Line Laser Diode - 5mW 650nm Red
PRODUCT ID: 1057
DESCRIPTION
You have some frickin' sharks at your lair, and you're thinking "it would be really
great if I could attach some lasers to them" and then you see these little laser diode
modules: what great timing! These encapsulated laser diodes are Class IIIa 5mW,
with a 650nm red wavelength. They can be driven from 2.8V to 5.2V so they're
great for your embedded electronics project.
This particular laser diode has a lens attached to turn the dot into a line. We think
this would be particularly good for making a 3D scanner, but there are probably
many other cool uses! Simply connect power to the red and black wires and you will
be lasing in no time.
The line beam spread is 120° - so from a distance of 5cm the line is 15cm long.
The line fades out and doesn't have a sharp cut-off.
Please note: this is not a laser pointer. It's a diode with integrated driver. You still
need a 3 to 5VDC power supply. These diodes are 5mW output, and have a safety
label marked on them. For more information on laser safety and ratings check out
the Wikipedia page
http://www.adafruit.com/products/1057
10/5/2015
Technical Details
Weight: 11.85g
Diameter: 10.11mm
Length: 32.82mm
Wire length: 100mm
650nm wavelength
2.8 - 5.2V DC voltage input
25mA max current draw
Operating temperature -10°C to 40°C;
