32128AFCBW-RGB
32128AFCBW-RGB
    DISPLAYTECH
    DISPLAYLCD128X32TRANSFL
32128AFCBW-RGB 数据手册
Website: www.displaytech.com.hk LCD Module Product Specification Product: 32128A-RGB Series Monochrome Graphic Display Module (128x32DOTS) Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. October 28, 2014. Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 1. REVISION RECORD VERSION 1.0 1.1 2.0 2.1 CHANGES Initial revision Maximum power supply for logic at absolute maximum ratings in page 2 New format; Changed the LED driving current on page 5, 6, & 7. Add interface info in 2. General Specifications 1 DATE 27 Mar. 2006 15 Apr. 2008 Jan 30, 2013 Oct 28, 2014 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 Table of Content 1. 2. REVISION RECORD ........................................................................ 1 General Specifications ........................................................................ 3 3. Absolute Maximum Ratings ............................................................... 3 4. Electrical Characteristics ................................................................... 3 5. Display Controller /Power Supply Timing ........................................ 3 6. Block Diagram .................................................................................... 4 7. Mechanical Drawing ........................................................................... 5 8. Backlight Drawing .............................................................................. 6 9. Backlight specification ........................................................................ 7 10. Optical Characteristics ....................................................................... 8 11. Quality Guarantee ............................................................................ 10 12. Precautions For Using LCD Modules.............................................. 15 13. Using LCD Modules.......................................................................... 17 2 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 2. General Specifications Item Display Format Dot Size View Area Module Size LCD Type Polarizer Mode View Angle Backlight Backlight Driver Type Backlight Color Controller & LCD Driver Driving Method Interface Contents 128 x 32 DOTS 0.242 x 0.245 36.1 mm x 9.95mm 41.3 mm x 19.7mm x 8.1 mm FSTN Transflective 6 O’clock LED External Power RGB ST7565V 1/33 Duty, 1/6 Bias 8-Bit Parallel 3. Absolute Maximum Ratings (Ta=25°C, VSS=0V) ITEM Power Supply for Logic Power Supply for LCD Input Voltage Supply Voltage for LED Backlight Normal Operating Temperature Normal Storage Temperature Wide Operating Temperature Wide Storage Temperature SYMBOL VDD V0-VSS VIN VLED Top Tst Top Tst MIN. -0.3 4.0 -0.3 --0 -10 -20 -30 TYP. ------3.2 --------- MAX. 3.6 13.0 VDD+0.3 --50 60 70 80 UNIT V V V V °C °C °C °C Note: • When temperature is below 0°C, the response time of liquid crystal (LC) will be slower. • If module driving condition exceeds the absolute maximum ratings, permanent damaged may be resulted. If module is driven within the absolute maximum ratings but exceeded the DC characteristics, malfunction may be resulted. • VDD/VCC > VSS 4. Electrical Characteristics DC Characteristics (Ta=25°C, VSS=0V) ITEM Power Supply for LCM Input Voltage SYMBOL VDD VIL VIH LCD Driver Driving Voltage VDD2 Supply Current for LCM IDD ILED CONDITION --L level H level --25°C --VDD=3.0V; 25°C VLED=3.2V; 25°C 5. Display Controller /Power Supply Timing See Display Controller Specification: Sitronix ST7565V 3 MIN. 2.85 Vss 0.8VDD ----------- TYP. 3.0 ------6.9 --0.35 45 MAX. 3.15 0.2VDD Vdd --------60 UNIT Volt Volt Volt Volt mA Displaytech Ltd LCD MODULE 6. Block Diagram 4 32128A-RGB SERIES Version: 2.1 Displaytech Ltd LCD MODULE 7. Mechanical Drawing • 32128A FC BW-RGB 5 32128A-RGB SERIES Version: 2.1 Displaytech Ltd LCD MODULE 8. Backlight Drawing • 32128A BL-RGB 6 32128A-RGB SERIES Version: 2.1 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 9. Backlight specification  MECHANICAL SPECIFICATIONS ITEM OUTLINE SIZE (LxWxH) VIEWING AREA (LxW) CONTACT PIN PITCH/LENGTH NO.OF LED SMT NOMINAL DIMENSIONS 41.3 x 19.7 x 8.10 37.10 x 10.95 NIL 3 UNIT mm mm mm ---  ELECTRICAL/OPTICAL CHARACTERISTICS (Ta=25°°C, If=45mA typ.) MODE PARAMETER PURE COLOR RED BLUE GREEN X=0.7032 X=0.1899 X=0.1417 CHROMATICITY COORDINATE Y=0.2965 Y=0.7276 Y=0.0612 FORWARD VOLTAGE (Vf) 3.2 typ 3.2 typ 3.2 typ FORWARD CURRENT (If) 45 45 45 AVERAGE LUMINOUS INTENSITY (Iv) 62 336 134  UNIT ----V mA cd/m2 ABSOLUTE MAXIMUM RATING ITEM FORWARD CURRENT REVERSE VOLTAGE OPERATING TEMPERATURE STORAGE TEMPERATURE RED 60mA 5V TESTING POINT PURE GREEN 60mA 5V -20°C TO 70°C -30°C TO 80°C BLUE UNIT 60mA 5V If Vr Top Tstg CIRCUIT DIAGRAM REMARK: 1. Average luminous intensity is the average value of the six indicated points as shown. 2. Measurement instrument: BM-7, APERTURE: ∅10mm. 3. IT IS RECOMMENDED TO DRIVE THE LED BACKLIGHT WITH PWM SIGNAL. 7 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 10.Optical Characteristics NO Item Symbol 1 Recommended Operating Voltage VLCD 2 3 Measuring Condition θ=0 Φ= 0 °C STD.Value Min Typ 25 6.6 6.9 7.2 --------------------------------- --1.889 ----2.116 ----58 ----118 --40 35 30 30 --------------90 ----210 ----------- --- 17 --- Vth θ=0 Φ= 0 Vsat θ=0 Φ= 0 Tr θ=0 Φ= 10 Tf θ=0 Φ= 10 Φ=0° Φ=180° Φ=90° Φ=270° 0 25 50 0 25 50 0 25 50 0 25 50 25 25 25 25 Hz=64 25 Operating Voltage Response time 4 Viewing Angle (Cr2) θ θ θ θ 5 Current Consumption ILCD Max Unit Remark V Note1 Note2 ms Note4 Deg Note1 uA Note3 NOTE 1: DEFINITION OF VIEWING ANGLE AND DIRECTION Zθ =0° Detector θ 12H Φ =180 ° 3H Φ =90 ° Φ ° 9H Φ =270 6H Φ =0 ° NOTE 2: THERSHOLD VOLTAGE AND SATURATION VOLTAGE Vth: The voltage Vop which the transmission rate of segment is 90%(positive) or 10%(negative) of saturated value on conditions of the selected waveform.(non-selected waveform is opposition) Vsat: The voltage Vop which the transmission rate of segment is 10%(positive) or 10%(negative) of saturated value on conditions of the selected waveform.(non-selected waveform is opposition) 8 Displaytech Ltd LCD MODULE 32128A-RGB SERIES NOTE 3: CURRENT CONSUMPTION (I LCD) Conditions: 1.Driving waveform: static waveform. 2.Voltage applied to all segments NOTE 4: RESPONSE TIME (Tr, Tf) NOTE 5: CONTRAST RATIO (CR) 5.1 POSITIVE TYPE: CONTRAST RATIO = BRIGHTNESS AT VOP(NON-SELECTED) BRIGHTNESS AT VOP(SELECTED) 5.2 NEGATIVE TYPE: CONTRAST RATIO = BRIGHTNESS AT VOP(SELECTED) BRIGHTNESS AT VOP(NON-SELECTED) NOTE 6: CAPACITANCE (C) Conditions: Voltage applied to all segments. 9 Version: 2.1 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 11.Quality Guarantee  PURPOSE: It is to define the inspection standard of LCD modules  PRODUCT STANDARD 1) INSPECTION AND TEST  FUNCTION TEST  APPEARANCE INSPECTION  PACKING SPECIFICTION 2) INSPECTION CONDITION  Put under the lamp (20w×2) at a distance 100mm from the LCD Modules.  Tilt upright 45 degree by the front (back) to inspect LCD appearance. P M A L R O T A R E P O  : MIL-STD-105D : SINGLE : 0.65% (MAJOR) : 2.5% (MINOR) : II/NORMAL M C L 3) AQL INSPECTION LEVEL  SAMPLING METHOD  SAMPLING PLAN  MAJOR DEFECT  MINOR DEFECT  GENERAL LEVEL DISPLAY AREA DEFINITION: View area Viewing boundary 10 Displaytech Ltd  LCD MODULE 32128A-RGB SERIES Version: 2.1 INSPECTION STANDARD 1) FUNCTIONAL TEST STANDARD Item Standar Defect d type Reject MAJ Reject MAJ Reject MAJ Inspection Standard Description 1 2 3 LCD has no display LCM display do not change Display wrong pattern 4 Display segment open Missing segment Reject MAJ Reject MAJ Reject See sample See sample MAJ Missing segment 5 Display dim segment 6 Wrong LCD viewing direction 7 Dim Display 8 LCD color variation Dim segment Dim segment Pattern parallelism L ≧20mm ≧30mm ≧40mm ≧50mm ≧60mm ≧70mm ≧80mm ≧90mm ≧100mm 9 Acceptable range 1 W 4 1 Reject MIN 1 Reject MIN 1 Reject MIN 1 Accept 2 Accept 1 ≧ b 4 Standard y 1 ≧ a 4 (X or y) ≧0.2mm 1 b 4 1 ≦ b 5 ≦ 11 Accept 1 1 X LCD display Broken segment(dots) MAJ Ø≦0.25 Ø>0.25 Draw 11 MAJ 1 a 4 1 ≦ a 5 ≦ QTY Displaytech Ltd Item LCD MODULE 32128A-RGB SERIES Inspection Standard Description Ø= 12 13 14 15 16 Version: 2.1 LCD display Black spot or White spot Standard x+ y 2 QTY Ø0.025) LCD display excess black line or white line Defect type 2 1 0 0 QTY 2 1 0 0 Backlight not function LED not function or dim Backlight defect (dirt, scratch) Accept Accept Accept Reject Reject MIN MAJ Accept Accept Reject Reject Reject Reject Reject MIN MAJ MAJ MIN MIN 2) COSMETIC INSPECTION STANDARD Item 1 Standard description of inspection Standard LCD inspection item 1.1 LCD color variation 1.2 LCD broken 1.3 Wrong polarizer of LCD 1.4 Spot on LCD surface Scratch on LCD LCD scratch 1.6 Scratch depth see sample White or black spot on LCD 1.8 x x+ y Ø= 2 1.5 1.7 Defect type x+ y Ø= 2 Black line in LCD 1.9 Round air bubble 1.10 Line defect y Scratch =L 0.01 mm/mm d1-d2≦tolerance 3.7 d1-d2>tolerance 13 Accept Accept Reject Accept Accept Reject Accept Reject MIN MIN MIN Accept Reject MIN Displaytech Ltd Item LCD MODULE 32128A-RGB SERIES Standard description of inspection Scratch on bezel Standard Face L L≦3 Not defined W≦0.20 2 L≦2 W≦0.3 2 - Defect type Accept QTY W W≦0.15 3.8 Version: 2.1 See Sample W>0.3 side Accept QTY L - W W≦0.2 except L≦3 W≦0.25 2 L≦2 W≦0.3 2 See Sample 3.9 Twist angle α=45º+5º Accept 3.10 Void gap between bezel and PCB Bezel clip incorrectly Reject 3.11 Reject MIN MIN NG 4 Solder specification 4.1 Wrong component 4.2 Broken component Reject Reject MAJ MAJ Component legs extend beyond the pad and Legs >pad distance(w) on solder area >W2 Accept Component legs extend beyond the pad and Legs >pad distance(w) on solder area 0.5mm Accept Reject Accept Reject Accept Reject Reject Mis-alignment MIN 4.3 Component Offset Component assembly defect h≦2.0mm h>2.0mm h≦0.5mm h>0.5mm 4.7 Components hoist 4.8 Switch (socket) hoist 4.9 Components cold solder or incomplete solder 14 MIN MIN MIN MAJ Displaytech Ltd Item LCD MODULE 32128A-RGB SERIES Standard description of inspection Version: 2.1 Standard Defect type Solder PAD tilt up, but height (h) less than Solder PAD thickness (a) 4.10 Accept Excess solder above components 4.11 Reject Min 4.12 Reject MIN 4.13 Solder area less than soldering PAD Area by 2/3 Trimmed pin length beyond 0.09inch (2.3mm) Reject MIN 4.14 Reject Min Reject Reject Reject Reject MAJ MIN MAJ MIN Insufficient solder below components height or less than diameter 5 5.1 5.2 5.3 5.4 Packing specification Wrong carton mark . Carton mark problem Carton damage extend than 150mm Carton damage, scratch more 50mm, less 150mm. 12.Precautions For Using LCD Modules  HANDLING PRECAUTIONS 1. 2. 3. This device is susceptible to Electro-Static Discharge (ESD) damage. Observe Anti-Static precautions. The display panel is made of glass. Do not subject it to a mechanical shock by dropping it or impact. If the display panel is damaged and the liquid crystal substance leaks out, be sure not to get any in your mouth. If the substance contacts your skin or clothes, wash it off using soap and water. 4. Do not apply excessive force to the display surface or the adjoining areas since this may cause the color tone to vary. 5. The polarizer covering the display surface of the LCD module is soft and easily scratched. Handle this polarizer carefully. 6. If the display surface becomes contaminated, breathe on the surface and gently wipe it with a soft dry cloth. If it is heavily contaminated, moisten cloth with one of the following solvents : • Isopropyl alcohol • Ethyl alcohol 7. Solvents other than those above-mentioned may damage the polarizer. Especially, do not use the following. • Water • Ketone • Aromatic solvents 8. Exercise care to minimize corrosion of the electrode. Corrosion of the electrodes is accelerated by water droplets, moisture condensation or a current flow in a high-humidity environment. 9. Install the LCD Module by using the mounting holes. When mounting the LCD module make sure it is free of twisting, warping and distortion. In particular, do not forcibly pull or bend the I/O cable or the backlight cable. 10. Do not attempt to disassemble or process the LCD module. 15 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 11. NC terminal should be open. Do not connect anything. 12. If the logic circuit power is off, do not apply the input signals. 13. To prevent destruction of the elements by static electricity, be careful to maintain an optimum work environment. • Be sure to ground the body when handling the LCD modules. • Tools required for assembling, such as soldering irons, must be properly grounded. • To reduce the amount of static electricity generated, do not conduct assembling and other work under dry conditions. • The LCD module is coated with a film to protect the display surface. Exercise care when peeling off this protective film since static electricity may be generated. 1. 2. 3. 4. 1. 2. 3. 4. 1. 2. 3. 4. 5. 6. 7. 1. 1. 2. 3.  POWER SUPPLY PRECAUTIONS: Identify and, at all times, observe absolute maximum ratings for both logic and LC drivers. Note that there is some variance between models. Prevent the application of reverse polarity to VDD and VSS, however briefly. Use a clean power source free from transients. Power-up conditions are occasionally “jolting” and may exceed the maximum ratings of the modules. The VDD power of the module should also supply the power to all devices that may access the display. Don’t allow the data bus to be driven when the logic supply to the module is turned off.  OPERATING PRECAUTIONS: DO NOT plug or unplug the module when the system is powered up. Minimize the cable length between the module and host MPU. For models with EL backlights, do not disable the backlight by interrupting the HV line. Unload inverters produce voltage extremes that may arc within a cable or at the display. Operate the module within the limits of the modules temperature specifications.  MECHANICAL/ENVIRONMENTAL PRECAUTIONS: Improper soldering is the major cause of module difficulty. Use of flux cleaner is not recommended as they may seep under the elastomeric connection and cause display failure. Mount the module so that it is free from torque and mechanical stress. Surface of the LCD panel should not be touched or scratched. The display front surface is an easily scratched, plastic polarizer. Avoid contact and clean only when necessary with soft, absorbent cotton dampened with petroleum benzene. Always employ anti-static procedure while handling the module. Prevent moisture build-up upon the module and observe the environmental constraints for storage temperature and humidity. Do not store in direct sunlight If leakage of the liquid crystal material should occur, avoid contact with this material, particularly ingestion. If the body or clothing becomes contaminated by the liquid crystal material, wash thoroughly with water and soap  STORAGE PRECAUTIONS When storing the LCD modules, avoid exposure to direct sunlight or to the light of fluorescent lamps. Keep the modules in bags (avoid high temperature / high humidity and low temperatures below specified storage temperature). Whenever possible, the LCD modules should be stored in the same conditions in which they were shipped from our company.  OTHERS Liquid crystals solidify under low temperature (below the storage temperature range) leading to defective orientation or the generation of air bubbles (black or white). Air bubbles may also be generated if the module is subject to a low temperature. If the LCD modules have been operating for a long time showing the same display patterns, the display patterns may remain on the screen as ghost images and a slight contrast irregularity may also appear. A normal operating status can be regained by suspending use for some time. It should be noted that this phenomenon does not adversely affect performance reliability. To minimize the performance degradation of the LCD modules resulting from destruction caused by static electricity etc., exercise care to avoid holding the following sections when handling the modules. • Exposed area of the printed circuit board. • Terminal electrode sections. 16 Displaytech Ltd LCD MODULE 32128A-RGB SERIES Version: 2.1 13.Using LCD Modules  Liquid Crystal Display Modules LCD is composed of glass and polarizer. Pay attention to the following items when handling. 1. Please keep the temperature within specified range for use and storage. Polarization degradation, bubble generation or polarizer peel-off may occur with high temperature and high humidity. 2. Do not touch, push or rub the exposed polarizers with anything harder than an HB pencil lead (glass, tweezers, etc.). 3. N-hexane is recommended for cleaning the adhesives used to attach front/rear polarizers and reflectors made of organic substances which will be damaged by chemicals such as acetone, toluene, ethanol and isopropylalcohol. 4. When the display surface becomes dusty, wipe gently with absorbent cotton or other soft material like chamois soaked in petroleum benzin. Do not scrub hard to avoid damaging the display surface. 5. Wipe off saliva or water drops immediately, contact with water over a long period of time may cause deformation or color fading. 6. Avoid contacting oil and fats. 7. Condensation on the surface and contact with terminals due to cold will damage, stain or dirty the polarizers. After products are tested at low temperature they must be warmed up in a container before coming is contacting with room temperature air. 8. Do not put or attach anything on the display area to avoid leaving marks on. 9. Do not touch the display with bare hands. This will stain the display area and degradate insulation between terminals (some cosmetics are determinated to the polarizers). 10. As glass is fragile. It tends to become or chipped during handling especially on the edges. Please avoid dropping or jarring.  Precaution for Handing LCD Modules Since LCM has been assembled and adjusted with a high degree of precision, avoid applying excessive shocks to the module or making any alterations or modifications to it. 1. Do not alter, modify or change the shape of the tab on the metal frame. 2. Do not make extra holes on the printed circuit board, modify its shape or change the positions of components to be attached. 3. Do not damage or modify the pattern writing on the printed circuit board. 4. Absolutely do not modify the zebra rubber strip (conductive rubber) or heat seal connector. 5. Except for soldering the interface, do not make any alterations or modifications with a soldering iron. 6. Do not drop, bend or twist LCM.  Electro-Static Discharge Control Since this module uses a CMOS LSI, the same careful attention should be paid to electrostatic discharge as for an ordinary CMOS IC. 1. Make certain that you are grounded when handing LCM. 2. Before remove LCM from its packing case or incorporating it into a set, be sure the module and your body have the same electric potential. 3. When soldering the terminal of LCM, make certain the AC power source for the soldering iron does not leak. 4. When using an electric screwdriver to attach LCM, the screwdriver should be of ground potentiality to minimize as much as possible any transmission of electromagnetic waves produced sparks coming from the commutator of the motor. 5. As far as possible make the electric potential of your work clothes and that of the work bench the ground potential. 6. To reduce the generation of static electricity, be careful that the air in the work is not too dried. A relative humidity of 50%-60% is recommended.  Precaution for soldering to the LCM Observe the following when soldering lead wire, connector cable and etc. to the LCM. • Soldering iron temperature : 310°C ± 10°C. • Soldering time : 3-4 sec. • Solder : lead free solder. If soldering flux is used, be sure to remove any remaining flux after finishing to soldering operation. (This does not apply in the case of a non-halogen type of flux.) It is recommended that you protect the LCD surface with a cover during soldering to prevent any damage due to flux spatters. 2. When soldering the electroluminescent panel and PC board, the panel and board should not be detached more than three times. This maximum number is determined by the temperature and time conditions mentioned above, though there may be some variance depending on the temperature of the soldering iron. 3. When remove the electroluminescent panel from the PC board, be sure the solder has completely melted, the soldered pad on the PC board could be damaged. 1. 17 Displaytech Ltd 1. 2. 3. 4. 5. 6. LCD MODULE 32128A-RGB SERIES Version: 2.1  Precautions for Operation Viewing angle varies with the change of liquid crystal driving voltage (VO). Adjust VO to show the best contrast. Driving the LCD in the voltage above the limit shortens its life. Response time is greatly delayed at temperature below the operating temperature range. However, this does not mean the LCD will be out of the order. It will recover when it returns to the specified temperature range. If the display area is pushed hard during operation, the display will become abnormal. However, it will return to normal if it is turned off and then back on. Condensation on terminals can cause an electrochemical reaction disrupting the terminal circuit. Therefore, it must be used under the relative condition of 40°C , 50% RH. When turning the power on, input each signal after the positive/negative voltage becomes stable.  Storage When storing LCDs as spares for some years, the following precaution are necessary. 1. Store them in a sealed polyethylene bag. If properly sealed, there is no need for dessicant. 2. Store them in a dark place. Do not expose to sunlight or fluorescent light, keep the temperature between 0°C and 35°C. 3. The polarizer surface should not come in contact with any other objects. (We advise you to store them in the container in which they were shipped.) 4. Environmental conditions : • Do not leave them for more than 168hrs. at 60°C. • Should not be left for more than 48hrs. at -20°C. 1. 2.  Safety It is recommended to crush damaged or unnecessary LCDs into pieces and wash them off with solvents such as acetone and ethanol, which should later be burned. If any liquid leakes out of a damaged glass cell and comes in contact with the hands, wash off thoroughly with soap and water.  Limited Warranty Unless agreed between DISPLAYTECH and customer, DISPLAYTECH will replace or repair any of its LCD modules which are found to be functionally defective when inspected in accordance with DISPLAYTECH LCD acceptance standards (copies available upon request) for a period of one year from date of shipments. Cosmetic/visual defects must be returned to DISPLAYTECH within 90 days of shipment. Confirmation of such date shall be based on freight documents. The warranty liability of DISPLAYTECH limited to repair and/or replacement on the terms set forth above. DISPLAYTECH will not be responsible for any subsequent or consequential events.  Return LCM under warranty No warranty can be granted if the precautions stated above have been disregarded. The typical examples of violations are : • Broken LCD glass. • PCB eyelet’s damaged or modified. • PCB conductors damaged. • Circuit modified in any way, including addition of components. • PCB tampered with by grinding, engraving or painting varnish. • soldering to or modifying the bezel in any manner. Module repairs will be invoiced to the customer upon mutual agreement. Modules must be returned with sufficient description of the failures or defects. Any connectors or cable installed by the customer must be removed completely without damaging the PCB eyelet’s, conductors and terminals. 18
32128AFCBW-RGB 价格&库存
很抱歉,暂时无法提供与“32128AFCBW-RGB”相匹配的价格&库存,您可以联系我们找货
