90-00003-A1
90-00003-A1
    PDA
    Capacitive Graphic LCD Display Module Transmissive Red, Green, Blue (RGB) TFT - Color SPI, Parallel ...
90-00003-A1 数据手册
Features • Complete Module for Standalone Use: • • • • • • – Atmel XMEGA256A3BU MCU – Projected Capacitive Multi Touch Controller – 2.8in LCD – USB Connectivity – SD Card – Expansion Header for Development (PCB Rev A2) MCU: – ATXMEGA256A3BU – 256KBytes Flash / 8Kbytes Boot – 16KBytes RAM – 4KBytes EEPROM – USB 2.0 Full speed (12Mbps) and low speed (1.5Mbps) Storage: – SD/MMC Touch: – Atmel maXTouch mXT143E Touch Controller – Supports up to 8 touches Display: – Displaytech SDT028ATFT 2.8in LCD – 320x240 resolution – 20 ms typical response time – SPI interface via ILI9341 / ILI9320 (or compatible) – Optional support for 18-bit parallel interface – White LED backlight Cover Panel: – 1.2mm Soda Lime Glass – Optional 0.7mm Gorilla Glass™ Expansion Header: (PCB Rev A2) – Hirose DF40C series mezzanine connector – I2C, SPI and USART Buses – Interrupts – I/O – ADC, DAC, Analog Comparator – Timer OC, PWM/AWeX PDA TM2801: 2.8in PCAP Touch Module 1303-5-6   Contents 1 2 Module Overview 1.1 PCB Connections 4 1.2 Debug Connector J1 6 1.3 Touch Sensor Flex Connector J2 6 1.4 Display Flex Connector J3 7 1.5 Programming/Debug J4 7 1.6 Universal Serial Bus (USB) J5 8 1.7 Expansion J6 8 1.8 SD/MMC U5 9 1.9 XMEGA U4 10 Overview of the 2.8in PCAP Touch Module Introduction 11 2.2 Understanding Unfamiliar Concepts 12 2.3 XMEGA A3BU Microcontroller 12 Atmel Software Framework 12 2.4 LCD Panel 2.4.1 2.5 2.6 maXTouch Controller Interface SD/MMC Connector 2.6.1 2.7  2 Atmel Software Framework maXTouch Capacitive Touchscreen Controller 2.5.1 4 11 2.1 2.3.1 3 4 Atmel Software Framework Expansion Interface Getting Started 12 13 13 13 14 14 14 15 3.1 Hardware Setup 15 3.2 Demo Firmware 15 3.3 Loading Firmware 15 3.3.1 Programming Tools 15 3.3.2 Programming the Example Code 15 Specifications 16 4.1 Mechanical Specifications 16 4.2 Absolute Maximum Specifications 18 4.3 Recommended Operating Conditions 18 4.4 DC Specifications 18 4.5 I2C-compatible Bus Specifications 18 4.6 Power Consumption 19 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 4.7 5 Part Number 2.8in PCAP Touch Module 19 I2C Basics (I2C-compatible Operation) 20 5.1 Interface Bus 20 5.2 Transferring Data Bits 20 5.3 START and STOP Conditions 20 5.4 Address Byte Format 21 5.5 Data Byte Format 21 5.6 Combining Address and Data Bytes into a Transmission 22 6 Revision History 23 7 Notes 24   3 1 Module Overview 1.1 PCB Connections USB SD/MMC Debug / Programming J5 U5 Pin 1 J4 Pin 1 TouchJ2 Sensor Flex J3 Display Flex AT M EL XM EGA256A3BU AT M EL MXT143E J1 Debug Pin 1 Pin 1 Figure 1 - PCB Connectors (10-01034-A1)  4 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module USB SD/MMC Debug / Programming J5 U5 Pin 1 J4 Pin 1 Touch Sensor Flex J2 Display J3 Flex AT M EL XM EGA256A3BU AT M EL MXT143E Pin 1 Pin 1 J6 Expansion Figure 2 – Main PCB Connectors (10-01034-A2) NOTE: The SD/MMC Slot (U5) is on the underside of the PCB Pin 1 Pin 1 Figure 3 – Expansion PCB (10-01052-A0) The following abbreviations and notations are used for the pin descriptions below. Note signal direction is given with respect to the touch module and on-board MCU – not the device connected: maXTouch touchscreen LCD LCD Panel SD SD/MMC USB Universal Serial Bus Exp Expansion (PCB Rev A2 or greater) MXT I Input only O Output only, push-pull XMega Port Identification of XMega Port/Pin OD Open drain output P Power or Ground   5 1.2 Debug Connector J1 Connector J1 carries signals used to debug the MaXTouch Touchscreen Controller. Debug Connector is only present on the 10-01034-A1 revision PCB. As of the 10-01034-A2 revision PCB, these signals are accessible on the Expansion connector. Pin Type Description Pin Type Description 2 1 P +5Vdc 6 I/O 2 - N/C 7 I ~MXT_RESET (1) 3 O ~MXT_CHG (1) 8 P GND 4 - N/C 9 O MXT DBG DATA 10 O MXT DBG CLK 5 I 2 I C SDA (2) I C SCL (2) NOTE 1 – Pulled up through 47kΩ resistor NOTE 2 – Pulled up through 3.3kΩ resistor 1.3 Touch Sensor Flex Connector J2 Connector J2 connects to the touch sensor flex and carries signals used by the maXTouch controller to detect input on the touch sensor.  6 Pin Type 1 I/O 2 I/O 3 Description Pin Type X1 14 I/O Y6 X3 15 I/O Y7 I/O X5 16 I/O Y8 4 I/O X7 17 I/O Y9 5 I/O X9 18 I/O Y10 6 I/O X11 19 P GND 7 P GND 20 I/O X12 8 I/O Y0 21 I/O X10 9 I/O Y1 22 I/O X8 10 I/O Y2 23 I/O X6 11 I/O Y3 24 I/O X4 12 I/O Y4 25 I/O X2 13 I/O Y5 26 I/O X0 PDA TM2801: 2.8in PCAP Touch Module Description 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 1.4 Display Flex Connector J3 Connector J3 connects to the LCD panel flex and carries signals between the host and the LCD panel. Pin Type 1 P 2 3 Description Pin Type Description Vin 24 O GND (DB8) P LED_K1 (Backlight Cathode) 25 O GND (DB7) P LED_K2 (Backlight Cathode) 26 O GND (DB6) 4 P LED_K3 (Backlight Cathode) 27 O GND (DB5) 5 P LED_K4 (Backlight Cathode) 28 O GND (DB4) 6 - N/C (IM0) 29 O GND (DB3) 7 - N/C (IM1) 30 O GND (DB2) 8 - N/C (IM2) 31 O GND (DB1) 9 - N/C (IM3) 32 O GND (DB0) 10 - N/C (FMARK) 33 O ~CS (1) 11 O GND (VSYNC) 34 O WR 12 O GND (HSYNC) 35 O RS / SCL 13 O GND (DOTCLK) 36 O GND (RD) 14 O GND (ENABLE) 37 O RESET (1) 15 O GND (DB17) 38 I SDO 16 O GND (DB16) 39 O SDI 17 O GND (DB15) 40 P Vdd 18 O GND (DB14) 41 P GND 19 O GND (DB13) 42 - Reserved (RES1) 20 O GND (DB12) 43 - Reserved (mXT ~CHG) (1) 21 O GND (DB11) 44 - Reserved (SDA) (2) 22 O GND (DB10) 45 - Reserved (SCL) 23 O GND (DB9) (2) NOTE 1 – Pulled up through 47kΩ resistor NOTE 2 – Pulled up through 3.3kΩ resistor 1.5 Programming/Debug J4 Connector J4 connects to the MCU’s PDI programming and debug interface. Pin Type 1 I/O 2 3 Description Pin Type Description PDI_DAT 4 - N/C P Vdd 5 I ~RESET / PDI_CK - N/C 6 P GND   7 1.6 Universal Serial Bus (USB) J5 Connector J5 connects to the MCU’s USB interface. Pin Type 1 P 2 Description Pin Type Description +5VBUS 6 P GND I/O D- 7 P GND 3 I/O D+ 8 P GND 4 - N/C 9 P GND 5 P GND 1.7 Expansion J6 Connector J6 ( Hirose DF40-C-30DS-0.4V(51) ) provides access to many system signals as well as additional I/O and signals to support development and prototyping. The Expansion Interface PCB (10-01052-A0) can be used to access these signals. Signals on the Expansion PCB follow the same sequence as shown in the table below. See section 2.7 for additional details. 1 P 2 P 3 I/O 4 O Description Vin Vin I2C SDA (2) 2 I C SCL (2) 5 I ~MXT_CHG 6 O WR (1) (1) Pin Type 16 I Description MXT LCD SD XMega Port Pin Type MXT LCD SD XMega Port Note: Some signals provided through the Expansion Interface are used by the system – these signals are indicated via gray highlighting in the table below. Care should be taken when using this interface and these pins in particular to ensure the effect on system operation is understood and no damage will occur. Refer to the Atmel XMega256A3BU datasheet for details on available pin functions. ~SD_Detect (1)  B1 (1)  17 O ~RESET_LCD  C0 18 I/O INT, ADC, AC, DAC B3  C1 19 I/O INT, ADC, AC, DAC, JTAG B4  C2 20 I/O INT, ADC, AC, DAC, JTAG B5  C3 21 I/O INT, ADC, AC, DAC, JTAG B6  C4 22 I/O INT, ADC, AC, DAC, JTAG B7 O LED_EN XMEGA: ~RESET / PDI_CK 7 O ~CS 8 O MOSI   C5 23  9 I MISO   C6 24 I 10 O SCK   C7 25 I/O XMEGA: PDI_DAT 11 I/O INT, TC, I2C: SDA E0 26 O ~RESET_MXT (1)  12 I/O INT, TC, I2C SCL,USART: XCK E1 27 O MXT DBG DATA  13 I/O INT, TC, USART: RXD E2 28 O MXT DBG CLK  14 I/O INT, TC, USART: TXD E3 29 P GND 15 O ~SD_CS (1)  B0 30 P GND B2 F0   A7 NOTE 1 – Pulled up through 47kΩ resistor NOTE 2 – Pulled up through 3.3kΩ resistor  8 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 1.8 SD/MMC U5 The SD/MMC Connector U5 connects to the MCU’s SPI and I/O. Pin Type Description (1) Pin Type Description 9 - N/C (SD DAT2) 1 O ~SD_CS (SD DAT3) 2 O MOSI (SD CMD) 10 I ~SD_Detect (SD C/D) (1) 3 P GND 11 P GND 4 P Vdd 12 - N/C (SD W/P) 5 O SCK (SD CLK) 13 P GND (SD SHELL) 6 P GND 14 P GND (SD SHELL) 7 I MISO (SD DAT0) 15 P GND (SD SHELL) 8 - N/C (SD DAT1) 16 P GND (SD SHELL) NOTE 1 – Pulled up through 47kΩ resistor   9 1.9 XMEGA U4 Type Description Pin Type 1 - 2 - N/C 34 P GND N/C 35 P Vdd 3 O LED- 36 -  4 - N/C 5 O ~RESET_MXT (1) 6 O ~SD_CS (1) 7 I 8 O 9 - 10 ~SD_Detect  (1) ~RESET_LCD (1) - Description Expansion Interface(3) (E0) (3) - Expansion Interface (E1)  - Expansion Interface(3) (E2)  Expansion Interface(3) (E3)     39 -   40 - N/C  41 - N/C  42 - N/C  Expansion Interface (3) (B4)  43 - N/C (3) 11 - Expansion Interface (B5)  44 P GND 12 - Expansion Interface(3) (B6)  45 P Vdd  46 O LED_EN (3) 13 - 14 P GND 47 - N/C 15 P Vdd 48 - N/C 16 I/O - N/C - N/C 17 O Expansion Interface I2C SDA (2) 2 I C SCL (2) 18 I ~MXT_CHG 19 O WR (1) (1) (B7)  37 38 Expansion Interface(3) (B3) MXT LCD SD USB Exp Pin MXT LCD SD USB Exp The MCU’s pins are assigned as shown below. Note a pin’s functionality within the system is indicated in the columns located to the right of the description.   49   50   51 - N/C   52 P GND   53 P Vdd 20 O ~CS 21 O MOSI   54 - N/C 22 I MISO   55 - N/C 23 O SCK   56 I/O 24 P GND 57 25 P Vdd 26 - Reserved (RES1) 27 - 28 29   PDI_DAT  I ~RESET / PDI_CK  58 - N/C 59 - N/C N/C 60 P GND O LED D4 61 P Vdd O LED D5 62 - N/C 30 O LED D2 63 - N/C 31 O LED D3 64 - N/C 32 I/O D-  65 P GND (Thermal Pad) 33 I/O D+  NOTE 1 – Pulled up through 47kΩ resistor NOTE 2 – Pulled up through 3.3kΩ resistor NOTE 3 – Expansion Interface not available on PCB Rev A1  10 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 2 Overview of the 2.8in PCAP Touch Module 2.1 Introduction The 2.8in PCAP Touch Module is a touchscreen module offering best-in-class projected capacitance multi-touch functionality combined with a 2.8in LCD panel. With an onboard Atmel XMEGA256A3BU MCU, the module offers standalone operation based on a subset of functionality available from the Atmel XMEGA A3BU Xplained MCU Board and Atmel mXT143E Xplained Module. The module has been designed to effectively reproduce the combined schematic of these Xplained boards: Atmel XMEGA A3BU Xplained MCU Board Atmel mXT143E Routing Board = PDA TM2801 2.8in PDA TM2800 mXT143E Xplained Board + Expansion Interface As shown in Figure 4 below, the module MCU offers access to the touchscreen controller, display interface, USB and storage for easy development and integration. PDA 2.8in PCAP Touch Module PCB Capacitive Touchscreen Controller J2 mXT143E J3 J5 MCU LCD Panel U5 XMEGA256 A3BU Touch sensor USB HOST SD Card LOCK LED D2 LED D3 SDSC card LED D4 LED D5 J6 Expansion Interface Figure 4 - Functional Block Diagram   11 2.2 Understanding Unfamiliar Concepts Throughout this document, the functionality of the module sub-system will be outlined and summarized. However, the user is encouraged to refer to the resources and documents below in order to gain a more thorough understanding of each sub-system. • Atmel XMega256A3BU (www.atmel.com) • Atmel maXTouch mXT143E Datasheet (www.atmel.com) • Displaytech SDT028ATFT Datasheet (www.displaytech-us.com) • For a basic overview of I2C communication, refer to Section 5 of this document • Universal Serial Bus (www.usb.org) • Secure Digital Card (www.sdcard.org) 2.3 XMEGA A3BU Microcontroller The module is designed around the Atmel XMEGA256A3BU microcontroller. This microcontroller has a variety of features and flexibility and provides a good starting point for development and evaluation of the PDA TM2801 touch module. For additional details, see the XMEGA documentation available from Atmel’s website (www.atmel.com). The MCU is directly connected to all of the module sub-systems, providing a capable full-featured platform for development. 2.3.1 Atmel Software Framework The Atmel Software Framework or ASF (http://asf.atmel.com) contains example projects targeting the XMEGA256A3BU MCU and its various features. This provides an excellent resource, in combination with the XMEGA documentation, for the user to become acquainted with the capabilities of the MCU. Of particular interest with this module, the ASF contains sample code for implementing the USB device interface available on the XMEGA256A3BU. 2.4 LCD Panel The module MCU has a direct connection to the LCD panel interface (Connector J3) which includes a serial interface to the ILI9341 (or ILI9320 or compatible) display driver IC and LED backlight control. The LCD Backlight control is performed using the LED_EN and LED- signals (XMEGA U4 Pins 46 and 3, respectively) as shown in Figure 5 below:  12 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 3 LED_K R8 3.3k Q1 2N7002 1 2 LED_EN LED- R9 47k R10 33 C6 0.1uF Figure 5 - LED Backlight Control 2.4.1 Atmel Software Framework The Atmel Software Framework includes projects targeting the ILI9341 Display Driver IC. 2.5 maXTouch Capacitive Touchscreen Controller The module touch screen interface is based on the Atmel maXTouch mXT143E Touch Controller. The touch controller scans the touch sensor and signals the MCU with an active low interrupt signal (~MXT_CHG) when new touch data is available. Data communication with the maXTouch controller is performed over an I2C interface (XMEGA U4 Pins 16, 17). The I2C address of the touch controller is set to 0x4A. NOTE: Pull-up resistors for the I2C SCL and SDA lines are located at R4 and R3 respectively. A pull-up resistor for the ~MXT_CHG interrupt signal is located at R6. 2.5.1 maXTouch Controller Interface Details of the maXTouch communication protocol are beyond the scope of this document. However information is provided below to facilitate evaluation and initial development. The module is pre-loaded with a configuration already optimized for this touch sensor and panel, so the developer need only focus on interfacing with the device. When developing the maXTouch controller interface during evaluation and development, care should be taken to avoid changing the maXTouch configuration or committing changes to NV storage on the maXTouch controller. To get started with development, the user is strongly encouraged to leverage existing code available from the resources outlined in the following sections. 2.5.1.1 Atmel Software Framework The Atmel Software Framework (http://asf.atmel.com) contains examples of code for interfacing with devices in the maXTouch family of touch controllers. Many of the code examples found in the ASF are targeted for the mXT143E Xplained module and support the XMEGA256A3BU as the host MCU. With very minor modification, these projects are directly applicable to this module. 2.5.1.2 Linux Kernel / Android While the Linux or Android OS may not be applicable to XMEGA256A3BU, there is a growing code base in the Linux and Android communities that can interface with maXTouch touchscreen controllers. These drivers provide an excellent starting point for development with embedded firmware running on the XMEGA. The Linux Kernel (www.kernel.org) has included basic support for maXTouch devices since version 2.6.36. The mainline driver has undergone considerable evolution since then.   13 In addition, Atmel maintains patches (www.github.com/atmel-maxtouch/linux) which provide numerous out-of-cycle improvements to the mainline Linux Kernel driver. 2.6 SD/MMC Connector The module includes a SD/MMC Connector (Connector U5) to provide optional removable storage in the user’s developments. This feature is currently experimental. 2.6.1 Atmel Software Framework The Atmel Software Framework (in additional to many online resources) includes example projects that implement SD/MMC support. 2.7 Expansion Interface As of PCB revision A2, the Debug connector is replaced with an Expansion Connector (Connector J6). In addition to the signals previously available through the Debug Connector, the expansion interface provides broader access to system signals, spare I/O and a selection signals to support prototyping and development. The Main PCB uses the Hirose DF40-C-30DS-0.4V(51) mezzanine connector. The accompanying Expansion PCB (10-01052-A0) uses the Hirose DF40-C-30DP-0.4V(51) mezzanine connector. Signals on the Expansion PCB are routed one-to-one from the mezzanine connector to an array of through-holes suitable for direct soldering or populating with any configuration of connectors featuring 0.025in terminals with 0.100in pitch. Note: Some signals provided through the Expansion Interface are used by the system for communication with the LCD, Touchscreen Controller and SD/MMC interface and are of varying criticality to normal operation. Care should be taken when using this interface. Refer to section 1.7 for details on which signals are used elsewhere as well as the Atmel XMega256A3BU datasheet for details on available pin functions.  14 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 3 Getting Started As previously noted, the module was designed to effectively consolidate the functionality of the XMEGA A3BU Xplained and mXT143E Xplained board into a single, standalone module. This configuration provides a quick, easy way to evaluate the performance of the touchscreen and display as well as offering a convenient platform for development. In addition, Atmel provides free development tools and coding resources to support development using Atmel Studio (www.atmel.com) and the Atmel Software Framework (http://asf.atmel.com). The following sections outline the process of setting up and programming the module. 3.1 Hardware Setup The module is powered by the USB connector even if the USB interface to a host is not being used. Therefore, the module can be powered either by connecting to a USB host or by connecting USB power supply. 3.2 Demo Firmware The module is pre-loaded with example firmware to demonstrate basic touchscreen and display functionality. This demo firmware will begin as soon as the device is powered up. 3.3 Loading Firmware The user is encouraged to experiment with the various sample projects available in the Atmel Software Framework (http://asf.atmel.com). In order demonstrate the functionality of the module, several of the example projects from the ASF have been compiled for the XMEGA256A3BU and binary images (HEX files) are available for download from the PDA website. See details below. 3.3.1 Programming Tools Before the example HEX files can be loaded, you must first ensure that the necessary programmer (supporting PDI programming) with associated driver/software is installed on your development system. Consult the manual and/or support resources for your programmer for instructions on installation and use. The programmer should be connected to the 6-pin PDI connector J4. 3.3.2 Programming the Example Code Download the example HEX files from http://www.pdaatl.com/modules/2.8in/tm2801demo.zip and unzip to a working folder. Files are named according to the example project.   15 4 Specifications For complete specifications, refer to the datasheets listed in section 2.2 for the various sub-system components outlined in Sections 2.4 and 2.5. 4.1 Mechanical Specifications Drawings and CAD models available upon request. 51.0 mm (PET Outline) Cover Panel Outline 57.13mm x 81.61mm R3.175mm in corners 1.2 mm (Cover Panel) 50.0 mm User side 70.1 mm (PET Outline) 58.6 mm (Viewable) Viewed from user side LCD side 0.460 mm (Sensor) 44.2 mm (Viewable) 0.076 mm (FPC) PIN 1 PCB contacts face down 14.1 mm 5.42 mm 13.5 mm (FPC Min Width) PIN 26 4.65 mm 43 mm (FPC Max Width) Figure 6 - Sensor Only Dimensions Sensor (P/N: 21-00001-A0) may be purchased individually. Minimum order quantities apply. Contact PDA for details.  16 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 7.7 mm (PCB Component Clearance) 57.25 mm (Frame Width) 10-01034-A2 Rev 10-01034-A1 Rev 52.7 mm (PCB Length) AT MEL XM EGA2 56 A3BU 62.9 mm (PCB Length) 50.8 mm (PCB Width) 81.82 mm (Frame Length) AT M EL MXT 143E AT MEL XM EGA2 56 A3BU ATM EL MXT143E 50.8 mm (PCB Width) 19.83 mm (Cover Panel rear surface to Mounting Boss) Figure 7 – Module Dimensions   17 4.2 Absolute Maximum Specifications Parameter Value Operating temp 0oC to +70oC Storage temp -40oC to +85oC Vdd -0.5 to +3.6V Max continuous pin current, any control or drive pin ±40 mA Voltage forced onto any pin -0.5V to (Vdd + 0.5) Volts CAUTION: Stresses beyond those listed under Absolute Maximum Specifications may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or other conditions beyond those indicated in the operational sections of this specification are not implied. Exposure to absolute maximum specification conditions for extended periods may affect device reliability. 4.3 Recommended Operating Conditions Parameter Value Vin 3.3V ±5 percent Supply ripple + noise ±20 mV 4.4 DC Specifications Vdd = 3.3, Ta = recommended range, unless otherwise noted Parameter Description Min Typ Max Units VIL Low input logic level - 0.5 – 0.3 Vdd V VHL High input logic level 0.7 Vdd – Vdd + 0.5 V VOL Low output voltage – – 0.2Vdd V VOH High output voltage 0.8Vdd – – V – – 1 µA IIL Input leakage current Notes 4.5 I2C-compatible Bus Specifications  18 Parameter Operation Address (maXTouch 143E) 0x4A Maximum bus speed (SCL) 400 kHz PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: I2C Specification 2.8in PCAP Touch Module Version 2.1 4.6 Power Consumption Vdd (V) Mode Idd (mA) 3.3Vdc mxt143E in free run and LCD backlight ON full. 60ma 4.7 Part Number Part Number Description 90-00003-A0 2.8” Touchscreen Module (PCB Rev A1) 90-00003-A1 2.8” Touchscreen Module with Expansion Interface (PCB Rev A2)   19 5 I2C Basics (I2C-compatible Operation) 5.1 Interface Bus The device communicates with the host over an I2C-compatible bus, in accordance with version 2.1 of the I2C specification. The following sections give an overview of the bus; more detailed information is available from www.i2C-bus.org. Devices are connected to the I2C-compatible bus as shown in Figure 8 both bus lines are connected to Vdd via pull-up resistors. The bus drivers of all I2C-compatible devices must be open-drain type. This implements a wired “AND” function that allows any and all devices to drive the bus, one at a time. A low level on the bus is generated when a device outputs a zero. Figure 8. I2C-compatible Interface Bus Vdd Device 1 Device 2 Device 3 Device n R1 R2 SDA SCL 5.2 Transferring Data Bits Each data bit transferred on the bus is accompanied by a pulse on the clock line. The level of the data line must be stable when the clock line is high; the only exception to this rule is for generating START and STOP conditions. Figure 9. Data Transfer SDA SCL Data Stable Data Stable Data Change 5.3 START and STOP Conditions The host initiates and terminates a data transmission. The transmission is initiated when the host issues a START condition on the bus, and is terminated when the host issues a STOP condition. Between the START and STOP conditions, the bus is considered busy. As shown in Figure 10 START and STOP conditions are signaled by changing the level of the SDA line when the SCL line is high.  20 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6 PDA TM2801: Figure 10. 2.8in PCAP Touch Module START and STOP Conditions SDA SCL START STOP 5.4 Address Byte Format All address bytes are 9 bits long. They consist of 7 address bits, one READ/WRITE control bit and an acknowledge bit. If the READ/WRITE bit is set, a read operation is performed. Otherwise a write operation is performed. An address byte consisting of a slave address and a READ or a WRITE bit is called SLA+R or SLA+W, respectively. When the device recognizes that it is being addressed, it acknowledges by pulling SDA low in the ninth SCL (ACK) cycle. The most significant bit of the address byte is transmitted first. Figure 11. Address Byte Format Addr MSB Addr LSB R/W ACK 7 8 9 SDA SCL 1 2 START 5.5 Data Byte Format All data bytes are 9 bits long, consisting of 8 data bits and an acknowledge bit. During a data transfer, the host generates the clock and the START and STOP conditions. The slave device is responsible for acknowledging the reception. An acknowledge (ACK) is signaled by the slave device pulling the SDA line low during the ninth SCL cycle. If the slave device leaves the SDA line high, a NACK is signaled. Figure 12. Data Byte Format Addr MSB Addr LSB R/W ACK 8 9 Aggregate SDA SDA from Transmitter SDA from Receiver SCL from Master 1 SLA+R/W 2 7 Data Byte STOP or Next Data Byte   21 5.6 Combining Address and Data Bytes into a Transmission A transmission consists of a START condition, an SLA+R or SLA+W, one or more data bytes and a STOP condition. The wired “ANDing” of the SCL line is used to implement handshaking between the host and the device. The device extends the SCL low period by pulling the SCL line low whenever it needs extra time for processing between the data transmissions. Figure 13 shows a typical data transmission. Note that several data bytes can be transmitted between the SLA+R or SLA+W and the STOP. Figure 13. Byte Transmission Addr MSB Addr LSB R/W ACK Data MSB Data LSB ACK SDA SCL 1 START  22 2 7 SLA+R/W 8 PDA TM2801: 2.8in PCAP Touch Module 9 1 2 7 Data Byte 8 9 STOP 1303-5-6 PDA TM2801: 2.8in PCAP Touch Module 6 Revision History Revision No. History Rev 1210-1-1 – Oct 2012 Preliminary Draft Rev 1210-2-2 – Oct 19, 2012 Initial Release Rev 1211-3-3 – Nov 20, 2012 Add notes to Figure 4 regarding sensor orientation and pin 1 location. Add notes to Figure 1 identifying connectors and pin 1 locations. Rev 1303-4-5 – Mar 28, 2013 Add details of new 10-01034-A2 PCB Rev with Expansion interface Rev 1305-5-6 – May 30,2013 Update references to ILI9320 to include ILI9341 LCD driver IC   23 7 Notes Precision Design Associates, Inc. 736 Johnson Ferry Rd, Suite C-270 Marietta, GA 30068 USA email: sales@pdaatl.com tel: (770)-971-4490 ® url: http://www.pdaatl.com ® ® © 2013 Precision Design Associates. All rights reserved. Atmel , Atmel logo and combinations thereof, maXTouch , QTouch , and others are registered trademarks of Atmel Corporation or its subsidiaries. Other terms and product names may be registered trademarks or trademarks of others.  24 PDA TM2801: 2.8in PCAP Touch Module 1303-5-6
90-00003-A1 价格&库存
很抱歉,暂时无法提供与“90-00003-A1”相匹配的价格&库存,您可以联系我们找货
