LCD-08884
LCD-08884
    SPARKFUNELECTRONICS
    LCDSERIALGRAPHIC160X128
LCD-08884 数据手册
Distar Technology Limited Http://www.distarltd.com Fax:86-755-26645987 Tel:86-755-26645997 SPECIFICATIONS LCD MODULE FOR DS-G160128STBWW PIXELS: 160 X 128 DOTS OUTLINE DIMENSION: 129.0 X 102.0 VIEWING AREA: 101.0 X 82.0 MM DOT SIZE: 0.54 X 0.54 MM DOT PITCH: 0.58 X 0.58 MM REV. A DATE 2007-3-15 REVISION RECORD PAGE MM COMMENT NEW RELEASE DISTAR TECHNOLOGY LIMITED DS-G160128STBWW CONTENTS 1. LCD MODULE NUMBERING SYSTEM 2. DISPLAY MODE MECHANICAL CHARACTERISTICS 2.1 DISPLAY SPECIFICATIONS 2.2 MECHANICAL DATA 2.3 MECHANICAL DRAWINGS 3. CIRCUIT BLOCK DIAGRAM 3.1 Electrical Block Diagram 3.2 Pins Definition 3.3 Power Supply For LCM Driving 4. ABSOLUTE MAXIMUN RATINGS 4.1 Electrical Absolute Maximum Ratings 4.2 Enviromental Absolute Maximum Ratings 5. ELECTRICAL CHARACTERISTICS 5.1 DC Characteristics 5.2 AC Characteristics 6. BACKLIGHT CHARACTERISTICS 6.1 Absolute Maximum Ratings 6.2 Operating Parameters 7. ELECTRO-OPTICAL CHARACTERISTIC 8. DISPLAY CONTROL INSTRUCTION 8.1 INSTRUCTION TABLE 8.2 Character Table 8.3 SOFTWARE EXAMPLES 9. INSPECTION STANDARDS 10. PRECAUTIONS IN USING LCM DISTAR TECHNOLOGY LIMITED 1. LCD MODULE NUMBERING SYSTEM FOR DS-G160128STBWW DS G DISTAR TECHNOLOGY LIMITED DISPLAY CONTENTS G---GRAPHIC TYPE 160128 ST 160X128 PIXELS LCD PANEL LCD TYPE:STN B W W BACKGROUND COLOUR : BULE BACKLIGHT COLOR : WHITE WIDE TEMPRETURE DS-G160128STBWW DISTAR TECHNOLOGY LIMITED DS-G160128STBWW K: DENOTE CHARACTER TABLE IS 00 2. DISPLAY MODE AND MECHANICAL CHARACTERISTICS 2.1 DISPLAY SPECIFICATIONS LCD MODE DISPLAY COLOR BACKGROUND COLOUR DRIVING DUTY BIAS VIEWING DIRECTION BACKLIGHT BACKLIGHT COLOR 2.2 : STN-NEGATIVE-TRANSMISSIVE : WHITE : BLUE : 1/128DUTY : 1/9 BIAS : 6 O’CLOCK : SIDE LED BACKLIGHT : WHITE MECHANICAL DATA ITEM STANDARD VALUE UNIT NUMBER OF PIXELS 160(COLUMNS) X128(ROWS) OUTLINE DIMENSIONS 129.0(W)X102.0(H) X 14.0(T) mm EFFECTTVE VIEWING AREA 101.0(W) X 82.0(H) mm DOT SIZE 0.54(W) X 0.54(H) mm DOT PITCH 0.58(W) X 0.58(H) mm 260 g APPROX 2.3 WEIGHT MECHANICAL DRAWINGS DISTAR TECHNOLOGY LIMITED DS-G160128STBWW DISTAR TECHNOLOGY LIMITED DS-G160128STBWW 3. CIRCUIT BLOCK DIAGRAM 3.1 Electrical Block Diagram 3.2 Pins Definition PIN SYMBOL FUNCTION 1 FG FRAME GROUND 2 Vss Power Supply(GND) 3 Vdd Power Supply For Logic(+5V) 4 Vo Power Supply For LCD Driving (Contrast Adjust) 5 VEE NEGATIVE VOLTAGE INPUT/OUTPUT 6 /WR DATA WRITE 7 /RD DATA READl 8 /CE CHIP ENABLE FOR T6963C 9 C/D COMMAND/DATA SELECTION 10 /HALT CLOCK OPERATING STOP SIGNAL 11 /RST RESET T6963C(LOW EFFECTIVE) 12--19 DB0—DB7 DATA BUS 20 NC NO CONNECTION 21 LEDA LED BACKLIGHT POWER SUPPLY(+)(+5V) DISTAR TECHNOLOGY LIMITED 22 3.3 LEDK DS-G160128STBWW LED BACKLIGHT POWER SUPPLY(-)(0V) Power Supply For LCM Driving 3.3.1 For LCM With DC/DC on Board(Internal Negative Voltage) +5V Vdd NOTES: Vdd LCD MODULE GND Vss V0 VEE VR Vdd-V0: LCD Driving Voltage VR: 10K - 20K VEE: Genarated By On Board DC-DC VLED: LED BACKLIGHT DRIVING VOLTAGE 4.2V For Yellow/Green LED Backlight 3.2V For White LED Backlight -10V OUTPUT A VLED K 3.3.2 For LCM without DC/DC on Board(Negative Voltage input) Vdd +5V NOTES: Vdd LCD MODULE Vss GND V0 VEE VR VEE Vdd-V0: LCD Driving Voltage VR: 10K - 20K VEE: Need External Negative Voltage VLED: LED BACKLIGHT DRIVING VOLTAGE 4.2V For Yellow/Green LED Backlight 3.2V For White LED Backlight -10V A K VLED 4. ABSOLUTE MAXIMUN RATINGS 4.1 Electrical Absolute Maximum Ratings ITEM Supply Voltage (Logic) Supply Voltage (LCD Drive) SYMBOL CONDITION MIN MAX UNIT Vdd – Vss - -0.3 7.0 V Vdd – V0 - 0 25.0 V DISTAR TECHNOLOGY LIMITED Input Voltage 4.2 Vi DS-G160128STBWW - -0.3 Vdd +0.3 V Enviromental Absolute Maximum Ratings ITEM SYMBOL CONDITIONS Operating Temp Topr -Normal Storage Temp Ttsg version- Humidity RH Endurance Vibration MIN temp. MAX UNIT -20 70 deg C -30 80 deg C - 95 % - 4.9m/ss no ondensation Ta
LCD-08884 价格&库存
很抱歉,暂时无法提供与“LCD-08884”相匹配的价格&库存,您可以联系我们找货
