanical/Environmental precautions: • Improper soldering is the major cause of module difficulty. Use of flux cleaner is not recommended as they may seep under the elastomeric connection and cause display failure. • Mount the module so that it is free from torque and mechanical stress. • Surface of the LCD panel should not be touched or scratched. The display front surface is an easily scratched, plastic polarizer. Avoid contact and clean only when necessary with soft, absorbent cotton dampened with petroleum benzene. • Always employ anti-static procedure while handling the module. • Prevent moisture build-up upon the module and observe the environmental constraints for storage temperature and humidity. • Do not store in direct sunlight • If leakage of the liquid crystal material should occur, avoid contact with this material, particularly ingestion. If the body or clothing becomes contaminated by the liquid crystal material, wash thoroughly with water and soap 11
DT070ATFT 价格&库存
很抱歉,暂时无法提供与“DT070ATFT”相匹配的价格&库存,您可以联系我们找货
