US-Lasers: 808nm-5mW - Infrared Laser Diode and Infrared Diode Laser Module
Page 1 of 1
Diode Laser Module
Links to Laser Diode &
Laser Module
Configurations and
Specifications
Laser Diode
Laser Diode Module
Micro Laser Module
N808-5
NM808-5
MM808-5
Variable Output
Laser Diode Module
DATA SHEETS .... MM808nm 5mW ....IR LASER MODULE & DIODE
Barrel Specs:
Weight & Wire Lengths:
Lens Housing Specs:
z 2 Pieces
z Module with 6" wire leads - 49 grain wt.b
z 12 - 56 Thread Size
z Module without 6" wire leads - 42 grain wt
z 3.0mm Aperture
z Dia: 6.4mm
z Module with spring leads - 42 1/2 grain wt.
z 4.0mm Plastic Lens
z Length: 17mm
z Spring 2.4mm dia. 4mm long (trimmable)
IR LASER DIODE DATA SHEET
ABSOLUTE MAXIMUM RATINGS - (Tc=25 °C)
TECHNICAL DATA
808nm
IR light output
Optical power output
5mW CW
Package Type
5.6mm
Built-in photo diode for monitoring laser output
Pin Out Diagram
Items
Symbols
Values
Unit
Optical output power
Po
5
mW
Laser diode reverse voltage
V
2
V
Photo diode reverse voltage
V
30
V
Operating temperature
Topr
-10 ~ +45
°C
Storage temperature
Tstg
-40 ~ +85
°C
OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC)
Test Condition
Items
Symbols Min.
Typ.
Max.
Unit
Po
5
mW
Threshold current
Ith
25
40
mA
Iop
35
50
mA
Po=5mW
Operating current
Vop
2.5
V
Po=5mW
Operating voltage
Lasing wavelength
803
808
813
nm
Po=5mW
Beam divergence
5
11
deg
Po=5mW
Beam divergence
25
37
deg
Po=5mW
Im
10
uA
Po=5mW
Monitor current
Astigmatism
As
5
um
Po=5mW
3-5,000 hrs.
Po=5mW
MTTF
Emitter Size
10 x 60 Microns - Emitter Distance to Cap Lens = 0.3mm
Structure
Index Guided
http://www.us-lasers.com/mmd808nm5m.htm
4/7/2009
很抱歉,暂时无法提供与“MM8085I”相匹配的价格&库存,您可以联系我们找货
