PE300B-10FM
PE300B-10FM
    EXCELITASTECHNOLOGIES(埃赛力达)
    MODULECERMAX300W
PE300B-10FM 数据手册
UNCONTROLLED COPY PE300B-10FM 300 Watt Cermax® f/1.0 Module Min Nominal Max Comments 1. Ignition Requirements 1.1 Peak Ignition Voltage at Lamp Terminals (kV) 23 - 35 1.2 Ignition Pulse Width FWHM at Lamp Terminals (ns) 75 100 150 1.3 Recommended Boost Voltage at Lamp Terminals (Volts) 180 210 240 1.4 Boost Current at Lamp Terminals (Amps) - - 66 1.5 Boost Circuit RC discharge time (ms) 0.75 1.0 1.5 1.6 Boost Energy (Joules) 1.5 2.0 2.5 Not to exceed 36kV for electrical safety 1.7 Recommended discharge energy in ignition transformer 0.1 to 0.2 Joules. 1.8 Main DC power supply to deliver operating current within RC discharge time of boost circuit. 1.9 Ignition requirements applicable throughout lamp life. 2. Electrical 2.1 Operating Power (Watts) 175 300 305 2.2 Operating Current (Amps) 13.0 22.0 23.0 2.3 Initial Lamp Voltage (Volts) 11.5 13.5 15.0 - - 2 2.4 Ripple Current 0 - 1kHz (pk-pk %) Voltage may change over lamp life 3. Light Output / Performance at Nominal Power (initial only unless otherwise specified) 3.1 Spot Size at Focus - FWHM (inches) - .09 - 3.2 Radiant Output (Watts) - 65 - 3.3 UV Output < 390nm (Watts) - 3.3 - 3.4 IR Output > 770nm (Watts) - 32 - 3.5 Total Visible Output 390 - 770nm when new (Lumens) - 6900 - 3.6 Total Visible Output 390 - 770nm @ 500 hours (Lumens) - 3450 - 3.7 Color Temperature (Kelvin) - 5900 - 3.8 Initial Focused Output into 6mm aperture (Lumens) 2400 3500 - May decrease 5-10% over lamp life 39 3.9 Initial I i i l Focused F d Output O into i 3mm 3 aperture (L (Lumens)) - 2000 - 3.10 Peak instabilities 0 - 100Hz, integrated light when new (%) - 4 6 As per Excelitas test method and equipment 3.11 Peak instabilities 0 - 100Hz, integrated light @ 1000 hours (%) - - 8 As per Excelitas test method and equipment 4. Mechanical & Environmental 4.1 Window Diameter (millimeters) 4.2 Recommended Exit Air Flow (CFM) 4.3 4.4 - 25.4 - 35 45 - Operating Temperature at top center of ceramic (Celsius) 90 120 150 Storage Temperature (Celsius) -40 - 70 4.5 Ambient Starting Temperature (Celsius) 0 - - 4.6 Operating Humidity (% non-condensing) - - 85 4.7 Weight (Grams) - 750 - 4.8 Recommended Environmental Operating Pressure (hPa) 300 1010 1050 4.9 Operating Orientation (Degrees from horizontal) -45 0 45 Max is at end of life hPa = hectopascals (Pascals x 100) = millibar 4.10 Material composition for lamp module housing 20% glass filled nylon (UL94VO). Maximum recommended temperature is 100ºC. 4.11 Optical components used with lamp module should not impede air flow, nor should they reflect radiated energy back towards the lamp. 4.12 Air flow and air inlet temperature should always ensure lamp temperature is kept within specification throughout lamp life. 4.13 EMI characteristics may vary with operating hours and power. Adequate system precautions should be taken. 4.14 Additional EMI may result when operated outside the recommended power range. 4.15 Non-operating Shock and Vibration per ISTA1A. 5. Warranty & Limitation of Excelitas Technologies Liability 5.1 Warranty Period : 12 months 5.2 Warranty : 50% of initial 6mm lumens output minimum specification at 500 hours of continuous operation with no more than 1000 ignition cycles conditional on operation within specification limits & warranty period. 5.3 Where no minimum or maximum value is specified, the value is nominal only and may vary. 5.4 Excelitas assumes no responsibility for the suitability of this product for any particular application or any consequential damages associated with the use of this product. 5.5 Specifications subject to change without notice. This document contains confidential information of Excelitas Technologies. The contents shall not be disclosed, reproduced, duplicated, disseminated, or used for purposes other than authorized in writing by Excelitas Technologies. 231148 Rev. B Sheet 2 of 2
PE300B-10FM 价格&库存
很抱歉,暂时无法提供与“PE300B-10FM”相匹配的价格&库存,您可以联系我们找货
