M6355I
M6355I
    US-LASERSINC.
    Module
    M6355I
M6355I 数据手册
US-Lasers: 635nm-5mW - Red Laser Diode and Red Diode Laser Module Page 1 of 2 US-Lasers: 635nm-5mW - Red Laser Diode and Red Diode Laser Module Links to Laser Diode & Laser Module Configurations and Specifications >>>>>>>>>> Laser Diodes Laser Diode Module Micro Laser Module N635-5 NM635-5 Variable Output Laser Diode Module EPM635-5 MM635-5 DATA SHEETS .... MM635nm 5mW ....RED LASER MODULE Barrel Specs: Weight & Wire Lengths: Lens Housing Specs: z 2 Pieces z Module with 6" wire leads - 49 grain wt.b z 12 - 56 Thread Size z 12 - 56 Thread Size z Module without 6" wire leads - 42 grain wt z 3.0mm Aperture z Dia: 6.4mm z Module with spring leads - 42 1/2 grain wt. z 4.0mm Plastic Lens z Length: 17mm z Spring 2.4mm dia. 4mm long (trimmable) RED LASER DIODE DATA SHEET ABSOLUTE MAXIMUM RATINGS - (Tc=25 ° C) TECHNICAL DATA Visible laser diode light 635nm output Optical power output 5mW CW Package Type 5.6mm Built-in photo diode for monitoring laser output Pin Out Diagram Items Symbols Values Unit Optical output power Po 5 mW Laser diode reverse voltage V 2 V Photo diode reverse voltage V 30 V Operating temperature Topr -10 ~ +40 °C Storage temperature Tstg -40 ~ +85 °C OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC) Items Optical output power Threshold current Operating current Operating voltage Lasing wavelength Beam divergence Symbols Po Ith Iop Vop http://www.us-lasers.com/mmd635nm5m.htm Min. 30 630 5 Typ. 35 45 635 8 Max. 5 45 70 2.5 645 11 Unit mW mA mA V nm deg Test Condition Kink free Po=5mW P o=5mW Po=5mW Po=5mW Po=5mW 4/6/2009 US-Lasers: 635nm-5mW - Red Laser Diode and Red Diode Laser Module Beam divergence Off Axis Angle Off Axis Angle Monitor current Astigmatism MTTF Emitter Size Structure Im As 25 - 31 35 11 37 +/-3 +/-3 3-5,000 hrs. Page 2 of 2 deg deg deg uA um Po=5mW Po=5mW,VR=5V Po=5mW,NA=0.4 Po=5mW 10 x 60 Microns - Emitter Distance to Cap Lens = 0.3mm IlGaInP MQW http://www.us-lasers.com/mmd635nm5m.htm 4/6/2009
M6355I 价格&库存
很抱歉,暂时无法提供与“M6355I”相匹配的价格&库存,您可以联系我们找货
