MIKROE-2276
MIKROE-2276
    MIKRO
    MIKROMEDIA HMI 3.5" RES
MIKROE-2276 数据手册
MIKROE-2276 OVERVIEW Summary A smart display solution, mikromedia HMI 3.5" Res has a 320x240px color display with a resistive touch panel on the front, and a powerful FT900Q 32-bit MCU with additional essential circuitry on the back - making it a standalone but cost-effective solution suitable for industrial applications. MCU mikromedia HMI boards are driven by FTDI Chip's FT900Q with their proprietary 32-bit RISC core with industryleading performance. With execution from shadow memory, the MCU can achieve speeds of 3.1 DMIPS/MHz at 100 MHz. FT900Q has 256KB of Flash memory, a small part of which is taken by the built-in bootloader. Additional circuitry The concept of mikromedia HMI is to keep only the essential components that simplify its integration into a final product, whilst keeping overall costs down. The board integrates a microSD card for expanding storage capacity, a haptic feedback motor, small audio speaker, and a micro USB connector. A connector for interfacing the MCU with external electronics, along with a separate connector for FT900Q's parallel camera interface. Display mikromedia for HMI 3.5" Res has a high-quality Riverdi display with 16.7M color depth and 550 NIT brigtness. The display is driven by a FT812 graphic controller. A mounting frame surrounding the screen simplifies integration. MIKROE-2276 KEY FEATURES • Size: 3.5” • Resolution: 240x320 • Brightness: 450 • MCU: FT900Q Speed: 100MHz; 310 DMIPS Memory: 256 KB Flash Peripherals include: 2xCAN, 2xSPI, 2xI2C, I2S, UART • Graphic controller: FT812 • Touchscreen: Resistive • Interface: Main connector, Camera connector, Micro USB • Storage: 8MB Flash + MicroSD card slot • Audio speaker • Mounting frame MIKROE-2276 COMPARISON CHART See how mikromedia HMI 3.5" Res compares with the rest of the product line. Product Name Size Resolution Touch Panel Luminosity mikromedia HMI 3.5" 3.5" 320 x 240 None 540 mikromedia HMI 3.5" Res 3.5" 320 x 240 Resistive mikromedia HMI 3.5" Cap 3.5" 320 x 240 mikromedia HMI 4.3" 4.3" mikromedia HMI 4.3" Res Active Area Graphics Controller Haptic Feedback Dot Pitch (mm2) 70.08 x 52.56 FT812 No 0.73 x 0.219 450 70.08 x 52.56 FT812 No 0.73 x 0.219 Capacitive 480 70.08 x 52.56 FT813 No 0.73 x 0.219 480 x 272 None 550 95.04 x 53.86 FT812 Yes 0.066 x 0.198 4.3" 480 x 272 Resistive 440 95.04 x 53.86 FT812 Yes 0.066 x 0.198 mikromedia HMI 4.3" Cap 4.3" 480 x 272 Capacitive 500 95.04 x,53.86 FT813 Yes 0.066 x 0.198 mikromedia HMI 4.3" UXB 4.3" 480 x 272 Capacitive, UX Black 500 95.04 x 53.86 FT813 Yes 0.066 x 0.198 mikromedia HMI 4.3" UXW 4.3" 480 x 272 Capacitive, UX White 500 95.04 x 53.86 FT813 Yes 0.066 x 0.198 mikromedia HMI 5" 5.0" 800 x 480 None 600 118.00 x 64.80 FT812 Yes 0.045 x 0.135 mikromedia HMI 5" Res 5.0" 800 x 480 Resistive 480 118.00 x 64.80 FT812 Yes 0.045 x 0.135 mikromedia HMI 5" Cap 5.0" 800 x 480 Capacitive 510 118.00 x 64.80 FT813 Yes 0.045 x 0.135 mikromedia HMI 5" UXB 5.0" 800 x 480 Capacitive, UX Black 510 118.00 x 64.80 FT813 Yes 0.045 x 0.135 mikromedia HMI 5" UXW 5.0" 800 x 480 Capacitive, UX White 510 118.00 x 64.80 FT813 Yes 0.045 x 0.135 mikromedia HMI 7" 7.0" 800 x 480 None 400 154.08 x 85.92 FT812 Yes 0.045 x 0.135 mikromedia HMI 7" Res 7.0" 800 x 480 Resistive 320 154.08 x 85.92 FT812 Yes 0.045 x 0.135 mikromedia HMI 7" Cap 7.0" 800 x 480 Capacitive 350 154.08 x 85.92 FT813 Yes 0.045 x 0.135 mikromedia HMI 7" UXB 7.0" 800 x 480 Capacitive UX Black 350 154.08 x 85.92 FT813 Yes 0.045 x 0.135 mikromedia HMI 7" UXW 7.0" 800 x 480 Capacitive UX White 350 154.08 x 85.92 FT813 Yes 0.045 x 0.135 TOOLS AND ACCESSORIES • There’s no use for a fast chip if it slows you down as a developer and mikroC, mikroBasic and mikroPascal for FT90x do just the opposite — they make you more productive. Out of the box, the compilers have more than 500 functions and more than 150 examples. Currently, these are the only dedicated FT90x compilers on the market. mikromedia HMI developers should look no further. • Visual TFT is a drag-and-drop GUI design tool that generates code compatible with mikroC, mikroBasic and mikroPascal for FT90x. It dramatically simplifies the process of designing and programming graphical user interfaces. With full support for both FT812 and FT813 graphic controllers, Visual TFT is the final part of the mikromedia HMI development equation. • The mikromedia HMI breakout board is a simple accessory that conveniently enables developers to access pins from the onboard FT900Q MCU. This simplifies development in the prototyping phase. This board also contains a microUSB port, an RJ-45 ethernet connector, as well as an external programmer connector (ideally used with mikroProg for FT90x). • The mikromedia HMI board connects to external electronics via standard 24-pin flat cable connectors. A single cable is included in the mikromedia box. With the breakout board you get two. Replacement cables are also available if the original cables wear out after prolonged use. http://www.mikroe.com/mikromedia-hmi/35-res/ 6/1/2016
MIKROE-2276 价格&库存
很抱歉,暂时无法提供与“MIKROE-2276”相匹配的价格&库存,您可以联系我们找货
MIKROE-2276
  • 1+1111.552441+143.80898
