VOL6505I
VOL6505I
    US-LASERSINC.
    Module
    VOL6505I
VOL6505I 数据手册
US-Lasers: 650nm-5mW Samsung Visible Laser Diode Specifications Page 1 of 1 US-Lasers: 650nm-5mW Samsung Visible Laser Diode Specifications Links to Laser Diode & Variable Output Laser Diodes Laser Diode Module Micro Laser Module Laser Module Laser Diode Module Configurations and Specifications SD650-5 SM650-5 MM650-5 EPSM650-5 >>>>>>>>>> DATA SHEETS .... EPSM & SM650nm 5mW ....RED LASER MODULE Barrel Specs: z z z 3/8 - 56 Thread Size Dia: 10.4mm Length: 17mm Collect Specs: z z z Lens Housing Specs: 3/8 - 56 Thread Size 4.3mm Aperture Half Hard Brassbbb RED LASER DIODE DATA SHEET z z z 3/8 - 56 Thread Size 3.7mm Aperture 7mm Plastic Lens ABSOLUTE MAXIMUM RATINGS (Tc=25 °C) TECHNICAL DATA Visible laser diode light 650nm output Optical power output 5mW CW Package Type TO-18 Built-in photo diode for monitoring laser output Pin Out Diagram - Style A Items Symbols Values Unit Optical output power Po 7 mW Laser diode reverse voltage V 2 V Photo diode reverse voltage V 30 V Operating temperature Topr -10 ~ +60 °C Storage temperature Tstg -40 ~ +85 °C OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC) Items Symbols Min. Typ. Max. Optical output power Po 5 Threshold current Ith 35 45 Operating current Iop 45 55 Operating voltage Vop 2.2 2.6 Lasing wavelength 640 655 658 Beam divergence 7 8 10 22 30 38 Monitor current Im 100 200 500 http://www.us-lasers.com/sd650nm5.htm Unit mW mA mA V nm deg deg µA Test Condition Po=5mW Po=5mW Po=5mW Po=5mW Po=5mW Po=5mW 4/7/2009
VOL6505I 价格&库存
很抱歉,暂时无法提供与“VOL6505I”相匹配的价格&库存,您可以联系我们找货
