INT043BTFT-TS
INT043BTFT-TS
    DISPLAYTECH
INT043BTFT-TS 数据手册
Website: www.displaytech.com.hk LCD Module Product Specification Product: INT043BTFT & INT043BTFT-TS 4.3'' Integrated TFT Display Module (480RGBx272DOTS) Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. January 25, 2013. Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 1. REVISION RECORD VERSION CHANGES DATE 1.0 2.0 Initial revision Change pin#38 to +5.0V at page 5, 6, & 7. 4 November 2011 January 2, 2013 2.1 Added voltage and current details for pin#38 at page 8 Add “ERRATA” section on page 1 January 3, 2013 January 25, 2013 2.2 2. ERRATA (1) The reset line of devices with date codes earlier than 1306xxxxxxxx connects directly to the SSD1961 controller and COG driver on the TFT module, but does not reset the on-board Atmel device. Therefore, driving the reset pin low will reset the SSD1961 controller and COG driver, but the Atmel chip will not re-initialize these devices. (2) In order to re-initialize the controller and driver, the user will need to send initialization commands to the controller and driver. For this reason, we recommend not driving the reset pin low at startup of the device. To fully reset and re-initialize the device, a power-cycle (power the device off and back on) is required. (3) Alternatively, the customer may wish to re-route the reset line to the Atmel's reset pin by cutting the trace from pin 17 and adding a jumper wire from pin 17 to R20. Doing so will allow the user to reset the Atmel device, which will in turn reset and re-initialize the controller and driver. (4) The auto-initialization of the controller and driver requires that the Atmel part assert control of the command and data lines of the on-board controller and driver. These lines will need to be set as inputs by the customer MCU during the auto-initialization time. Specifically, the CS, RS, RD, WR, RESET, and DATA lines need to be set as inputs during the initialization time. The customer can determine when auto-initialization has completed by monitoring the state of the CS line, or by simply waiting 1s at startup of the device. 1 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 Table of Content 1. REVISION RECORD........................................................................... 1 2. ERRATA ................................................................................................ 1 3. Introduction ........................................................................................... 3 4. Features .................................................................................................. 3 5. General Specifications .......................................................................... 4 6. Mechanical Drawing ............................................................................. 5 7. Interface Description ............................................................................ 7 8. Absolute Maximum Ratings ................................................................. 8 9. Electrical Characteristics ..................................................................... 8 10. Display Controller /Power Supply Timing ......................................... 8 11. Backlight specification .......................................................................... 9 12. Optical Characteristics ......................................................................... 9 13. Safety Precaution ................................................................................ 12 2 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 3. Introduction INT043BTFT and INT043BTFT-TS are integrated display module based upon a TFT display with a 272 x 480 RGB resolution. The TFT module is mounted on a PCB on which is mounted a Solomon SSD1961 controller with integrated touch screen control and PWM driving circuit for the LED backlight. The TFT module is automatically initialised upon power up by an on-board controller circuit. 4. Features • • • • • • • • • 8080/6800 MCU Interface (1) Built-in 675kbyte (5,529,600bit) frame buffer. Support up to 640 x 480 at 18bpp display Deep sleep mode for power saving Screen display rotation Display mirroring Programmable contrast and saturation control Auto initialisation (2) Embedded 4-Wires Touch Panel Controller Embedded PWM control and LED driving circuit for backlight Remarks: (5) MCU Interface is selected by soldering option as below. • 8080 interface (Default setting): R4 is with 0 ohm resistor / R19 is opened. • 6800 interface (By request): R19 is with 0 ohm resistor / R4 is opened. • 8/16/18-bit MCU interface are available. (6) “Auto Initialisation” takes around half second to complete, customer is suggested to add an one second delay at the beginning of their program. 3 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 5. General Specifications Item Specification Unit LCD mode Transmissive --- 480(RGB) Line 272 Line 4.3 Inch 116.20 mm 69.70 mm 95.04 mm 53.86 mm 6 o’clock --- Resolution Diagonal Size Overall Size Active area Optimum Viewing Direction Solomon SSD1961; Controller IC MAX11802 (Touch screen) --- Interface type 8080/6800 with 8/16/18 Data Bus Width (1) --- Colours 262K --- Operation temperature range -20~70 °C Storage temperature range -30~80 °C Remarks: (1) MCU Interface is selected by soldering option as below.  8080 interface (Default setting): R4 is with 0 ohm resistor / R19 is opened.  6800 interface (By request): R19 is with 0 ohm resistor / R4 is opened.  8/16/18-bit MCU interface are available.  Maxim MAX11802 is with SPI interface. (2) Color tune may be changed slightly by temperature and driving voltage. (3) RoHS compliant. Component Life Cycle 1) Storage Life: min. 1 Year 2) Operation Life (*1): min. 43 x 10³ h (24hr/day x 7days/week x 52weeks/year x 5years) (Not include backlight) 3) Storage and Operation Life Times are defined for a temperature of +25°C Notes: *1. Operation life ends when one of the listed faults occurs:  The on/off response-times reach 1.5 times of the max. value specified for a new display  The contrast is reduced to 0.5 of the original contrast value  Loss of function  The number of cosmetic defects exceeds the maximum defined 4 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS 6. Mechanical Drawing • INT043BTFT 5 Version: 2.2 Displaytech Ltd • LCD MODULE INT043BTFT / INT043BTFT-TS INT043BTFT-TS 6 Version: 2.2 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 7. Interface Description Pin no 1 2 3 4 5 Symbol GND VDDIO VDDD VDDLCD GND I/O ----------- 6 TP_AUX I 7 TP_TIRQ O 8 9 10 11 12 13 14 TP_DIN TP_CLK TP_DOUT TP_CS GND /CS /RS I I I I --I I 15 E(/RD) I R/W(/WR) I /RESET GND DATA00 | DATA17 NC (PWM) +5.0V NC (BL+) NC (BL-) I --- Description Power ground 0V Power supply for digital I/O pads Power supply for internal digital circuit Power supply for LCD interface related pads Power ground 0V Auxiliary Input: Analog input that used to monitor external conditions such as battery voltage or temperature. (INT043BTFT-TS only: for MAX11802) Active-Low Touch Interrupt Output: Active-low interrupt, indicating that a touch is present (CINT) or has been initiated (EINT) in DCM, or that new data is available in the FIFO in ACM. (INT043BTFT-TS only: for MAX11802) SPI Serial Data Input. (INT043BTFT-TS only: for MAX11802) SPI Serial Data Clock Input. (INT043BTFT-TS only: for MAX11802) SPI Data Output. (INT043BTFT-TS only: for MAX11802) SPI Chip-Select Input. (INT043BTFT-TS only: for MAX11802) Power ground 0V Chip select (for Controller SSD1961) Data/Command select 6800 mode: E (enable signal) 8080 mode: /RD (read strobe signal) 6800 mode: R/W 0: Write cycle 1: Read cycle 8080 mode: /WR (write strobe signal) Master synchronize reset Power ground 0V I/O Data bus. Pins not used should be floating --I ----- No connection Power supply for backlight No connection No connection 16 17 18 19 | 36 37 38 39 40 7 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 8. Absolute Maximum Ratings (GND=VSS=0V; Ta=25°C) Item I/O power supply Digital Core power supply LCD Interface power supply Input Voltage Output Voltage Operating Temperature Storage Temperature Symbol Min. Max. Unit VDDIO VDDD VDDLCD VIN VOUT TOP TST -0.5 -0.5 -0.5 -0.5 -0.5 -20 -30 4.6 1.8 4.6 4.6 4.6 +70 +80 V V V V V °C °C Note: • When temperature is below 0°C, the response time of liquid crystal (LC) will be slower and the color of panel will be darker. • If module driving condition exceeds the absolute maximum ratings, permanent damaged may be resulted. If module is driven within the absolute maximum ratings but exceeded the DC characteristics, mal-function may be resulted. • VDD/VCC > VSS 9. Electrical Characteristics DC Characteristics (GND=VSS=0V; Ta=25°C) Item Symbol Min. Typ. Max. Unit I/O power supply VDDIO 3.135 3.3 3.465 V Digital Core power supply VDDD 1.08 1.2 1.32 V VDDLCD 1.65 3.3 3.6 V LCD Interface power supply Input signal voltage Low level VIL --- --- 0.2VDDIO High level VIH 0.8VDDIO --- VDDIO + 0.5 V Output signal voltage Low level VOL --- --- 0.2VDDIO V High level VOH 0.8VDDIO --- --- V Power supply for backlight (pin#38) 4.75 5.0 5.25 V Current consumption for backlight (pin#38) 112 140 210 mA 10.Display Controller /Power Supply Timing See Display and Touch Screen Controller Specification: Solomon SSD1961 & Maxim MAX11802 8 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 11.Backlight specification Item Supply voltage Forward current Uniformity Color coordination Symbol Condition Vf If ∆Bp X Y If=40mA (VDDIO=3.3V, GND=VSS=0V, Ta=25°C) Min Typ Max Unit Note 15.0 --70 0.275 0.275 If=40mA 16.0 --------- 17.0 40 --0.317 0.317 V mA % ----- 2 1, 2 LED circuit diagram: Constant current If=2x20mA=40mA; Vf=16.0V(typ) Note: 1) The LED’s driver mode needs to be constant current mode. 2) Permanent damage to the device may occur if maximum values are exceeded. Functional operation should be restricted to the conditions described under normal operating conditions. 12.Optical Characteristics Item Brightness Uniformity Viewing Angle Contrast ratio Response Time CIE (x,y) Chromaticity White Red Green Blue NTSC Ratio Symbol Condition Bp ∆Bp θ1 (Ф=90° or 270°) θ2 (Ф=0° or 180°) Cr Tr Tf x y x y x y x y S θ=0º Ф=0º (VDDIO=3.3V, GND=VSS=0V, Ta=25°C) Min Typ Max Unit Note 220 70 ----- ----- cd/m² % 1 1, 2 deg 3 -70 ~ 50 Cr≥10 -70 ~ 70 θ=0º Ф=0º θ=0º Ф=0º 9 400 450 --- --- 4 --- 20 30 ms 5 0.273 0.298 0.536 0.307 0.294 0.427 0.104 0.052 --- 0.323 0.348 0.586 0.357 0.344 0.577 0.154 0.102 50 0.373 0.398 0.636 0.407 0.394 0.527 0.204 0.152 --- --- % 1, 6 Displaytech Ltd Note 1: LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 The data are measured after LEDs are turned on for 5 minutes. LCM displays full white. The brightness is the average value of 9 measured spots. Measurement equipment PR-705 (Φ8mm) Measuring condition: - Measuring surroundings: Dark room. - Measuring temperature: Ta=25°C. - Adjust operating voltage to get optimum contrast at the center of the display. Measured value at the center point of LCD panel after more than 5 minutes while backlight turning on. Note 2: The luminance uniformity is calculated by using following formula. ∆Bp = Bp (Min.) / Bp (Max.)×100 (%) Bp (Max.) = Maximum brightness in 9 measured spots Bp (Min.) = Minimum brightness in 9 measured spots. W/3 W/3 L/3 L/3 L/6 W/6 Measurement equipment PR-705 (Φ8mm) Note 3: The definition of viewing angle: Refer to the graph below marked by θ and 10 Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 Note 4: The definition of contrast ratio (Test LCM using PR-705): Luminance When LCD is at “White” state Contrast Ratio (CR) = Luminance When LCD is at “Black” state (Contrast Ratio is measured in optimum common electrode voltage) Note 5: Definition of Response time. (Test LCD using DMS501): The output signals of photo detector are measured when the input signals are changed from “black” to “white” (falling time) and from “white” to “black” (rising time), respectively. The response time is defined as the time interval between the 10% and 90% of amplitudes. Refer to figure as below. The definition of response time Note 6: Definition of Color of CIE Coordinate and NTSC Ratio. Color gamut: S= 11 area of RGB triangle area of NTSC triangle x 100% Displaytech Ltd LCD MODULE INT043BTFT / INT043BTFT-TS Version: 2.2 13. Safety Precaution Handling precautions: • This device is susceptible to Electro-Static Discharge (ESD) damage. Observe Anti-Static precautions. Power supply precautions: • Identify and, at all times, observe absolute maximum ratings for both logic and LC there is some variance between models. drivers. Note that • Prevent the application of reverse polarity to VCC and GND, however briefly. • Use a clean power source free from transients. Power up conditions are occasionally “jolting” and may exceed the maximum ratings of the modules. • The VCC power of the module should also supply the power to all devices that may access the display. Don’t allow the data bus to be driven when the logic supply to the module is turned off. Operating precautions: • DO NOT plug or unplug the module when the system is powered up. • Minimize the cable length between the module and host MPU. • Operate the module within the limits of the modules temperature specifications. Mechanical/Environmental precautions: • Improper soldering is the major cause of module difficulty. Use of flux cleaner is not recommended as they may seep under the elastomeric connection and cause display failure. • Mount the module so that it is free from torque and mechanical stress. • Surface of the LCD panel should not be touched or scratched. The display front surface is an easily scratched, plastic polarizer. Avoid contact and clean only when necessary with soft, absorbent cotton dampened with petroleum benzene. • Always employ anti-static procedure while handling the module. • Prevent moisture build-up upon the module and observe the environmental constraints for storage temperature and humidity. • Do not store in direct sunlight • If leakage of the liquid crystal material should occur, avoid contact with this material, particularly ingestion. If the body or clothing becomes contaminated by the liquid crystal material, wash thoroughly with water and soap 12
INT043BTFT-TS 价格&库存
很抱歉,暂时无法提供与“INT043BTFT-TS”相匹配的价格&库存,您可以联系我们找货
INT043BTFT-TS
  • 1+762.25122
  • 13+745.50577
  • 25+729.47888
库存:6
INT043BTFT-TS
库存:518
