US-Lasers: 850nm-5mW - Infrared Laser Diode and Infrared Diode Laser Module
Page 1 of 1
Laser Module
Links to Laser Diode &
Laser Module
Configurations and
Specifications >>>>>>>>>>
Barrel Specs:
Laser Diode
Laser Diode Module
Micro Laser Module
Variable Output
Laser Diode Module
MM850-5
Weight & Wire Lengths:
Lens Housing Specs:
z 2 Pieces
z Module with 6" wire leads - 49 grain wt.b
z 12 - 56 Thread Size
z Module without 6" wire leads - 42 grain wt
z 3.0mm Aperture
z Dia: 6.4mm
z Module with spring leads - 42 1/2 grain wt.
z 4.0mm Plastic Lens
z Length: 17mm
z Spring 2.4mm dia. 4mm long (trimmable)
INFRARED DIODE LASER ABSOLUTE MAXIMUM RATINGS - (Tc=25 °C)
TECHNICAL DATA for LASER DIODE
z
Index Guided MQW Structure
z
Wavelength: 850nm (Typ.)
z
Optical Power: 5mW CW
z
Threshold Current: 20mA (Typ.)
z
Standard Package: 5.6mm
Infrared light output
Pin Out Diagram - Style A
850nm
Optical power output
5mW CW
Package Type
5.6mm
Built-in photo diode for monitoring laser output
Items
Optical output power
Laser diode reverse voltage
Photo diode reverse voltage
Operating temperature
Storage temperature
Symbols
Po
VLDR
VPDR
Topr
Tstg
Values
5
2
30
-10 ~ +40
-40 ~ +85
Unit
mW
V
V
°C
°C
OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC)
Items
Threshold current
Operating current
Operating voltage
Lasing wavelength
Beam divergence
Beam divergence
Slope Efficiency (mW/mA)
Monitor current
Astigmatism
Symbols
Po
Ith
Iop
Vop
8D
θF
θz
Im
As
MTTF
Emitter Size
Emitter Distance to Cap Lens
Structure
Min.
10
15
2.0
840
8
25
0.4
10
Typ.
5
2.4
850
10
31
0.5
100
11
3000-5,000
hrs.
Max.
35
45
2.7
860
11
40
0.7
200
Unit
mW
mA
mA
V
nm
deg
deg
µA
µm
Test Condition
Po=5mW
Po=5mW
Po=5mW
Po=5mW
Po=5mW
Po=5mW,Vr=5V
Po=5mW
Po=5mW,NA=0.4
1 x 4 Microns
0.3mm
Index Guided
http://www.us-lasers.com/mmn850nm5m.htm
4/7/2009
很抱歉,暂时无法提供与“MM8505I”相匹配的价格&库存,您可以联系我们找货
