7.0" 40-pin TFT Display - 800x480 without
Touchscreen
PRODUCT ID: 2353
Description
This 7.0" TFT screen has lots of pixels, 800x480 to be exact, and an LED backlight. Its great for when you
need a lot of space for graphics. These screens are commonly seen in consumer electronics, such as
miniature TV's, GPS's, handheld games car displays, etc. A 40-pin connector has 8 red, 8 green, and 8 blue
parallel pins, for 24 bit color capability.
This version does not have touchscreen attached It's exactly the same TFT display as PID 2354 but
without the resistive touch panel so it is a little less expensive.
This is a "raw pixel-dot-clock" display and does not have an SPI/parallel type controller or any kind of
RAM. The display is supposed to be constantly refreshed, at 60Hz, with a pixel clock, V sync, H sync, etc.
There are some high end processors such as that used in the BeagleBone that can natively support such
RGB TTL displays. However, it is extremely rare for a small microcontroller to support it, as you need
dedicated hardware or a very fast processor such as an FPGA. Not only that, but the backlight requires a
125-150mA constant-current mode boost converter that can go as high as 9V instead of our other small
displays that can run the backlight off of 5V
For that reason, we are carrying it as a companion to the Adafruit RA8875 driver board in the store, which
is a chip that can handle the huge video RAM and timing requirements, all in the background. That's the
best way to interface this display to just about any microcontroller (including Arduino & friends) If you
want to control with from an HDMI or DVI output, check out our TFP401 driver board. If you are an
advanced electronics enthusiast you can try wiring this directly to your processor, but it we don't have any
support or tutorials for that purpose.
Technical Details
o
Dimensions: 164mm x 100mm x 4mm / 6.5" x 3.9" x 0.2"
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2353”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+280.282861+36.25460
