2354
2354
    ADAFRUIT
2354 数据手册
ON TAT INDUSTRIAL COMPANY SPECIFICATION Product Model : YX700WV03 (Rev.A) Designed by R&D Checked by Quality Department by Approval by Customer OK NG,Problem survey: Approved By All Rights Reserved 1/18 Approved by ON TAT INDUSTRIAL COMPANY Revision Record REV NO. REV DATE CONTENTS A 2014-12-08 NEW ISSUE All Rights Reserved 2/18 Note REV A ON TAT INDUSTRIAL COMPANY Table Of Contents List Description Page No. Cover 1 Revision Record 2 Table Of Contents 3 1 Numbering System 4 2 General Information 4 3 External Dimensions 5 4 Interface Descrirtion 6 5 Absolute Maximum Ratings 6 6 Electrical Characteristics 6 7 Timing Characteristics 7 8 Backlight Charasterics 10 9 Optical Characteristics 11 10 Reliability Test Conditions And Methods 13 11 Inspection Standard 14 12 Handling Precautions 17 13 Precaution For Use 18 14 Packing Method 18 All Rights Reserved 3/18 REV A ON TAT INDUSTRIAL COMPANY 1. Numbering System 2. General Iinformation ITEM STANDARD VALUES UNITS LCD type 7.0’’TFT -- Dot arrangement 800×3(RGB)×480 dots Color Pixel Arrangement RGB vertical stripe -- Display Mode TN / Transmissive / Normally white -- 12 o’clock -- Module size 164.9(W)×100.0(H)×3.4(T) mm Active area 154.08(W)×85.92(H) mm Dot pitch 0.1926 (W)×0.1790 (H) mm Interface 24-bit Parallel RGB Interface -- Operating temperature -20 ~ +70 ℃ Storage temperature -30 ~ +80 ℃ Weight TBD g Viewing Direction All Rights Reserved 4/18 REV A ON TAT INDUSTRIAL COMPANY 3. External Dimensions 34.08±0.5 (80.96) 164.9±0.3(LCM OUTLINE) 156.7(BEZEL OPEN) 155.08(TP A.A) 154.08(LCD A.A) TFT NOTE: 1, LCD TYPE :16.7 COLOR ,TFT 2, VIEWING DIRECTION:12 0'CLOCK 3, BACKLIGHT 1)WHITE LED 18 series connection 4, DPERATION TEMP.:-20°~70° 5, STORAGE TEMP.:-30°~80° (5.49) (6.4) (6.9) 导通面 3.4±0.2 补强面 0.3±0.05 (FPC+PI) A K XR YD XL YU ON TAT INDUSTRIAL COMPANY REV A 5/18 All Rights Reserved (3.57) (4.28) (4.78) 100±0.3(LCM OUTLINE) 89.1(BEZEL OPEN) 86.92(TP A.A) 85.92(LCD A.A) (47.74) 65±0.5 ON TAT INDUSTRIAL COMPANY 4. Interface Pin Symbol Description. 1 LED-K LED backlight (Cathode). 2 LED-A LED backlight (Anode). 3 GND Ground. 4 VDD Power supply. 5~12 R0~R7 Red Data. 13~20 G0~G7 Green Data. 21~28 B0~B7 Blue Data. 29 GND Ground. 30 DCLK Dot clock signal input. Latching input data at its rising edge. 31 DISP Display on/off. 32 HSYNC Horizontal sync input. Negative polarity. 33 VSYNC Vertical sync input. Negative polarity. 34 DEN 35 NC 36 GND Ground. 37 XR TP Right. 38 YD TP Bottom. 39 XL TP Left. 40 YU TP Up. Data enable input. Active high to enable the input data bus. NC. 5. Absolute Maximum Ratings Item Symbol Min. Max. Unit Analog Supply Voltage VDD -0.3 5 V Input Voltage Vin -0.3 VDD+0.3 V Operating Temperature TOP -20 70 °C Storage Temperature TST -30 80 °C Storage Humidity HD 20 90 %RH 6. DC Characteristics Item Symbol Min. Typ. Max. Unit Remark Analog Supply Voltage VDD 3.0 3.3 3.6 V - Input High Voltage VIH 0.7VDD - VDD V Digital input pins Input Low Voltage VIL GND - 0.3VDD V Digital input pins Output High Voltage VOH VDD-0.4 - VDD V Digital output pins Output Low Voltage VOL GND - VDD+0.4 V Digital output pins I/O Leak Current ILI -1 - 1 uA - All Rights Reserved 6/18 REV A ON TAT INDUSTRIAL COMPANY 7. Timing Characteristics 7.1 Power ON/OFF Sequence Power on sequence (VDDVEEVGH) Power off sequence (VGHVEEVDD) 7.2 Timing Diagram of interface Signal Parallel 24-bit RGB Mode Input Clock and Data Timing Diagram All Rights Reserved 7/18 REV A ON TAT INDUSTRIAL COMPANY Source output timing diagram All Rights Reserved 8/18 REV A ON TAT INDUSTRIAL COMPANY All Rights Reserved 9/18 REV A ON TAT INDUSTRIAL COMPANY 8. Backlight Charasterics A K Item Symbol MIN TYP MAX UNIT Test Condition Supply Voltage Vf 9.3 9.9 10.5 V If=120mA Supply Current Luminous Intensity for LCM Life Time If - 120 180 mA - - 300 400 - Cd/m2 If=120mA - 20000 - - Hr If=120mA Backlight Color All Rights Reserved White 10/18 REV A ON TAT INDUSTRIAL COMPANY 9. Optical Characteristics Test Conditions: 1. DVDD=3.3V, IL=180mA (Backlight current), the ambient temperature is 25℃. 2. The test systems refer to Note 2. Note 1: Definition of viewing angle range Fig. 1 Definition of viewing angle All Rights Reserved 11/18 REV A ON TAT INDUSTRIAL COMPANY Note 2: Definition of optical measurement system. The optical characteristics should be measured in dark room. After 30 minutes operation, the optical properties are measured at the center point of the LCD screen. (Response time is measured by Photo detector TOPCON BM-7, other items are measured by BM-5A/Field of view: 1° /Height: 500mm.) Fig. 2 Optical measurement system setup Note 3: Definition of Response time The response time is defined as the LCD optical switching time interval between “White” state and “Black” state. Rise time (TON) is the time between photo detector output intensity changed from 90% to 10%. And fall time (TOFF) is the time between photo detector output intensity changed from 10% to 90%. Fig. 3 Definition of response time Note 4: Definition of contrast ratio Luminance measured when LCD on the " White " state Contrast ratio(CR) = Luminance measured when LCD on the " Black " state Note 5: Definition of color chromaticity (CIE1931) Color coordinates measured at center point of LCD. Note 6: All input terminals LCD panel must be ground while measuring the center area of the panel. The LED driving condition is IL=180mA . All Rights Reserved 12/18 REV A ON TAT INDUSTRIAL COMPANY 10. Reliability Test Conditions And Methods NO. ① ② ③ ④ TEST ITEMS High Temperature Storage Low Temerature Storage High Temperature Operating Low Temperature Operating ⑤ Temperature Cycle(Storage) ⑥ Damp Proof Test (Storage) ⑦ Vibration Test ⑧ Drooping Test ⑨ ESD Test TEST CONDITION INSPECTION AFTER TEST 80℃±2℃×200Hours -30℃±2℃×200Hours Inspection after 2~4hours storage at 70℃±2℃×120Hours room temperature,the samples should be free -20℃±2℃×120Hours from defects: 1,Air bublle in the LCD. -20℃ 25℃ 70℃ 2,Sealleak. (30min) (5min) (30min) 3,Non-display. 1cycle 4,Missing segments. Total 10cycle 5,Glass crack. 50℃±5℃×90%RH×120Hours 6,Current IDD is twice higher than initial value. Frequency:10Hz~55Hz~10Hz 7,The surface shall be Amplitude:1.5M free from damage. X,Y,Z direction for total 3hours 8,The electric (Packing Condition) Drop to the ground from 1M height charateristic requirements shall be one time satisfied. every side of carton. (Packing Condition) Voltage:±8KV,R:330Ω,C:150PF,Air Mode,10times REMARK: 1,The Test samples should be applied to only one test item. 2,Sample side for each test item is 5~10pcs. 3,For Damp Proof Test,Pure water(Resistance>10MΩ)should be used. 4,In case of malfunction defect caused by ESD damage,if it would be recovered to normal state after resetting,it would be judge as a good part. 5,EL evaluation should be excepted from reliability test with humidity and temperature:Some defects such as black spot/blemish can happen by natural chemical reaction with humidity and Fluorescence EL has. 6,Failure Judgment Criterion:Basic Specification Electrical Characteristic,Mechanical Characteristic,Optical Characteristic. All Rights Reserved 13/18 REV A ON TAT INDUSTRIAL COMPANY 11. Inspection Standard This standard apply to C-STN/TFT module 1. Spot check plan: According to spot check level Ⅱ,MIL-STD-105D Level Ⅱ,the rank of accept or reject is below: 3A 级、2A 级:major non-conformance:AQL 0.25 minor non-conformance:AQL 0.4 A 级:major non-conformance: AQL 0.65 2. minor non-conformance: AQL 1. Inspection condition: 30 degree Under daylight lamp 20~40W,product distance inspector’eye 30cm,incline degree 30°。 3. LCD area define: A B C Area A:display area Area B:VA area Area C:out of VA area,not in sight after assemby Remark :non-conformance at area C,but is OK that isn’t influence raliability of product & assembly by customer. All Rights Reserved 14/18 REV A ON TAT INDUSTRIAL COMPANY 4. Inspection standard 4.1 Major non-conformance NO. Item Inspection standard Rate Function 4.1.1 non-confor mance 1) No display,display abnormaly 2) Miss line, short 3) B/L no function or function abnormaly 4) TP no function 4.1.2 miss No matter miss what component 4.1.3 Out of size Module dimension out of spec major 4.2 Appearance non-conformance NO. Item Inspection standard Rate dot non-conformance defineΦ y Φ= ( x  y ) x 2 A grade Most approve q’ty area 4.2.1 Black or white spot (power on) size(mm) A B Φ≤0.10 ignore 0.10<Φ≤0.15 3 0.15<Φ≤0.20 2 0.20<Φ≤0.25 1 0.25<Φ 0 C Minor ignore Most approve 4 damages, dot to dot ≥10mm A grade Size(mm) 4.2.2 Black or white line (power on) Most approve q’ty A B L(length) W(width) ignore W≤0.03 ignore L≤5.0 0.03< W≤0.05 2 L≤3.0 0.05< W≤0.07 1 0.07<W Treat with dot non-conformance C Minor ignore Most approve 3 damages, line to line ≥10mm All Rights Reserved 15/18 REV A ON TAT INDUSTRIAL COMPANY 4.2.3 Polarizer 1) polarizer attach meet drawing,disallow out of LCD. position 2) polarizer must cover display area(special require unless) Minor (i) crash at side(remark: S=ITO length) X Y Z ≤3.0 ≤S ignore Crash disallow extend to ITO or seal. (ii) commonly surface scathe 4.2.4 LCD non-conf ormance Minor X Y Z ≤2.0
很抱歉,暂时无法提供与“2354”相匹配的价格&库存,您可以联系我们找货
    • 1+651.52080
    • 200+259.96680
