Cross Laser Diode - 5mW 650nm Red
PRODUCT ID: 1058
DESCRIPTION
You have some frickin' sharks at your lair, and you're thinking "it would be really
great if I could attach some lasers to them" and then you see these little laser diode
modules: what great timing! These encapsulated laser diodes are Class IIIa 5mW,
with a 650nm red wavelength. They can be driven from 2.8V to 5.2V so they're
great for your embedded electronics project.
This particular module has a lens attached that will turn the dot into a cross. This
makes it particularly good for laser-vision guidance, targeting, and more! Simply
connect power to the red and black wires and you will be lasing in no time.
The cross has a beam spread of approximately 60° in both directions. So from a
distance of 5cm, the cross is 5cm tall and 5cm wide. The cross ends have a sharp
cutoff so the shape is very clearly defined.
Please note: this is not a laser pointer. It's a diode with integrated driver. You still
need a 3 to 5VDC power supply. These diodes are 5mW output, and have a safety
label marked on them. For more information on laser safety and ratings check out
the Wikipedia page
http://www.adafruit.com/products/1058
10/5/2015
Technical Details
Weight: 11.85g
Diameter: 10.11mm
Length: 32.82mm
Wire length: 100mm
650nm wavelength
2.8 - 5.2V DC voltage input
25mA max current draw
Operating temperature -10°C to 40°C;
很抱歉,暂时无法提供与“1058”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+166.84920
- 200+66.57120
- 500+64.34640
- 1000+63.25560
