1054
1054
    ADAFRUIT
    Ф10mm
1054 数据手册
Laser Diode - 5mW 650nm Red PRODUCT ID: 1054 DESCRIPTION - You have some frickin' sharks at your lair, and you're thinking "it would be really great if I could attach some lasers to them" and then you see these little laser diode modules: what great timing! These encapsulated laser diodes are Class IIIa 5mW, with a 650nm red wavelength. They can be driven from 2.8V to 5.2V so they're great for your embedded electronics project. You can use these for laser harps, electronic 'trip wires', laser-vision guidance, and more! Simply connect power to the red and black wires and you will be lasing in no time. Please note: this is not a laser pointer. It's a diode with integrated driver. You still need a 3 to 5VDC power supply. These diodes are 5mW output, and have a safety label marked on them. For more information on laser safety and ratings check out the Wikipedia page http://www.adafruit.com/products/1054 10/5/2015 Technical Details Weight: 6.3g Diameter: 10mm / 0.4" Length: 31mm / 1.2" Wire length: at least 100mm / 3.9" 650nm wavelength 2.8 - 5.2V DC voltage input 25mA max current draw Operating temperature -10°C to 40°C;
很抱歉,暂时无法提供与“1054”相匹配的价格&库存,您可以联系我们找货
    • 1+110.92680
    • 200+44.25840
    • 500+42.77880
    • 1000+42.05520
