IF-HN08M
IF-HN08M
    INDUSTRIALFIBER
    带外壳装置,教育
    LASER HEL NEON .8MW CLASS II MOD
IF-HN08M 数据手册
Specifications Table 2. Laser specifications. Parameter Value Operating Input voltage Input current Temperature 12 to 18 volts 650 milliamperes 0 to 40° C Optical Polarization Wavelength Output power Beam diameter (at aperture) Beam divergence, maximum random 632.8 nm see label on laser underside 1 mm 2 milliradians, half angle Electrical Analog bandwidth, 3 dB 600 Hz to 20 k Hz Storage Dimensions Weight, chassis Weight, power adapter Temperature 5.8 × 8.7 × 36.2 cm 820 grams 470 grams -20 to 50° C Models and Laser Classifications Table 3. CDRH classifications for Industrial Fiber Optics laser models. Laser Model Classification Typical power levels IF-HN05 CLASS II .4 to 1.0 mW IF-HN08 CLASS II .75 to 1.0 mW IF-HN08M CLASS II .75 to 1.0 mW IF-HN15M CLASS IIIa 1.00 to 2.0 mW IF-HN20 CLASS IIIa 1.5 to 3 mW IF-HN35 CLASS IIIa 3.0 to 5.0 mW -6-
IF-HN08M 价格&库存
很抱歉,暂时无法提供与“IF-HN08M”相匹配的价格&库存,您可以联系我们找货
