US-Lasers: 850nm-30mW - IR LASER DIODE and IR DIODE LASER MODULE
Page 1 of 2
US-Lasers: 850nm-30mW - Infrared Laser Diode and
Infrared Diode Laser Module
Back To Laser
Modules
TECHNICAL DATA for LASER MODULE
Barrel Specs:
z
z
z
3/8 - 56 Thread Size
Dia: 10.4mm
Length: 17mm
Collect Specs:
z
z
z
Lens Housing Specs:
4.3mm Aperature
Half Hard Brassbbb
IR LASER DIODE DATA SHEET
z
z
z
3.7mm Aperture
7mm Plastic Lens
ABSOLUTE MAXIMUM RATINGS - (Tc=25 °C)
TECHNICAL DATA
IR light output
850nm
Optical power output
30mW CW
Package Type
5.6mm
Built-in photo diode for monitoring laser output
Pin Out Diagram
Items
Symbols
Values
Unit
Optical output power
Po
30
mW
Laser diode reverse voltage
V
2
V
Photo diode reverse voltage
V
30
V
Operating temperature
Topr
-10 ~ +50
°C
Storage temperature
Tstg
-40 ~ +85
°C
OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC)
Typ.
Max.
Unit
Test Condition
Items
Symbols Min.
Po
30
mW
Threshold current
Ith
30
50
70
mA
Po=30mW
Operating current
Iop
60
80
100
mA
Po=30mW
Operating voltage
Vop
2.0
2.2
2.7
V
Po=30mW
Lasing wavelength
ep
830
850
870
nm
Po=30mW
Beam divergence
8
10
11
deg
Po=30mW
Beam divergence
25
31
40
deg
Po=30mW
Monitor current
Im
100
300
500
uA
Po=30mW
Astigmatism
As
11
um
Po=30mW
Slope Efficiency (mW/mA)
0.3
0.4
0.7
Po=30mW
10000 hrs.
MTTF
Po=30mW
Emitter Size
10 x 60 Microns - Emitter Distance to Cap Lens = 0.3mm
Structure
Index Guided
http://www.us-lasers.com/m850nm30m.htm
4/6/2009
Page 2 of 2
4/6/2009
很抱歉,暂时无法提供与“M850-30”相匹配的价格&库存,您可以联系我们找货
