LCD-OLINUXINO-10TS
LCD-OLINUXINO-10TS
    OLIMEX
    LCD-OLINUXINO-10TS
LCD-OLINUXINO-10TS 数据手册
FLAME approved sheet Model No : F101T50 Customer: Version: Date: 2012-02-17 CUSTOMER’S Accept APPROVAL&DATE: CUSTOMER’S APPROVAL : A.Configuration: □ OK □NG B.Function: □ OK □NG C.Standard for product check: □ OK □NG D.Other: □ OK □NG CUSTOMER’S SIGNATURE &DATE: For MJK’s improve,please tick or explain it(them) as belows while on debugging on our products: □A.price away from our target: □B.other supply’s debugging success: □C.Sample period away from our target: □D.Project cancel : □E.NO need to test for solution change: □F.Other: Page 1 of 23 Product Specification Standard LCD Module 1024(RGB) x 600Dots graphic type 10.1”TFT 16.2M Transmissive LCD COG bonding type Product Wide temperature LED back light Without Touch Panel 50PIN 24Bits TTL interface Page 2 of 23 变更记录 日期 版本 修改 页码 变更前描述 变更后描述 备注 Page 3 of 23 Product Model description M □ (1) (2) □□□ - □□□ □ (3) (4) (5) □ (6) □ (7) □ (8) □ 9 □ 10 Down Polaroid type W( Anti-Glare G-Glare) Up Polaroid type (W- Anti-Glare G-Glare) Product whether touch N- Without T-With Product version number Product angle of view: ( D---6 O’CLOCK L—9 O’CLOCK U—12 O’CLOCK R—3 O’CLOCK) Product display mode: (T—Transmissive R—Reflective F—Transflective) Product Number Product dimension (101-10.1 Inch) Product type ( D-- model;P—OPENCELL; C—CELL; U -–FULLCELL;B--PCBA;) optoelectronics limited Page 4 of 23 -- Contents -Revision …………………………………………………………….. 1. Summary........………………………………………………….. 2. Features.........………………………….....……………………. 3. General Specifications.................……………………….. 4 .Function Block Diagram…………………………………… 5. Absolute Maximum Ratings………………………………. 6. Electrical Characteristics ……….............….......………. 7. Pixel Format Image………………………………………….. 8. Optical Characteristics…………………………………….. 9. Interface Characteristics ………………………………….. 10. Interface Timings ………………………….…….……… 11. Mechanical Characteristics …………………………. 12. Package …………………………………………………….. Page 5 of 23 1. Summary This technical specification applies to 10.1” color TFT-LCD is a color active matrix thin film transistor (TFT) liquid crystal display(LCD) that uses amorphous silicon TFT as a switching device. It is composed of a TFT LCD panel, a timing controller, voltage reference, common voltage, column driver, and row driver circuit. This TFT LCD has a 10.1-inch diagonally measured active display area with WSVGA resolution (1024 vertical by 600 horizontal pixel array) 2. Features ■ ■ ■ ■ 10.1” WSVGA TFT LCD Panel LED Light-bar Backlight System(9 Parallel 3 Serial) Supported WSVGA (V:1024 lines, H:600 pixels) Resolution DualGate(1 Source + 1Gate) 3.General Specifications Contents Contents Unit NO Item (1) Module Outsize(mm) 235.00 x 143.00 x 5.40(Max.) mm (2) LCD Active area(mm) 222.72(H) x 125.28(V) mm (3) Display resolution(dot) 1024(x3) x 600 dot (4) Screen size(inch) 10.1 Inch (5) Dot pitch(mm) 0.2175(H) x 0.2088(V) mm (6) Color configuration R.G. B vertical stripe - (7) Support color 16.2M - (8) Display Mode Normally White(TN) - (9) Gray Scale inversion 6 o'clock - (10) LCD type a-si TFT - (11) Electrical Interface(Logic) 50PIN 24Bits TTL interface - (12) Weight TBD g (13) Panel surface treatment Glare MD101-056TDANGG --- (14) White Luminance 200 (Typ.) 5 points average Cd/m2 (15) Contrast Ratio 600 (Typ.) (16) Input Voltage(V) +3.3 (Typ.) Logic Voltage V (17) Power Consumption(W) TBD Logic system watt Page 6 of 23 4.Function Block Diagram Figure 1 shows the functional block diagram of the LCD module. Figure 1 Block diagram TTL RGB 24 BITS DVDD AVDD VCOM GND RESET DITHB DCLK HS VS DE MODE L/R U/D VGH VGL LCD Panel DATA BUS(R7~R0,G7~G0,B7~B0) 1024RGB X 600Dots 27-chip 9-Parallel 3 Serial VLED- VLED+ Page 7 of 23 5.Absolute Maximum Ratings Item Symbol Min Max Unit Digital Supply Voltage VDD -0.3 4 V Analog Supply Voltage AVDD -0.5 15 V Gate On Voltage VGH -0.3 42 v Gate Off Voltage VGL -20 0.3 V Logic Signal Input Level VI -0.3 VDD+0.3 V Forward Current (per LED) If -- 30 mA Reverse Voltage(per LED) VR -- 5 V Pulse forward current(per LED) Ifp -- 100 mA Condition Note 1、2 Note: Note1:Ifp Conditions : Pulse Width ≦10msec;Duty ≦1/10 Note2:perating must under the condition as below drawing. (Ambient Temperature /Allowable Forward Current) Each LED . Page 8 of 23 6.Electrical Characteristics 6.1 TFT LCD ITEM SYMBOL MIN TYP MAX UNIT Digital Power Supply Voltage For LCD VDD 3 3.3 3.6 V VDD Current IDD -- 150 -- mA Logic Signal Input Level ViH 0.7 Vcc - VCC V ViL 0 - 0.3 Vcc V Analog Power Supply Voltage AVDD TBF 10.85 TBD V Gate On Power Supply Voltage VGH 18 19 20 V Gate Off Power Supply Voltage VGL -9 -8 -7 V Common Power Supply Voltage VCOM 2.2 3.2 4.2 V NOTE Note: 1. Please adjust VCOM to make the flicker level be minimum. Page 9 of 23 6.2 Power、Signal sequence Page 10 of 23 6.3 Backlight Symbol Parameter Min. Typ. Max. Units Condition VF (BL+) - (BL-) 9 9.6 10 V Ta=25℃ IF LED Current - 180 - mA Ta=25℃ PLED LED Power Consumption -- 2.5 -- W Ta=25℃ LT LED Life Time 10000 - - Hours Ta=25℃ Note C Note: A: The LED life time define as the estimated time to 50% degradation of initial luminous. B: Calculator value for reference PLED =VF(normal Distribution) x IF (Normal Distribution) / Efficiency C: LED Circuit Diagram A K D: Suggestion: Using the constant current control to avoid the leakage light and brightness quality issue. Page 11 of 23 7.Pixel Format Image Figure 2 shows the relationship of the input signals and LCD pixel format image. Figure 2 Pixel Format Page 12 of 23 8.Optical Characteristics The optical characteristics are measured under stable conditions as following notes. Table 2 Optical Characteristics Item Conditions Specification Min. Viewing Angle [degrees] K=Contrast Ratio>10 Horizontal Vertical Typ. Max. Left -- 70 - Right -- 70 - Up -- 60 - Down -- 70 - Note A,B Contrast ratio Center -- 600 -- A,C Response Time [ms] Rising + Falling - 3+5 16 A,D Color Chromaticity (CIE1931) Red x 0.58 0.63 0.68 A, Red y 0.26 0.31 0.36 A, Green x 0.224 0.295 0.344 A, Green y 0.468 0.518 0.568 A, Blue x 0.093 0.143 0.193 A, Blue y 0.101 0.153 0.201 A, White x 0.245 0.295 0.345 A, White y 0.281 0.331 0.381 A, - 200 - 5point A, E - - - 80 - - White Luminance [cd/m^2] I-LED=20.0mA Luminance Uniformity [%] I-LED=20.0mA 13points I-LED=20.0mA 5points A, F (Note: Backlight is M-BL-101-009V0) Note: A. Measurement Setup The LCD module should be stabilized at given temperature for 15 minutes to avoid abrupt temperature change during measuring. In order to stabilize the luminance, the measurement should be executed after lighting backlight for 15 minutes in a windless room. Page 13 of 23 Figure 3 Measurement Setup B. Definition of Viewing Angle Figure 4 Definition of Viewing Angle C. Definition of Contrast Ratio (CR) The contrast ratio can be calculated by the following expression Contrast Ratio (CR) = L63 / L0 L63: Luminance of gray level 63, L0: Luminance of gray level 0 Page 14 of 23 D. Definition of Response Time (TR, TF) Figure 5 Definition of Response Time Figure 6 Measurement Locations of 13 Points E. Definition of Luminance White Measure the luminance of gray level 63 at center point and 5 points. Center of Luminance = Y1 Average Luminance of 5 points = (Y1 + Y2 + Y3 + Y4 + Y5)/5 F. Definition of Luminance Uniformity(Variation) Measure the luminance of gray level 63 at 13 points. Page 15 of 23 9.Interface Characteristics 9.1 CN1 (Input Signal) PIN NO SYMBOL 1 NC No connect 2 NC No connect 3 NC No connect 4 NC No connect 5 GND 6 VCOM 7 VDD 8 MODE 9 DE Data Input Enable 10 VSD Vertical Sync Input 11 HSD Horizontal Sync Input 12 B7 Blue data 13 B6 Blue data 14 B5 Blue data 15 B4 Blue data 16 B3 Blue data 17 B2 Blue data 18 B1 Blue data 19 B0 Blue data 20 G7 Green data 21 G6 Green data 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 5G Green data G4 Green data G3 Green data G2 Green data G1 Green data G0 Green data R7 Red data R6 Red data R5 Red data R4 Red data R3 Red data R2 Red data R1 Red data R0 Red data GND DESCRIPTION REMARK Digital ground Common voltage Digital Power DE/HV SYNC mode select H: DE L: HV Digital ground Page 16 of 23 37 38 39 40 41 42 43 44 DCLK GND L/R U/D VGH VGL AVDD RESET 45 46 47 NC VCOM DITHB Clock input Digital ground Left or Right Display Comtrol Up or Down Display Comtrol Positive power for TFT Negative power for TFT Analog power Global reset pin. Active low to enter reset state. Suggest to connecting with an RC reset circuit Normally pull high. (R=10KΩ,C=0.1μF) No connect Common voltage Dithering function enable control. Normally pull low DITHER = “1”, Enable internal dithering function DITHER = “0”, Disable internal dithering function Digital ground No connect No connect (IBST,Reserve for MJK test) GND 48 NC 49 NC 50 Remarks: 1) UPDN and SHLR control function Customer must be open Page 17 of 23 9.2 CN2 (LED backlight) PIN NO SYMBOL FUNCTION 1 2 A K Anode Cathode Page 18 of 23 10.Interface Timings 10.1 TTL mode AC electrical characteristics Page 19 of 23 10.2 TTL mode data input format Page 20 of 23 9.5 Parallel RGB input timing table: Resolution:1024x600 Page 21 of 23 11.Mechanical Characteristics Page 22 of 23 12.Package TBD Page 23 of 23
LCD-OLINUXINO-10TS 价格&库存
很抱歉,暂时无法提供与“LCD-OLINUXINO-10TS”相匹配的价格&库存,您可以联系我们找货
