2.2" 18-bit color TFT LCD display with
microSD card breakout
PRODUCT ID: 1480
Description
This lovely little display breakout is the best way to add a small, colorful and bright
display to any project. Since the display uses 4-wire SPI to communicate and has its own
pixel-addressable frame buffer, it can be used with every kind of microcontroller. Even a
very small one with low memory and few pins available!
The 2.2" display has 320x240 color pixels. Unlike the low cost "Nokia 6110" and similar
LCD displays, which are CSTN type and thus have poor color and slow refresh, this
display is a true TFT! The TFT driver (ILI9340 or compatible) can display full 18-bit
color (262,144 shades!). And the LCD will always come with the same driver chip so
there's no worries that your code will not work from one to the other.
The breakout has the TFT display soldered on (it uses a delicate flex-circuit connector) as
well as a ultra-low-dropout 3.3V regulator and a 3/5V level shifter so you can use it with
3.3V or 5V power and logic. We also had a little space so we placed a microSD card
holder so you can easily load full color bitmaps from a FAT16/FAT32 formatted
microSD card. The microSD card is not included.
Of course, we wouldn't just leave you with a datasheet and a "good luck!" - we've written
a full open source graphics library that can draw pixels, lines, rectangles, circles, text and
bitmaps as well as example code. The code is written for Arduino but can be easily
ported to your favorite microcontroller! Wiring is easy, we strongly encourage using the
hardware SPI pins of your Arduino as software SPI is noticeably slower when dealing
with this size display. Check the example sketches for wiring help until we get a detailed
wiring tutorial written!
Technical Details
Specifications:
o
o
o
o
o
o
o
o
o
o
o
o
o
o
o
o
2.2" diagonal LCD TFT display
320x240 resolution, up to 18‐bit (262,144) color
4 wire SPI digital interface ‐ this display talks in '8‐bit' SPI check the Arduino library
source for how to communicate
Built‐in microSD slot ‐ uses 2 more digital lines
5V compatible! Use with 3.3V or 5V logic
Onboard 3.3V @ 150mA LDO regulator
4 white LED backlight, transistor connected so you can PWM dim the backlight
0.1" spaced header for easy breadboarding
Max Dimensions: 40.63mm / 1.59" x 66.35mm / 2.61" x 6.05mm / 0.23"
LCD Dimensions: 55.23mm / 2.17" x 40mm / 1.57" x 2.46mm / 0.09"
Weight: 18.43g
Current draw is based mostly on the backlight: with full on backlight, current draw is
approx 100mA
Adafruit Fritzing Library
ILI9340 (datasheet) controller with built in pixel‐addressable video RAM buffer
Display datasheet
EagleCAD files on GitHub
As of January 12, 2016 the LCD may come with an ILI9340-compatible chip
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1480”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+229.690101+28.81470
