M8085I
M8085I
    US-LASERSINC.
    Module
    M8085I
M8085I 数据手册
US-Lasers: 808nm-5mW - Infrared Laser Diode and Infrared Diode Laser Module Page 1 of 1 US-Lasers: 808nm-5mW - Infrared Laser Diodes and Infrared Diode Laser Modules Back To Laser Modules TECHNICAL DATA for LASER MODULE Barrel Specs: z z z Collect Specs: 3/8 - 56 Thread Size Dia: 10.4mm Length: 17mm z z z Lens Housing Specs: 3/8 - 56 Thread Size 4.3mm Aperature Half Hard Brassbbb INFRARED DIODE LASER DATA SHEETS z z z 3/8 - 56 Thread Size 3.7mm Aperture 7mm Plastic Lens ABSOLUTE MAXIMUM RATINGS - (Tc=25 °C) TECHNICAL DATA for LASER DIODE z Index Guided MQW Structure z Wavelength: 808nm (Typ.) z Optical Power: 5mW CW z Threshold Current: 25mA (Typ.) z Standard Package: 5.6mm Infrared light output Pin Out Diagram - Style A 808nm Optical power output 5mW CW Package Type 5.6mm Built-in photo diode for monitoring laser output Items Optical output power Laser diode reverse voltage Photo diode reverse voltage Operating temperature Storage temperature Symbols Po VLDR VPDR Topr Tstg Values 5 2 30 -10 ~ +40 -40 ~ +85 Unit mW V V °C °C OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC) Items Optical output power Threshold current Operating current Operating voltage Lasing wavelength Beam divergence Beam divergence Slope Efficiency (mW/mA) Monitor current Astigmatism Symbols Po Ith Iop Vop 8D θF θz 0 Im As MTTF Emitter Size Emitter Distance to Cap Lens Structure Min. 10 15 1.9 800 8 20 0.1 10 - Typ. 5 20 25 2.1 808 11 35 0.3 100 11 3000-5,000 hrs. Max. 35 45 2.5 820 15 45 0.6 200 - Unit mW mA mA V nm deg deg µA µm Test Condition Po=5mW Po=5mW Po=5mW Po=5mW Po=5mW Po=5mW,Vr=5V Po=5mW Po=5mW,NA=0.4 1 x 4 Microns 0.3mm Index Guided http://www.us-lasers.com/m808nm5m.htm 4/6/2009
M8085I 价格&库存
很抱歉,暂时无法提供与“M8085I”相匹配的价格&库存,您可以联系我们找货
