US-Lasers: 780nm-10mW - Infrared Laser Diode and Infrared Diode Laser Module
Page 1 of 1
Laser Module
Back To Laser Modules
TECHNICAL DATA for LASER MODULE
Barrel Specs:
z
z
z
Collect Specs:
3/8 - 56 Thread Size
Dia: 10.4mm
Length: 17mm
z
z
z
Lens Housing Specs:
4.3mm Aperature
Half Hard Brassbbb
INFRARED DIODE LASER DATA SHEETS
z
z
z
3.7mm Aperture
7mm Plastic Lens
ABSOLUTE MAXIMUM RATINGS - (Tc=25 °C)
TECHNICAL DATA for LASER DIODE
z
Index Guided MQW Structure
z
Wavelength: 780nm (Typ.)
z
Optical Power: 10mW CW
z
Threshold Current: 45mA (Typ.)
z
Standard Package: 9mm
Infrared light output
Pin Out Diagram - Style A
780nm
Optical power output
10mW CW
Package Type
9mm
Built-in photo diode for monitoring laser output
Items
Optical output power
Laser diode reverse voltage
Photo diode reverse voltage
Operating temperature
Storage temperature
Symbols
Po
VLDR
VPDR
Topr
Tstg
Values
10
2
30
-10 ~ +40
-40 ~ +85
Unit
mW
V
V
°C
°C
OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC)
Items
Threshold current
Operating current
Operating voltage
Lasing wavelength
Beam divergence
Beam divergence
Slope Efficiency (mW/mA)
Monitor current
Astigmatism
Symbols
Po
Ith
Iop
Vop
8D
θF
θz
Im
As
MTTF
Emitter Size
Emitter Distance to Cap Lens
Structure
Min.
15
30
2.0
770
8
25
0.4
10
Typ.
10
25
40
2.4
780
10
31
0.5
30
11
3000-5,000
hrs.
Max.
40
60
2.7
790
11
40
0.7
90
Unit
mW
mA
mA
V
nm
deg
deg
µA
µm
Test Condition
Po=10mW
Po=10mW
Po=10mW
Po=10mW
Po=10mW
Po=10mW,Vr=5V
Po=10mW
Po=10mW,NA=0.4
1 x 40 Microns
0.3mm
Index Guided
http://www.us-lasers.com/m780nm10m.htm
4/6/2009
很抱歉,暂时无法提供与“M780-10”相匹配的价格&库存,您可以联系我们找货
