DT043BTFT-PTS1
DT043BTFT-PTS1
    DISPLAYTECH
    LCDDISPTFT4.3"480X272
DT043BTFT-PTS1 数据手册
TFT LCD Module Product Specification DT043BTFT-PTS1 4.3” (480(RGB) x 272 PIXELS) TFT Module with Capacitive Touch Panel October 28, 2016 Remark: Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. Displaytech Ltd. Tel: (852) 2311 2080 ; Fax: (852) 2722 6998 ; Email: sales@displaytech.com.hk Address: 31E Billion Plaza 2, No. 10 Cheung Yue Street, Cheung Sha Wan, Kowloon, Hong Kong. Website: http://www.displaytech.com.hk Displaytech Ltd. DT043BTFT-PTS1 Rev 0.0 Revision Record REV 0.0 CHANGES First release DATE Oct 28, 2016 (Ref. 1.0 20160930) - 1 Displaytech Ltd. DT043BTFT-PTS1 Rev 0.0 Table of Content Revision Record ...........................................................................1 1. Scope .....................................................................................3 2. Application ............................................................................3 3. General Information ..............................................................3 4. Outline Drawing ....................................................................4 5. Interface Signals ...................................................................5 6. Absolute Maximum Ratings .................................................6 7. Electrical Specifications .......................................................6 8. Optical Specification.............................................................7 9. Environmental / Reliability Tests ....................................... 10 10. Precautions for Use of LCD Modules ................................ 10 2 DT043BTFT-PTS1 Displaytech Ltd. Rev 0.0 1. Scope This data sheet is to introduce the specification of DT043BTFT-PTS1 active matrix TFT module. It is composed of a color TFT-LCD panel, driver ICs, FPC, capacitive touch panel and a backlight unit. The 4.3” display area contains 480 (RGB) x 272 pixels. 2. Application Digital equipments which need color display, mobile phone, mobile navigator/video systems. 3. General Information Item Contents Unit Size 4.3 inch Resolution 480(RGB) x 272 / Interface RGB / Technology Type a-Si TFT / Pixel Configuration R.G.B. Vertical Stripe / Outline Dimension (W x H x D) 105.50 x 67.20 x 4.7 mm Active Area 95.04 x 53.86 mm Display Mode Transmissive / Backlight Type LED / Driver IC HX8257A01 / Driver IC for PCAP FT5346 / Weight TBD g 3 Displaytech Ltd. DT043BTFT-PTS1 4. Outline Drawing Displaytech DT043BTFT-PTS1 4 Rev 0.0 DT043BTFT-PTS1 Displaytech Ltd. 5. Interface Signals Recommended connector: FH12-45S-0.5SH Pin No. 1-2 3 4 5-12 13-20 21-28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 Symbol GND VDD RESET R0 ~ R7 G0 ~ G7 B0 ~ B7 PCLK DISP HSYNC VSYNC ENABLE U/D L/R CS SCL SDI SDO XR (NC) YD (NC) XL (NC) YU (NC) K A I/O P P I I I I I I I I I I I I I I O O O O O P P Function Ground Power supply Reset the display, active low Red data bus Green data bus Blue data bus Data clock Display ON/OFF control Horizontal synchronous signal input Vertical synchronous signal input Data enable pin Select up or down scanning direction Select left or right scanning direction Chip select signal Serial clock signal Serial in signal Serial out signal Touch panel control pin (NC) Touch panel control pin (NC) Touch panel control pin (NC) Touch panel control pin (NC) LED backlight (Cathode) LED backlight (Anode) CTP signal interface Pin No. 1 2 3 4 5 6 Symbol SCL SDA VDD WAKE INT GND Function Clock for the data input Data input Power supply Interrupt output pin Ground 5 Rev 0.0 DT043BTFT-PTS1 Displaytech Ltd. Rev 0.0 6. Absolute Maximum Ratings 6.1 Electrical absolute maximum ratings Parameter Symbol MIN MAX Unit Remark Power Supply Voltage VCC -0.3 3.6 V Notes: 1. If the module is above these absolute maximum ratings. It may become permanently damaged. Using the module within the following electrical characteristic conditions are also exceeded, the module will malfunction and cause poor reliability. 2. VCC > VSS must be maintained. 6.2 Environment conditions Parameter Symbol MIN MAX Unit Operating Temperature TOPR -20 +70 C Storage Temperature TSTG -30 +80 C Note: 1. The response time will become lower when operated at low temperature. 2. Background color changes slightly depending on ambient temperature. The phenomenon is reversible. 3. Ta=40℃:Absolute humidity must be lower than the humidity of 85%RH at 40℃. Remark 7. Electrical Specifications 7.1 Electrical characteristics GND=0V, Ta=25C Item Power Supply Input Voltage Current Consumption Clock Frequency H L Symbol VDD VIH VIL ICC1 ICC2 fCLK Condition Ta=25C VDD=3.3V VDD=3.3V Normal mode Sleep mode - MIN 3.0 0.8VDD 0 - TYP 3.3 20 0.05 9 MAX 3.6 VDD 0.2VDD 30 0.1 12 Unit V V V mA mA MHz Remark Note: Tested in 1╳1 chessboard pattern. 7.2 LED backlight Ta=25C Item Symbol MIN TYP MAX Unit Remark Forward current IF 40 mA Forward voltage VF 15 V LED life time 20,000 Hr Note Note 1: The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL =40mA. The LED lifetime could be decreased if operating IL is larger than40mA. Note 2: Backlight should be driven in constant current mode. Use a supply voltage of 17 Volts or higher with a series resistor to limit the current to 40 mA (e.g. (17V - (5 x 3.2V) )/0.040 = 25 ohms). Alternatively, the backlight can be driven from lower voltages with a boost LED driver such as the ON Semiconductor CAT4139. 6 DT043BTFT-PTS1 Displaytech Ltd. Rev 0.0 8. Optical Specification Ta=25C Item Contrast ratio Response time View angles White Red Chromaticity Green Blue NTSC Ratio Luminance Uniformity Symbol CR Tr Tf T B L R x y x y x y x y S L U Condition =0 MIN 350 50 350 - 25C CR≧10 Brightness is on Note 1: Definition of optical measurement system. Note 2: Contrast ratio is defined as follow: 7 TYP 500 10 10 55 65 65 65 0.285 0.331 TBD TBD TBD TBD TBD TBD 60 48/0 80 MAX - Unit Remark Note 1, 2 ms Note 1, 3 Degree Note 4 Note 1, 5 % cd/m2 % Note 1, 5 Note 1, 6 Note 1, 7 Displaytech Ltd. DT043BTFT-PTS1 Rev 0.0 Note 3: Response time is defined as follow: Response time is the time required for the display to transition from black to white (Rise time, Tr) and from white to black (Decay Time, Tf). Note 4: Viewing angle range is defined as follow: Viewing angle is measured at the center point of the LCD. Note 5: Color chromaticity is defined as follow (CIE1931) Color coordinates measured at center point of LCD. 8 Displaytech Ltd. DT043BTFT-PTS1 Rev 0.0 Note 6: Luminance is defined as follow: Luminance is defined as the brightness of all pixels “White” at the center of display area on optimum contrast. Note 7: Luminance Uniformity is defined as follow: Active area is divided into 9 measuring areas (Refer Fig.2). Every measuring point is placed at the center of each measuring area. Fig. 2 Definition of uniformity 9 Displaytech Ltd. DT043BTFT-PTS1 Rev 0.0 9. Environmental / Reliability Tests No 1 2 3 4 5 6 7 8 9 10 Test Item High Temp Operation Low Temp Operation High Temp Storage Low Temp Storage High Temp & High Humidity Storage Thermal Shock (Non-operation) ESD (Operation) Vibration (Non-operation) Shock (Non-operation) Package Drop Test Inspection Appearance Alignment of LCD panel Electrical current Function / Display Condition Ta=+70C, 96hrs Ta=-20C, 96hrs Ta=+80C, 96hrs Ta=-30C, 96hrs Ta=+60C, 90% RH, 96hrs -30℃ 30 min~+80℃ 30 min, Change time:5min, 5 Cycles C=150pF, R=330Ω, 5points/panel Air:±8KV, 5times; Contact:±4KV, 5 times; Judgment Criteria Per table below Per table below Per table below Per table below Per table below (polarizer discoloration is excluded) Per table below Per table below 10Hz~150Hz, 100m/s2, 120min Per table below Half- sine wave,300m/s2,11ms Per table below Height: 80cm, 1 corner, 3 edges, 6 surfaces Per table below Criterion (after test) No crack on the FPC, on the LCD panel No bubbles in the LCD panel No other defects of alignment in active area Within device specifications No broken circuit, no short circuit or no black line No other defects of display 10. Precautions for Use of LCD Modules 10.1 Safety The liquid crystal in the LCD is poisonous. Do not put it in your mouth. If the liquid crystal touches your skin or clothes, wash it off immediately using soap and water. 10.2 Handling a. The LCD and touch panel is made of plate glass. Do not subject the panel to mechanical shock or to excessive force on its surface. b. Do not handle the product by holding the flexible pattern portion in order to assure the reliability. c. Transparency is an important factor for the touch panel. Please wear clear finger sacks, gloves and mask to protect the touch panel from finger print or stain and also hold the portion outside the view area when handling the touch panel. d. Provide a space so that the panel does not come into contact with other components. e. To protect the product from external force, put a covering lens (acrylic board or similar board) and keep an appropriate gap between them. f. Transparent electrodes may be disconnected if the panel is used under environmental conditions where dew condensation occurs. g. Property of semiconductor devices may be affected when they are exposed to light, possibly resulting in IC malfunctions. 10 Displaytech Ltd. DT043BTFT-PTS1 Rev 0.0 h. To prevent such IC malfunctions, your design and mounting layout shall be done in the way that the IC is not exposed to light in actual use. 10.3 Static electricity a. Ground soldering iron tips, tools and testers when they are in operation. b. Ground your body when handling the products. c. Power on the LCD module before applying the voltage to the input terminals. d. Do not apply voltage which exceeds the absolute maximum rating. e. Store the products in an anti-electrostatic bag or container. 10.4 Storage a. Store the products in a dark place at +25C±10C with low humidity (40% RH to 60% RH). Don’t expose to sunlight or fluorescent light. b. Storage in a clean environment, free from dust, active gas, and solvent. 10.5 Cleaning a. Do not wipe the touch panel with dry cloth, as it may cause scratch. b. Wipe off the stain on the product by using soft cloth moistened with ethanol. Do not allow ethanol to get in between the upper film and the bottom glass. It may cause peeling issue or defective operation. Do not use any organic solvent or detergent other than ethanol. 10.6 Cautions for installing and assembling Bezel edge must be positioned in the area between the Active area and View area. The bezel may press the touch screen and cause activation if the edge touches the active area. A gap of approximately 0.5mm is needed between the bezel and the top electrode. It may cause unexpected activation if the gap is too narrow. There is a tolerance of 0.2 to 0.3mm for the outside dimensions of the touch panel and tail. A gap must be made to absorb the tolerance in the case and connector. 11
DT043BTFT-PTS1 价格&库存
很抱歉,暂时无法提供与“DT043BTFT-PTS1”相匹配的价格&库存,您可以联系我们找货
